[国产单片机] MM32F031 DMA+PWM,DMA数据传输问题
2948|7
 楼主| hsxs 发表于 2019-2-16 22:25 | 显示全部楼层 |阅读模式
DMA的中断 我只进入了一次,,第二次中断怎么都进不去了,,不知道是什么问题,,对着手册查了
 楼主| hsxs 发表于 2019-2-16 22:29 | 显示全部楼层
想用PWM 来驱动ws2812,然后试着用DMA+PWM 的方式,我看stm32有人做成功了,然后试着MM32F031这个芯片,
  1. #define TIM2_CCR2_Address 0x40000038
  2. void DMA_TIM2_Init()
  3. {
  4.         NVIC_InitTypeDef NVIC_InitStructure;
  5.         DMA_InitTypeDef DMA_InitStructure;
  6.         DMA_DeInit(DMA1_Channel3);                                                        //通道2
  7.         RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);
  8.
  9.         DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)TIM2_CCR2_Address;           //目标地址
  10.         DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t)LED_BYTE_Buffer;                      //数据地址
  11.         DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralDST;                                //传输方向  MtoP
  12.         DMA_InitStructure.DMA_BufferSize = 10;
  13.         DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;                 //TIM2_CCR2地址不变
  14.         DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;                                                 // automatically increase buffer index
  15.         DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Word;      //16位
  16.         DMA_InitStructure.DMA_MemoryDataSize = DMA_PeripheralDataSize_HalfWord;
  17.         DMA_InitStructure.DMA_Mode = DMA_Mode_Normal;        // stop DMA feed after buffer size is reached
  18.        //不循环
  19.         DMA_InitStructure.DMA_Priority = DMA_Priority_High;                              //通道优先级 高
  20.         DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;                                     //非存储器到存储器
  21.
  22.         NVIC_InitStructure.NVIC_IRQChannel = DMA1_Channel2_3_IRQn;
  23.         NVIC_InitStructure.NVIC_IRQChannelPriority = 2;
  24.         NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  25.         NVIC_Init(&NVIC_InitStructure);
  26.         DMA_Init(DMA1_Channel3, &DMA_InitStructure);
  27.         DMA_ITConfig(DMA1_Channel3, DMA_IT_TC, ENABLE);
  28.
  29. }
这是我DMA 的初始化
  1. void TIM2_PWM_Init(u16 arr,u16 psc,u16 pluse)
  3.         GPIO_InitTypeDef GPIO_InitStructure;
  4.         TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
  5.         TIM_OCInitTypeDef  TIM_OCInitStructure;
  6.         RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE);                   //打开定时器2的时钟
  7.         //复用初始
  8.         GPIO_PinAFConfig(GPIOB,GPIO_PinSource3,GPIO_AF_2);
  9.         GPIO_InitStructure.GPIO_Pin = RGB_PIN;                                   //TIM2_CH2
  10.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;                         //复用推挽输出
  11.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  12.         GPIO_Init(GPIOB, &GPIO_InitStructure);
  13.         TIM_DeInit(TIM2);
  14.         TIM_TimeBaseStructure.TIM_Period = arr-1;                                     //设置在下一个更新事件装入活动的自动重装载寄存器周期的值
  15.         TIM_TimeBaseStructure.TIM_Prescaler =psc;                                   //设置用来作为TIMx时钟频率除数的预分频值  不分频
  16.         /*****TIM_Period和TIM_Prescaler决定了周期*****=(11059200)/(arr+1)*(psc+1)*/
  17.         TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1;                     //设置时钟分割:TDTS = Tck_tim
  18.         TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;                 //TIM向上计数模式
  19.         TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure);                             //根据TIM_TimeBaseInitStruct中指定的参数初始化TIMx的时间基数单位
  20.         TIM_ARRPreloadConfig(TIM2, ENABLE);                                         //使能TIMx在ARR上的预装载寄存器
  21.         TIM_OCStructInit(&TIM_OCInitStructure);                                     //装载默认值
  22.         TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;                           //选择定时器模式:TIM脉冲宽度调制模式1
  23.         TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;               //比较输出使能
  24.         TIM_OCInitStructure.TIM_Pulse = pluse;                                      //设置待装入捕获比较寄存器的脉冲值
  25.         /*******TIM_Pulse决定了占空比******/
  26.         TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;                   //输出极性:TIM输出比较极性高
  27.         TIM_OC2Init(TIM2, &TIM_OCInitStructure);                                    //根据TIM_OCInitStruct中指定的参数初始化外设TIMx
  28.         TIM_OC2PreloadConfig(TIM2, TIM_OCPreload_Enable);                           //CH2预装载使能
  29.         TIM_DMACmd(TIM2, TIM_DMA_Update|TIM_DMA_Trigger, ENABLE);
  30.   TIM_DMACmd(TIM2, TIM_DMA_CC2, ENABLE);
  31.         //        TIM_Cmd(TIM2, ENABLE);                                                      //使能TIMx
  32. }
这是PWM 的初始化
 楼主| hsxs 发表于 2019-2-16 22:31 | 显示全部楼层
  1. void DMA1_Channel2_3_IRQHandler()
  3. //    if(DMA_GetITStatus(DMA1_IT_TC3))
  4. //    {
  5. //        DMA_ClearITPendingBit(DMA1_IT_TC3);
  6. //    }
  7.         while(!DMA_GetFlagStatus(DMA1_FLAG_TC3)) ;         // wait until transfer complete
  8.         TIM_Cmd(TIM2, DISABLE);                           // disable Timer 3
  9.         DMA_Cmd(DMA1_Channel3, DISABLE);                               // disable DMA channel 6
  10.         DMA_ClearFlag(DMA1_FLAG_TC3);                                       // clear DMA1 Channel 6 transfer complete flag
  11. }
在第一次打开DMA_Cmd(DMA1_Channel3, ENABLE);后 可以进入中断,在中断里面关闭了DMA 然后第二次在主函数中打开DMA ,怎么也进入不了
airwill 发表于 2019-2-17 08:33 | 显示全部楼层
是不是中断有标志位没有在中断服务里清理掉?
 楼主| hsxs 发表于 2019-2-18 08:44 | 显示全部楼层
不是,后来我发现,和DMA工作模式有关,我改成循环模式之后,就能每次调用DMA的时候正常工作
airwill 发表于 2019-2-18 22:05 | 显示全部楼层
哦, 看来非循环模式, DMA 完成后需要重新初始化寄存器
liao284423641 发表于 2019-3-31 10:51 | 显示全部楼层
楼主 我现在也用了 这种方式 发现有时候 颜色不正常,用示波器 发现 PWM 频率有时候不对
liao284423641 发表于 2019-3-31 11:21 | 显示全部楼层
while(!DMA_GetFlagStatus(DMA1_FLAG_TC3)) ;    楼主请教一个问题 为什么一定要WHILE
