[STM32L1] STM32L152RBT6 LCD死在while(LCD_GetFlagStatus(LCD_FLAG_RDY) == RESET){} why???
1631|7
 楼主| zefengx68 发表于 2019-3-4 20:09 | 显示全部楼层 |阅读模式
/*!< Wait Until the LCD Booster is ready */
各位大神,死在这里是怎么一回事,请教下???
以下是我的代码:
void PER_LcdInit(void)
    LCD_InitTypeDef LCD_InitStructure;
    //¿ªÆôLSIºÍÅäÖÃRTCʱÖÓ
        RCC_LSICmd(ENABLE);
    while (RCC_GetFlagStatus(RCC_FLAG_LSIRDY) == RESET);
    RCC_RTCCLKConfig(RCC_RTCCLKSource_LSI);
    RCC_RTCCLKCmd(ENABLE);
    RTC_WaitForSynchro();
    RCC_APB1PeriphClockCmd(RCC_APB1Periph_LCD, ENABLE);
    GPIO_LcdInit();
    LCD_InitStructure.LCD_Prescaler = LCD_Prescaler_512;
    LCD_InitStructure.LCD_Divider = LCD_Divider_16;
    LCD_InitStructure.LCD_Duty = LCD_Duty_1_4;
    LCD_InitStructure.LCD_Bias = LCD_Bias_1_3 ;
    LCD_InitStructure.LCD_VoltageSource = LCD_VoltageSource_Internal;
    //LCD_InitStructure.LCD_VoltageSource = LCD_VoltageSource_External;
    LCD_Init(&LCD_InitStructure);
    //COMºÍSEG¸´ÓÃ
    LCD_MuxSegmentCmd(DISABLE);
    //LCD_MuxSegmentCmd(ENABLE);
    //²»¿¼Âǹ¦ºÄ£¬¿ÉÒÔ´ò¿ª
    LCD_HighDriveCmd(DISABLE);
    //LCD_HighDriveCmd(ENABLE);
    /*!< Configure the Pulse On Duration */
    //Âö³å³ÖÐøÊ±¼ä
    LCD_PulseOnDurationConfig(LCD_PulseOnDuration_7);
    //ËÀÇøÊ±¼ä
    LCD_DeadTimeConfig(LCD_DeadTime_1);
    //2.99V ¶Ô±È¶È
    LCD_ContrastConfig(LCD_Contrast_Level_3);
    /*!< Wait Until the LCD FCR register is synchronized */
    LCD_WaitForSynchro();
    /*!< Enable LCD peripheral */
    LCD_Cmd(ENABLE);
    /*!< Wait Until the LCD is enabled */
    while(LCD_GetFlagStatus(LCD_FLAG_ENS) == RESET){}
    LCD_Write(LCD_RAMRegister_0,(uint32_t)0x03F0);
    LCD_Write(LCD_RAMRegister_2,(uint32_t)0x03FF);
    LCD_Write(LCD_RAMRegister_4,(uint32_t)0x03FF);
    LCD_Write(LCD_RAMRegister_6,(uint32_t)0x03FF);
//    LCD->RAM[LCD_RAMRegister_0] = 0x40|(LCD->RAM[LCD_RAMRegister_0]);
void GPIO_LcdInit(void)
    /*!< Enable GPIOA, GPIOB, GPIOC, GPIOD and GPIOE AHB Clocks */
    RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA | RCC_AHBPeriph_GPIOB | RCC_AHBPeriph_GPIOC
                        | RCC_AHBPeriph_GPIOD | RCC_AHBPeriph_GPIOE, ENABLE);
//    GPIO_PinAFConfig(GPIOA, GPIO_PinSource8, GPIO_AF_LCD);
//        GPIO_PinAFConfig(GPIOA, GPIO_PinSource9, GPIO_AF_LCD);
//    GPIO_PinAFConfig(GPIOA, GPIO_PinSource10, GPIO_AF_LCD);
//    GPIO_PinAFConfig(GPIOB, GPIO_PinSource9, GPIO_AF_LCD);
    /*!< Connect PA.08 to LCD COM0 */
    /*!< Connect PA.09 to LCD COM1 */
    /*!< Connect PA.10 to LCD COM2 */
    /*!< Connect PB.09 to LCD COM3 */
//    GPIO_PinAFConfig(GPIOA, GPIO_PinSource1, GPIO_AF_LCD);
//        GPIO_PinAFConfig(GPIOA, GPIO_PinSource2, GPIO_AF_LCD);
//    GPIO_PinAFConfig(GPIOA, GPIO_PinSource3, GPIO_AF_LCD);
//    GPIO_PinAFConfig(GPIOA, GPIO_PinSource6, GPIO_AF_LCD);
//    GPIO_PinAFConfig(GPIOA, GPIO_PinSource7, GPIO_AF_LCD);
//    GPIO_PinAFConfig(GPIOB, GPIO_PinSource0, GPIO_AF_LCD);
//    GPIO_PinAFConfig(GPIOB, GPIO_PinSource1, GPIO_AF_LCD);
//    GPIO_PinAFConfig(GPIOB, GPIO_PinSource3, GPIO_AF_LCD);
//    GPIO_PinAFConfig(GPIOB, GPIO_PinSource4, GPIO_AF_LCD);
//    GPIO_PinAFConfig(GPIOB, GPIO_PinSource5, GPIO_AF_LCD);
//    GPIO_PinAFConfig(GPIOB, GPIO_PinSource10, GPIO_AF_LCD);
//    GPIO_PinAFConfig(GPIOB, GPIO_PinSource11, GPIO_AF_LCD);
    /*!< Connect PA.01 to LCD SEG0 */
    /*!< Connect PA.02 to LCD SEG1 */
    /*!< Connect PA.03 to LCD SEG2 */
    /*!< Connect PA.06 to LCD SEG3 */
    /*!< Connect PA.07 to LCD SEG4 */
    /*!< Connect PB.00 to LCD SEG5 */
    /*!< Connect PB.01 to LCD SEG6 */
    /*!< Connect PB.03 to LCD SEG7 */
    /*!< Connect PB.04 to LCD SEG8 */
    /*!< Connect PB.05 to LCD SEG9 */
    /*!< Connect PB.10 to LCD SEG10 */
    /*!< Connect PB.11 to LCD SEG11 */
//    /*!< Connect PB.12 to LCD SEG12 */
//    GPIO_PinAFConfig(GPIOB, GPIO_PinSource12, GPIO_AF_LCD);
//    /*!< Connect PB.13 to LCD SEG13 */
//    GPIO_PinAFConfig(GPIOB, GPIO_PinSource13, GPIO_AF_LCD);
//    /*!< Connect PB.14 to LCD SEG14*/
//    GPIO_PinAFConfig(GPIOB, GPIO_PinSource14, GPIO_AF_LCD);
//    /*!< Connect PB.15 to LCD SEG15 */
//    GPIO_PinAFConfig(GPIOB, GPIO_PinSource15, GPIO_AF_LCD);
//    /*!< Connect PB.08 to LCD SEG16 */
//    GPIO_PinAFConfig(GPIOB, GPIO_PinSource8, GPIO_AF_LCD);
//    /*!< Connect PA.15 to LCD SEG17 */
//    GPIO_PinAFConfig(GPIOA, GPIO_PinSource15, GPIO_AF_LCD);//JTDI
//    /*!< Connect PC.00 to LCD SEG18 */
//    GPIO_PinAFConfig(GPIOC, GPIO_PinSource0, GPIO_AF_LCD);
//    /*!< Connect PC.01 to LCD SEG19 */
//    GPIO_PinAFConfig(GPIOC, GPIO_PinSource1, GPIO_AF_LCD);
//    /*!< Connect PC.02 to LCD SEG20 */
//    GPIO_PinAFConfig(GPIOC, GPIO_PinSource2, GPIO_AF_LCD);
//    /*!< Connect PC.03 to LCD SEG21 */
//    GPIO_PinAFConfig(GPIOC, GPIO_PinSource3, GPIO_AF_LCD);
//    /*!< Connect PC.04 to LCD SEG22 */
//    GPIO_PinAFConfig(GPIOC, GPIO_PinSource4, GPIO_AF_LCD);
//    /*!< Connect PC.05 to LCD SEG23 */
//    GPIO_PinAFConfig(GPIOC, GPIO_PinSource5, GPIO_AF_LCD);
//    /*!< Connect PC.06 to LCD SEG24 */
//    GPIO_PinAFConfig(GPIOC, GPIO_PinSource6, GPIO_AF_LCD);
//    /*!< Connect PC.07 to LCD SEG25 */
//    GPIO_PinAFConfig(GPIOC, GPIO_PinSource7, GPIO_AF_LCD);
//    /*!< Connect PC.08 to LCD SEG26 */
//    GPIO_PinAFConfig(GPIOC, GPIO_PinSource8, GPIO_AF_LCD);
//    /*!< Connect PC.09 to LCD SEG27 */
//    GPIO_PinAFConfig(GPIOC, GPIO_PinSource9, GPIO_AF_LCD);
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1 | GPIO_Pin_2 | GPIO_Pin_3 | GPIO_Pin_6 | GPIO_Pin_7 | \
                                  GPIO_Pin_8 | GPIO_Pin_9 | GPIO_Pin_10;
    GPIO_InitStructure.GPIO_Speed = GPIO_Speed_40MHz;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
    GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
    GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
    GPIO_Init(GPIOA, &GPIO_InitStructure);
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_3 | GPIO_Pin_4 | GPIO_Pin_5 | \
                                  GPIO_Pin_9 | GPIO_Pin_10 | GPIO_Pin_11;
    GPIO_Init(GPIOB, &GPIO_InitStructure);
 楼主| zefengx68 发表于 2019-3-4 20:15 | 显示全部楼层
这是引脚图 VLCD是外接3V的,一直开我配置成外部电源不行,死在这句。。后来把VLCD割断了,选择内部电源,还是不行。!!!
643757107 发表于 2019-3-4 21:53 | 显示全部楼层
这个是用的STM32内部的LCD驱动,还是外置的?
 楼主| zefengx68 发表于 2019-3-5 09:51 来自手机 | 显示全部楼层
想用STM32内部的LCD控制器,不知道为什么会死在这句话上
 楼主| zefengx68 发表于 2019-3-5 11:37 来自手机 | 显示全部楼层
xiaoqizi 发表于 2019-3-11 15:43 | 显示全部楼层
最好别用while语句
木木guainv 发表于 2019-3-11 15:50 | 显示全部楼层
是说屏幕不能复位?
zhazhahua 发表于 2020-2-24 15:36 | 显示全部楼层
老哥,这个问题解决了吗?
