[技术问答] 新唐m051串口没输出
1602|11
 楼主| tangzhipeng12 发表于 2019-3-8 10:12 | 显示全部楼层 |阅读模式
#include <stdio.h>
#include "M051Series.h"
#define PLL_CLOCK           50000000
void SYS_Init(void)
    /* Unlock protected registers */
    SYS_UnlockReg();
    /* Init System Clock        */
    /* Enable Internal RC 22.1184MHz clock */
    CLK_EnableXtalRC(CLK_PWRCON_OSC22M_EN_Msk);
    /* Waiting for Internal RC clock ready */
    CLK_WaitClockReady(CLK_CLKSTATUS_OSC22M_STB_Msk);
    /* Switch HCLK clock source to Internal RC and HCLK source divide 1 */
    CLK_SetHCLK(CLK_CLKSEL0_HCLK_S_HIRC, CLK_CLKDIV_HCLK(1));
    /* Enable external XTAL 12MHz clock */
    CLK_EnableXtalRC(CLK_PWRCON_XTL12M_EN_Msk);
    /* Waiting for external XTAL clock ready */
    CLK_WaitClockReady(CLK_CLKSTATUS_XTL12M_STB_Msk);
        /*选择外部时钟为HCLK时钟*/
        //        CLK_SetHCLK(CLK_CLKSEL0_HCLK_S_HXT, CLK_CLKDIV_HCLK(1));
    /* Set core clock as PLL_CLOCK from PLL */
    CLK_SetCoreClock(PLL_CLOCK);
    /* Enable UART module clock */
    CLK_EnableModuleClock(UART0_MODULE);
    /* Select UART module clock source */
    CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UART_S_PLL, CLK_CLKDIV_UART(1));
    /* Init I/O Multi-function        */
    /* Set P3 multi-function pins for UART0 RXD and TXD */
    SYS->P3_MFP &= ~(SYS_MFP_P30_Msk | SYS_MFP_P31_Msk);
    SYS->P3_MFP |= (SYS_MFP_P30_RXD0 | SYS_MFP_P31_TXD0);
                /* Lock protected registers */
    SYS_LockReg();
void UART0_Init(void)
    /* Init UART        */
    /* Reset UART0 */
    SYS_ResetModule(UART0_RST);
           UART_Open(UART0, 115200);
/* MAIN function        */
int main(void)
                //uint8_t a=1;
    //uint8_t *Buf=&a;
    /* Init System, peripheral clock and multi-function I/O */
                unsigned char i,j;
    SYS_Init();
    /* Init UART0 for printf */
    UART0_Init();
  // printf("\n\nCPU @ %d Hz\n", SystemCoreClock);
   // printf("+-------------------------------------------------+\n");
   // printf("|    P1.2(Output) and P4.1(Input) Sample Code     |\n");
   // printf("+-------------------------------------------------+\n\n");
    /* Configure P1.2 as Output mode and P4.1 as Input mode */
   GPIO_SetMode(P4, BIT2, GPIO_PMD_OUTPUT);
   while(1)
                        j=0;
                        P42=1;
                        //延时0.1s
                        CLK_SysTickDelay(100000);
                        P42=0;
                        for(i=0;i<5;i++)
                                        UART_Write(UART0, &j, 1);
                                        j++;
clyu 发表于 2019-3-8 14:01 | 显示全部楼层
先把UART时钟源选HIRC试试看,是不是外部晶振没起振?另外,用示波器量一下P3.1有没有波形输出?
zhuotuzi 发表于 2019-3-8 19:33 来自手机 | 显示全部楼层
先测试官方例子
734774645 发表于 2019-3-10 21:48 | 显示全部楼层
  1. /****************************************************************************
  2. * [url=home.php?mod=space&uid=288409]@file[/url]     main.c
  3. * [url=home.php?mod=space&uid=895143]@version[/url]  V1.00
  4. * $Revision: 4 $
  5. * $Date: 14/01/28 11:45a $
  6. * [url=home.php?mod=space&uid=247401]@brief[/url]    M051 Series UART Interface Controller Driver Sample Code
  7. *
  8. * @note
  9. * Copyright (C) 2011 Nuvoton Technology Corp. All rights reserved.
  10. *
  11. ******************************************************************************/
  12. #include <stdio.h>
  13. #include "M051Series.h"
  14. #define PLL_CLOCK           50000000
  15. #define RXBUFSIZE 1024
  16. /*---------------------------------------------------------------------------------------------------------*/
  17. /* Global variables        */
  18. /*---------------------------------------------------------------------------------------------------------*/
  19. uint8_t g_u8RecData[RXBUFSIZE]  = {0};
  20. volatile uint32_t g_u32comRbytes = 0;
  21. volatile uint32_t g_u32comRhead  = 0;
  22. volatile uint32_t g_u32comRtail  = 0;
  23. volatile int32_t g_bWait         = TRUE;
  24. /*---------------------------------------------------------------------------------------------------------*/
  25. /* Define functions prototype        */
  26. /*---------------------------------------------------------------------------------------------------------*/
  27. int32_t main(void);
  28. void UART_TEST_HANDLE(void);
  29. void UART_FunctionTest(void);
  30. void SYS_Init(void)
  31. {
  32.     /*---------------------------------------------------------------------------------------------------------*/
  33.     /* Init System Clock        */
  34.     /*---------------------------------------------------------------------------------------------------------*/
  35.     /* Enable Internal RC 22.1184MHz clock */
  36.     CLK_EnableXtalRC(CLK_PWRCON_OSC22M_EN_Msk);
  37.     /* Waiting for Internal RC clock ready */
  38.     CLK_WaitClockReady(CLK_CLKSTATUS_OSC22M_STB_Msk);
  39.     /* Switch HCLK clock source to Internal RC and HCLK source divide 1 */
  40.     CLK_SetHCLK(CLK_CLKSEL0_HCLK_S_HIRC, CLK_CLKDIV_HCLK(1));
  41.     /* Enable external XTAL 12MHz clock */
  42.     CLK_EnableXtalRC(CLK_PWRCON_XTL12M_EN_Msk);
  43.     /* Waiting for external XTAL clock ready */
  44.     CLK_WaitClockReady(CLK_CLKSTATUS_XTL12M_STB_Msk);
  45.     /* Set core clock as PLL_CLOCK from PLL */
  46.     CLK_SetCoreClock(PLL_CLOCK);
  47.     /* Enable UART module clock */
  48.     CLK_EnableModuleClock(UART0_MODULE);
  49.     /* Select UART module clock source */
  50.     CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UART_S_HXT, CLK_CLKDIV_UART(1));
  51.     /*---------------------------------------------------------------------------------------------------------*/
  52.     /* Init I/O Multi-function        */
  53.     /*---------------------------------------------------------------------------------------------------------*/
  54.     /* Set P3 multi-function pins for UART0 RXD and TXD */
  55.     SYS->P3_MFP &= ~(SYS_MFP_P30_Msk | SYS_MFP_P31_Msk);
  56.     SYS->P3_MFP |= (SYS_MFP_P30_RXD0 | SYS_MFP_P31_TXD0);
  57. }
  58. void UART0_Init()
  59. {
  60.     /*---------------------------------------------------------------------------------------------------------*/
  61.     /* Init UART        */
  62.     /*---------------------------------------------------------------------------------------------------------*/
  63.     /* Reset IP */
  64.     SYS_ResetModule(UART0_RST);
  65.     /* Configure UART0 and set UART0 Baudrate */
  66.     UART_Open(UART0, 115200);
  67. }
  68. /*---------------------------------------------------------------------------------------------------------*/
  69. /* UART Test Sample        */
  70. /* Test Item        */
  71. /* It sends the received data to HyperTerminal.                                                            */
  72. /*---------------------------------------------------------------------------------------------------------*/
  73. /*---------------------------------------------------------------------------------------------------------*/
  74. /* MAIN function        */
  75. /*---------------------------------------------------------------------------------------------------------*/
  76. int main(void)
  77. {
  78.     /* Unlock protected registers */
  79.     SYS_UnlockReg();
  80.     /* Init System, IP clock and multi-function I/O */
  81.     SYS_Init();
  82.     /* Lock protected registers */
  83.     SYS_LockReg();
  84.     /* Init UART0 for printf and testing */
  85.     UART0_Init();
  86.     /*---------------------------------------------------------------------------------------------------------*/
  87.     /* SAMPLE CODE        */
  88.     /*---------------------------------------------------------------------------------------------------------*/
  89.     printf("\n\nCPU [url=home.php?mod=space&uid=72445]@[/url] %dHz\n", SystemCoreClock);
  90.     printf("\n\nUART Sample Program\n");
  91.     /* UART sample function */
  92.     UART_FunctionTest();
  93. }
  94. /*---------------------------------------------------------------------------------------------------------*/
  95. /* ISR to handle UART Channel 0 interrupt event                                                            */
  96. /*---------------------------------------------------------------------------------------------------------*/
  97. void UART0_IRQHandler(void)
  98. {
  99.     UART_TEST_HANDLE();
  100. }
  101. /*---------------------------------------------------------------------------------------------------------*/
  102. /* UART Callback function        */
  103. /*---------------------------------------------------------------------------------------------------------*/
  104. void UART_TEST_HANDLE()
  105. {
  106.     uint8_t u8InChar = 0xFF;
  107.     uint32_t u32IntSts = UART0->ISR;
  108.     if(u32IntSts & UART_ISR_RDA_INT_Msk)
  109.     {
  110.         printf("\nInput:");
  111.         /* Get all the input characters */
  112.         while(UART_IS_RX_READY(UART0))
  113.         {
  114.             /* Get the character from UART Buffer */
  115.             u8InChar = UART_READ(UART0);
  116.             printf("%c ", u8InChar);
  117.             if(u8InChar == '0')
  118.             {
  119.                 g_bWait = FALSE;
  120.             }
  121.             /* Check if buffer full */
  122.             if(g_u32comRbytes < RXBUFSIZE)
  123.             {
  124.                 /* Enqueue the character */
  125.                 g_u8RecData[g_u32comRtail] = u8InChar;
  126.                 g_u32comRtail = (g_u32comRtail == (RXBUFSIZE - 1)) ? 0 : (g_u32comRtail + 1);
  127.                 g_u32comRbytes++;
  128.             }
  129.         }
  130.         printf("\nTransmission Test:");
  131.     }
  132.     if(u32IntSts & UART_ISR_THRE_INT_Msk)
  133.     {
  134.         uint16_t tmp;
  135.         tmp = g_u32comRtail;
  136.         if(g_u32comRhead != tmp)
  137.         {
  138.             u8InChar = g_u8RecData[g_u32comRhead];
  139.             UART_WRITE(UART0, u8InChar);
  140.             g_u32comRhead = (g_u32comRhead == (RXBUFSIZE - 1)) ? 0 : (g_u32comRhead + 1);
  141.             g_u32comRbytes--;
  142.         }
  143.     }
  144. }
  145. /*---------------------------------------------------------------------------------------------------------*/
  146. /*  UART Function Test        */
  147. /*---------------------------------------------------------------------------------------------------------*/
  148. void UART_FunctionTest()
  149. {
  150.     printf("+-----------------------------------------------------------+\n");
  151.     printf("|  UART Function Test                                       |\n");
  152.     printf("+-----------------------------------------------------------+\n");
  153.     printf("|  Description :                                            |\n");
  154.     printf("|    The sample code will print input char on terminal      |\n");
  155.     printf("|    Please enter any to start     (Press '0' to exit)      |\n");
  156.     printf("+-----------------------------------------------------------+\n");
  157.     /*
  158.         Using a RS232 cable to connect UART0 and PC.
  159.         UART0 is set to debug port. UART0 is enable RDA and RLS interrupt.
  160.         When inputing char to terminal screen, RDA interrupt will happen and
  161.         UART0 will print the received char on screen.
  162.     */
  163.     /* Enable Interrupt and install the call back function */
  164.     UART_ENABLE_INT(UART0, (UART_IER_RDA_IEN_Msk | UART_IER_THRE_IEN_Msk | UART_IER_RTO_IEN_Msk));
  165.     NVIC_EnableIRQ(UART0_IRQn);
  166.     while(g_bWait);
  167.     /* Disable Interrupt */
  168.     UART_DISABLE_INT(UART0, (UART_IER_RDA_IEN_Msk | UART_IER_THRE_IEN_Msk | UART_IER_RTO_IEN_Msk));
  169.     NVIC_DisableIRQ(UART0_IRQn);
  170.     g_bWait = TRUE;
  171.     printf("\nUART Sample Demo End.\n");
  172. }
试试上面这个,官方BSP里的。
 楼主| tangzhipeng12 发表于 2019-3-12 17:31 | 显示全部楼层
我外部用的是22.1184M的晶振……示波器量晶振起震了
 楼主| tangzhipeng12 发表于 2019-3-12 17:38 | 显示全部楼层
官方例程是不是接了外部晶振时钟选择外部晶振没有接就自动选择成内部晶振是吧?
dongliushui 发表于 2019-3-12 20:52 | 显示全部楼层
是不是晶振没有配置对
dongliushui 发表于 2019-3-12 20:53 | 显示全部楼层
时钟选择上,要设置外部,且是你用的那个大小。
默认的是外部12M,例子里。
 楼主| tangzhipeng12 发表于 2019-3-13 09:09 | 显示全部楼层
默认的是外部12M,例子里。
例子里打开内部时钟的作用是什么……
 楼主| tangzhipeng12 发表于 2019-3-14 08:56 | 显示全部楼层
一个好用的工具PinView……现在串口正常了……
