PIC18系列 编辑问题type qualifier mismatch in assignment
5794|5
 楼主| aresmcu 发表于 2011-9-17 14:57 | 显示全部楼层 |阅读模式
lcd_puts("A/D:");
void lcd_puts(const char * s)
LCD_RS = 1; // write characters
while(*s)
lcd_write(*s++);
D:\code\18F\LED\LED.C:16:Warning [2066] type qualifier mismatch in assignment
我在16F874A里 编辑通过的 到18里面这么就不行了?
请高手指点 谢谢(下面是我的源程序)
 楼主| aresmcu 发表于 2011-9-17 15:00 | 显示全部楼层
#include        <p18f4520.h>
#include        "lcd.h"
#define        LCD_RS  PORTAbits.RA3
#define        LCD_RW  PORTAbits.RA2
#define LCD_EN  PORTAbits.RA1
#define LCD_DATA        PORTD
#define        LCD_STROBE()        ((LCD_EN = 1),(LCD_EN=0))
void __delay_us(unsigned int time)
while(--time)
void __delay_ms(unsigned int time1)
unsigned int i=0,j=2000;
i=j*time1;
  while(--i)
void  delay(void)
unsigned  int n,m;
   for(n=0;n<=6000;n++)
    {m++;}
  if(m==6000)
    {m=0;}
/* write a byte to the LCD in 4 bit mode */
void
lcd_write(unsigned char c)
        __delay_us(40);
        LCD_DATA = ( ( c >> 4 ) & 0x0F );
        LCD_STROBE();
        LCD_DATA = ( c & 0x0F );
        LCD_STROBE();
*         Clear and home the LCD
void
lcd_clear(void)
        LCD_RS = 0;
        lcd_write(0x1);
        __delay_ms(2);
/* write a string of chars to the LCD */
        while(*s)
                lcd_write(*s++);
/* write one character to the LCD */
void
lcd_putch(char c)
        lcd_write( c );
* Go to the specified position
void lcd_goto(unsigned char y,unsigned char x)
        LCD_RS = 0;
    y&=0x01;
        x&=0x0f;//限制x不能大于15,y不能大于1
        if(y)x|=0x40;//第二行地址为0x40+0x80;
        x|=0x80;
    lcd_write(x);
/* initialise the LCD - put into 4 bit mode */
void
lcd_init()
        char init_value;
        ADCON1 = 0x06;        // Disable analog pins on PORTA
        init_value = 0x3;
        TRISA=0x10;
        TRISD=0;
        LCD_RS = 0;
        LCD_EN = 0;
        LCD_RW = 0;
        __delay_ms(15);        // wait 15mSec after power applied,
        LCD_DATA         = init_value;
        LCD_STROBE();
        __delay_ms(5);
        LCD_STROBE();
        __delay_us(200);
        LCD_STROBE();
        __delay_us(200);
        LCD_DATA = 2;        // Four bit mode
        LCD_STROBE();
        lcd_write(0x28); // Set interface length
        lcd_write(0xF); // Display On, Cursor On, Cursor Blink
        lcd_clear();        // Clear screen
        lcd_write(0x6); // Set entry Mode
#include<p18f452.h>
#include"lcd.h"
#define        LED0  PORTBbits.RB0
#define        LED1  PORTBbits.RB1
#define LED2  PORTBbits.RB2
#define LED3  PORTBbits.RB3
void main()
    lcd_init();
    lcd_goto(1,0);        // select first lzine
        lcd_puts("A/D:");
        lcd_goto(0,1);        // Select second line
        lcd_puts("Thunder  Tiger");
    lcd_goto(0,15);        // Select second line
        lcd_puts("    ");
   TRISB=0;
   PORTB=0;
while(1)
LED0=~LED0;
delay();
delay();
delay();
delay();
LED1=~LED1;
delay();
delay();
delay();
delay();
LED2=~LED2;
delay();
delay();
delay();
delay();
LED3=~LED3;
delay();
delay();
delay();
delay();
胡来一刀 发表于 2011-10-14 18:52 | 显示全部楼层
遇到了同样的问题,不知道怎么解决!
胡来一刀 发表于 2011-10-14 18:56 | 显示全部楼层
修改为
void lcd_puts(const rom char * s)
试一下!
我刚才无意中试出来了!编译通过,没告警了!
shuidi_wangdan 发表于 2013-7-29 13:18 | 显示全部楼层
修改为
const rom起什么作用?
是指向了程序区吗?
