编译工程有如下提示:
Clean: Deleting intermediary and output files.
Clean: Deleted file "E:\Controler\Soft\Main.cce".
Clean: Deleted file "E:\Controler\Soft\Controler.mcs".
Clean: Done.
Executing: "C:\HT-PIC\BIN\PICC.EXE" -C -E"Main.cce" "Main.c" -O"Main.obj" -Zg9 -O -ASMLIST -Q -MPLAB -16F886
This compiler will expire in 20 days
Compiler operating in demo mode.
Some command line options are disabled and compilation is delayed.
Register this compiler to enable these options.
Error[000] : Unknown flag -16F886
Halting build on first failure as requested.
BUILD FAILED: Sun Sep 18 00:02:41 2011
编译没有通过仅仅是编译器有效期的问题吗?还是因为其他的原因?谢谢!!! |
