求助,GD32330的片子,注入通道AD采集
1320|2
 楼主| qdb33b 发表于 2019-4-18 13:46 | 显示全部楼层 |阅读模式
我照着库里给的历程把timer1-ch0改成timer2-ch3就可以,但是改成timer0-ch0就不行了,高级定时器配置有什么不一样吗
原带的配置:
void timer_config(void)
    timer_oc_parameter_struct timer_ocintpara;
    timer_parameter_struct timer_initpara;
    /* TIMER1 configuration */
    timer_initpara.prescaler         = 8399;
    timer_initpara.alignedmode       = TIMER_COUNTER_EDGE;
    timer_initpara.counterdirection  = TIMER_COUNTER_UP;
    timer_initpara.period            = 9999;
    timer_initpara.clockdivision     = TIMER_CKDIV_DIV1;
    timer_initpara.repetitioncounter = 0;
    timer_init(TIMER1,&timer_initpara);
    /* CH0 configuration in PWM mode1 */
    timer_ocintpara.ocpolarity  = TIMER_OC_POLARITY_HIGH;
    timer_ocintpara.outputstate = TIMER_CCX_ENABLE;
    timer_channel_output_config(TIMER1, TIMER_CH_0, &timer_ocintpara);
    timer_channel_output_pulse_value_config(TIMER1, TIMER_CH_0, 3999);
    timer_channel_output_mode_config(TIMER1, TIMER_CH_0, TIMER_OC_MODE_PWM1);
    timer_channel_output_shadow_config(TIMER1, TIMER_CH_0, TIMER_OC_SHADOW_DISABLE);
改后的配置:
    timer_deinit(TIMER0);
    timer_init(TIMER0,&timer_initpara);
    timer_channel_output_config(TIMER0, TIMER_CH_3, &timer_ocintpara);
    timer_channel_output_pulse_value_config(TIMER0, TIMER_CH_3, 3999);
    timer_channel_output_mode_config(TIMER0, TIMER_CH_3, TIMER_OC_MODE_TIMING);
    timer_channel_output_shadow_config(TIMER0, TIMER_CH_3, TIMER_OC_SHADOW_ENABLE);
q11726 发表于 2019-4-19 09:00 | 显示全部楼层
因为timer0-ch0是规则组的触发通道
请注意看F3X0的用户手册P161哦
