基于RL-RTX的ADC转换,结果通过串口发到电脑。
顺便说一下,新塘的数据手册写的真是烂到家了。翻了几遍了,愣是没找到VBG是多少
初始化代码-
- #include "NUC1xx.h"
- #include "drvsys.h"
- #include "drvgpio.h"
- #include "drvuart.h"
- #include "drvadc.h"
- static void ClockInit( void )
- UNLOCKREG();
- DrvSYS_SetOscCtrl( E_SYS_XTL12M, ENABLE );
- DrvSYS_SelectPLLSource( E_SYS_EXTERNAL_12M );
- DrvSYS_Open(48000000);
- DrvSYS_SelectSysTickSource( 3 );
- static void UartInit( void )
- STR_UART_T sParam;
- sParam.u32BaudRate = 115200;
- sParam.u8cDataBits = DRVUART_DATABITS_8;
- sParam.u8cStopBits = DRVUART_STOPBITS_1;
- sParam.u8cParity = DRVUART_PARITY_NONE;
- sParam.u8cRxTriggerLevel = DRVUART_FIFO_1BYTES;
- DrvSYS_SelectIPClockSource(E_SYS_UART_CLKSRC, INTERNAL_HCLK);
- DrvUART_Open (UART_PORT0, &sParam);
- DrvGPIO_InitFunction(E_FUNC_UART0_RX_TX);
- static void ADCInit( void )
- DrvADC_Open(ADC_SINGLE_END, ADC_SINGLE_CYCLE_OP, (1 << 1) | (1 << 7), EXTERNAL_12MHZ, 11); //Set adc parameter
- DrvADC_ConfigADCChannel7( INTERNAL_BANDGAP );
- DrvGPIO_InitFunction(E_FUNC_ADC1);
- DrvADC_EnableSelfCalibration(); //start calibration
- while(DrvADC_IsCalibrationDone() == 0);
- void SystemInit( void )
- ClockInit();
- UartInit();
- ADCInit();
- /* 重定向PRINTF函数到串口1*/
- int putchar(int __c)
- if(DrvUART_Write(UART_PORT0, (unsigned char *)__c, 1))
- return 1;
- else
- return 0;
主函数代码-
- #include <rtl.h>
- #include "bsp.h"
- #include <stdio.h>
- __task void ledtask( void )
- for( ;; )
- unsigned int i;
- float j;
- DrvADC_StartConvert(); //start first convert
- os_dly_wait( 200 );
- i = DrvADC_GetConversionData( 1 );
- j = (float)i * 3.3 / 4095;
- printf("The ADC Channel 1 Voltage:%1.3f V\n", j);
- i = DrvADC_GetConversionData( 7 );
- printf("The VBG Voltage:%1.3f V\n", j);
- __task void taskinit( void )
- os_tsk_create(ledtask, 1); //创建任务
- os_tsk_delete_self(); //删除自己
- for( ;; )
- int main( void )
- os_sys_init( taskinit ); //启动任务调度器
- while( 1 )
