[STM32F1] 关于SPI_NSS_Hard的问题
2199|6
 楼主| shipeng1989 发表于 2019-6-13 20:34 | 显示全部楼层 |阅读模式
spi, IO, gp, GPIO, ni
#ifdef        SPI3_NSS_HARD
#define SPI3_CS_ENABLE             SPI_Cmd(SPI3, ENABLE)
#define SPI3_CS_DISABLE            SPI_Cmd(SPI3, DISABLE)
#else
#define SPI3_CS_ENABLE             PAout(15)=0
#define SPI3_CS_DISABLE            PAout(15)=1
#endif
void SPI3_Configuration(void)
        SPI_InitTypeDef  SPI_InitStructure;
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_SPI3, ENABLE);
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB | RCC_APB2Periph_AFIO, ENABLE);
        GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable, ENABLE);//JTAG Disable SWDP Enable
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3  |  GPIO_Pin_4  | GPIO_Pin_5;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
        GPIO_Init(GPIOB, &GPIO_InitStructure);
        /* SPI: CS推挽输出 */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_15;
        #else
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
        #endif
  GPIO_Init(GPIOA, &GPIO_InitStructure);
        /* SPI 初始化定义 */
  SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex; //SPI设置为双线双向全双工
  SPI_InitStructure.SPI_Mode = SPI_Mode_Master;                      //设置为主 SPI
  SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;                  //SPI发送接收 8 位帧结构
  SPI_InitStructure.SPI_CPOL = SPI_CPOL_High;                        //时钟悬空高
  SPI_InitStructure.SPI_CPHA = SPI_CPHA_2Edge;                       //数据捕获于第二个时钟沿
        SPI_InitStructure.SPI_NSS = SPI_NSS_Hard;                          //硬件控制 NSS 信号
  #else
        SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;                          //软件控制 NSS 信号
        #endif
        SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_2; //波特率预分频值为2
  SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;                 //数据传输从 MSB 位开始
  SPI_InitStructure.SPI_CRCPolynomial = 7;                           //定义了用于 CRC值计算的多项式
  SPI_Init(SPI3, &SPI_InitStructure);
        SPI_SSOutputCmd(SPI3, ENABLE);
        SPI_Cmd(SPI3, DISABLE);
        #else
        SPI_Cmd(SPI3, ENABLE);
        #endif
        DMA_Config();
如上定义宏SPI3_NSS_HARD配置为硬件控制NSS输出,现烧录两个硬件:一个是采用HSI+PLL时钟64MHz,另一个采用HSE+PLL时钟72MHz。
测试如下代码:
void SFLASH_FastReadNByte(uint8_t* pBuffer, uint32_t ReadAddr, uint16_t nByte)
  while (PAin(15)==0);//Wait CS Disable
        SFLASH_WaitForNoBusy();
        SPI3_CS_ENABLE;                                 //使能器件
  SPI3_WriteByte(SFLASH_FAST_READ);               //《快读数据》指令
  SPI3_WriteByte((uint8_t)((ReadAddr)>>16));      //发送24bit地址
  SPI3_WriteByte((uint8_t)((ReadAddr)>>8));
  SPI3_WriteByte((uint8_t)ReadAddr);
  SPI3_WriteByte(0xFF);                           //等待8个时钟
  while(nByte--)                                 //循环读数
    *pBuffer = SPI3_ReadByte();
    pBuffer++;
  SPI3_CS_DISABLE;                                //失能器件
uint8_t SPI3_WriteByte(uint8_t TxData)
  while((SPI3->SR & SPI_I2S_FLAG_TXE) == (uint16_t)RESET);
  SPI3->DR = TxData;
  while((SPI3->SR & SPI_I2S_FLAG_RXNE) == (uint16_t)RESET);//发现程序会卡在此处
  return SPI3->DR;
发现64MHz硬件运行正常,但72MHz时钟硬件程序会卡在“while((SPI3->SR & SPI_I2S_FLAG_RXNE) == (uint16_t)RESET);”导致异常复位,而如果不采用硬件控制NSS信号输出(即不定义宏SPI3_NSS_HARD)则都不会有此问题。到底是我的代码有bug还是在运行SPI_Cmd(SPI3, ENABLE)使能SPI后到SPI正常工作有延迟。请高人指教。
香水城 发表于 2019-6-13 22:09 | 显示全部楼层
         #else
你红色这句什么意思?要关闭SPI?
dongnanxibei 发表于 2019-6-14 00:23 | 显示全部楼层
楼主自己搞错了
 楼主| shipeng1989 发表于 2019-6-14 08:51 | 显示全部楼层
         SPI_Cmd(SPI3, DISABLE); ...
是这样的:如果配置为硬件控制NSS信号输出,则只要SPI使能NSS引脚即输出低电平,要让NSS输出高电平只有关闭SPI,不信大家可以去看一下手册。
kxsi 发表于 2019-6-19 11:30 | 显示全部楼层
因为控制信号没有过来呢把
labasi 发表于 2019-7-5 11:04 | 显示全部楼层
我极少用到这个引脚
wakayi 发表于 2019-7-5 11:34 | 显示全部楼层
程序好像有些问题
