- /* Copyright(c) 2019 Nuvoton Technology Corp. All rights reserved. */
- // Website: http://www.nuvoton.com
- // E-Mail : MicroC-8bit@nuvoton.com
- // File Function: ML51 simple GPIO toggle out demo code
- #include "ML51.h"
- * @brief ACMP interrupt subroutine
- * @param None
- * @return None
- * @details None
- void ACMP_ISR (void) interrupt 23
- if ((ACMPSR&SET_BIT2)==SET_BIT2)
- ACMPSR&=CLR_BIT2;
- SFRS = 0x00;
- P13 ^=1;
- else if ((ACMPSR&SET_BIT0)==SET_BIT0)
- ACMPSR&=CLR_BIT0;
- SFRS = 0x00;
- P14 ^=1;
- * @brief ACMP negtive input use Bandgap voltage main loop
- * @param None
- * @return None
- * @details None
- void main (void)
- /* Setting Multi function pin setting for GPIO toggle
- * include gipo.c in Common for GPIO mode setting
- */ MFP_P13_GPIO;
- P13_QUASI_MODE;
- MFP_P23_ACMP0_P1;
- MFP_P24_ACMP0_N0;
- MFP_P41_ACMP0_O;
- /* ACMP intial
- * include acmp.c in Library for ACMP initial and interrupt setting.
- // Initial ACMP0 P2.3 as positive and Bandgap as negetive input, Output to P4.1
- ACMP_Open(ACMP0, ACMP_CTL_POSSEL_P1, ACMP_CTL_NEGSEL_PIN_N0,0, ACMP_CTL_ACMP0_OUTPUT_ENABLE, ACMP_CTL_HYSTERESIS_ENABLE);
- /* Initial ACMP interrupt enable, wakeup function disable.*/
- ACMP_INTEnable(ACMP0, ACMP_CTL_WAKEUP_ENABLE, ACMP_CTL_INT_ENABLE);
- /*To use interrupt function, must enable blobal interrupt after all setting.*/
- ENABLE_GLOBAL_INTERRUPT;
- while (1)
- set_PCON_PD;
- Timer3_Delay(24000000,128,100,10000);
