IAR FOR MSP430 用USB仿真器出现编译问题?内容如下:
5142|0
 楼主| tiger5z 发表于 2011-11-17 11:37 | 显示全部楼层 |阅读模式
Error[e104]: Failed to fit all segments into specified ranges. Problem discovered in segment CODE.
Unable to place 62 block(s) (0x1fc8 byte(s) total) in 0x1dec byte(s) of memory. The problem occurred
while processing the segment placement command "-P(CODE)CODE=E000-FF7F", where at the moment of
placement the available memory  ranges were "CODE:e194-ff7f"
可以肯定的是程序在低版本下没有问题,低版本下用的并口仿真器,版本号2.31C,芯片用的是MSP430F149,空间在低版本下查看还剩大把。用USB仿真器下IAR版本用的5.20,编译时出现上面的问题,这是什么原因?谢谢!
