[STM32H7] STM32H743的SPI使用DMA方式遇到的奇怪问题
6309|14
 楼主| nch1766 发表于 2019-9-6 17:42 | 显示全部楼层 |阅读模式
      不使用DMA方式的时候SPI可以正常读写到数据,使用了DMA方式后,第一包数据会正常发送/接收,从第二包数据开始,就无法中断了,在外部的引脚上也测量不到电平变化;
      如果将DMA模式由DMA_NORMAL改成DMA_CIRCULAR的话,引脚上就能看到波形了,但是目前外接的器件是SPI Flash,所以没办法用循环模式,现在也不知道问题出在哪里了,目前使用的HAL库已经更新到最新的V1.5版本了,还是不行;
     目前已经在这个问题上卡住快半个月了,有没有哪位大神路过救救我啊~~~~
void spiFlashPinConfig(void)
    GPIO_InitTypeDef gpioInit;
        __HAL_RCC_GPIOG_CLK_ENABLE();                   //使能GPIOJ时钟
    __HAL_RCC_GPIOC_CLK_ENABLE();                   //使能GPIOC时钟
    __HAL_RCC_GPIOB_CLK_ENABLE();                   //使能GPIOB时钟
    __HAL_RCC_GPIOA_CLK_ENABLE();                   //使能GPIOA时钟
        //初始化SPI时钟
    __HAL_RCC_SPI1_CLK_ENABLE();
    //SCK=PG11,  MISO=PG9
    gpioInit.Pin = GPIO_PIN_11 | GPIO_PIN_9;
    gpioInit.Speed = GPIO_SPEED_FREQ_HIGH;
    gpioInit.Pull = GPIO_PULLDOWN;
    gpioInit.Alternate = 5;
    gpioInit.Mode = GPIO_MODE_AF_PP;
    HAL_GPIO_Init(GPIOG,&gpioInit);
    //MOSI=PB5
    gpioInit.Pin = GPIO_PIN_5;
    HAL_GPIO_Init(GPIOB,&gpioInit);
    //NSS=PA15
    gpioInit.Mode = GPIO_MODE_OUTPUT_PP;
    gpioInit.Pin = GPIO_PIN_15;
    HAL_GPIO_Init(GPIOA,&gpioInit);
    gpioInit.Pin = SPI_FLASH_RST_Pin;
    HAL_GPIO_Init(GPIOC,&gpioInit);
    HAL_GPIO_WritePin(GPIOC, SPI_FLASH_RST_Pin, GPIO_PIN_RESET);
    sleep(100);
    HAL_GPIO_WritePin(GPIOC, SPI_FLASH_RST_Pin, GPIO_PIN_SET);
void HAL_SPI_MspInit(SPI_HandleTypeDef *hspi)
    if (hspi->Instance == SPI_PORT)
        __HAL_RCC_DMA2_CLK_ENABLE();//DMA2时钟使能
        spiFlashPinConfig();
        /* Configure the DMA handler for Transmission process */
        dma_TxHandler.Instance                 = SPIx_TX_DMA_STREAM;
        dma_TxHandler.Init.FIFOMode            = DMA_FIFOMODE_DISABLE;
        dma_TxHandler.Init.FIFOThreshold       = DMA_FIFO_THRESHOLD_FULL;
        dma_TxHandler.Init.MemBurst            = DMA_MBURST_SINGLE;
        dma_TxHandler.Init.PeriphBurst         = DMA_MBURST_SINGLE;
        dma_TxHandler.Init.Request             = SPIx_TX_DMA_REQUEST;
        dma_TxHandler.Init.Direction           = DMA_MEMORY_TO_PERIPH;
        dma_TxHandler.Init.PeriphInc           = DMA_PINC_DISABLE;
        dma_TxHandler.Init.MemInc              = DMA_MINC_ENABLE;
        dma_TxHandler.Init.PeriphDataAlignment = DMA_PDATAALIGN_BYTE;
        dma_TxHandler.Init.MemDataAlignment    = DMA_MDATAALIGN_BYTE;
        dma_TxHandler.Init.Mode                = DMA_NORMAL;//DMA_CIRCULAR;//DMA_NORMAL;
        dma_TxHandler.Init.Priority            = DMA_PRIORITY_LOW;
        HAL_DMA_Init(&dma_TxHandler);
        /* Associate the initialized DMA handle to the the SPI handle */
        __HAL_LINKDMA(hspi, hdmatx, dma_TxHandler);
        dma_RxHandler.Instance                 = SPIx_RX_DMA_STREAM;
        dma_RxHandler.Init.FIFOMode            = DMA_FIFOMODE_DISABLE;
        dma_RxHandler.Init.FIFOThreshold       = DMA_FIFO_THRESHOLD_FULL;
        dma_RxHandler.Init.MemBurst            = DMA_MBURST_SINGLE;
        dma_RxHandler.Init.PeriphBurst         = DMA_MBURST_SINGLE;
        dma_RxHandler.Init.Request             = SPIx_RX_DMA_REQUEST;
        dma_RxHandler.Init.Direction           = DMA_PERIPH_TO_MEMORY;
        dma_RxHandler.Init.PeriphInc           = DMA_PINC_DISABLE;
        dma_RxHandler.Init.MemInc              = DMA_MINC_ENABLE;
        dma_RxHandler.Init.PeriphDataAlignment = DMA_PDATAALIGN_BYTE;
        dma_RxHandler.Init.MemDataAlignment    = DMA_MDATAALIGN_BYTE;
        dma_RxHandler.Init.Mode                = DMA_NORMAL;//DMA_CIRCULAR;//DMA_NORMAL;
        dma_RxHandler.Init.Priority            = DMA_PRIORITY_HIGH;
        HAL_DMA_Init(&dma_RxHandler);
        __HAL_LINKDMA(hspi, hdmarx, dma_RxHandler);
        /* NVIC configuration for DMA transfer complete interrupt (SPI1_TX) */
        HAL_NVIC_SetPriority(SPIx_DMA_TX_IRQn, 1, 1);
        HAL_NVIC_EnableIRQ(SPIx_DMA_TX_IRQn);
        /* NVIC configuration for DMA transfer complete interrupt (SPI1_RX) */
        HAL_NVIC_SetPriority(SPIx_DMA_RX_IRQn, 1, 0);
        HAL_NVIC_EnableIRQ(SPIx_DMA_RX_IRQn);
void spiFlashInit( )
        // SPI配置
        ETH_SPI_CS_HIGH;
    spiHandle.Instance = SPI_PORT;                //SP1
    spiHandle.Init.Mode = SPI_MODE_MASTER;          //设置SPI工作模式,设置为主模式
    spiHandle.Init.Direction = (0x0U << SPI_CFG2_COMM_Pos);//SPI_DIRECTION_2LINES_TXONLY;//SPI_DIRECTION_2LINES;//设置SPI单向或者双向的数据模式:SPI设置为双线模式
    spiHandle.Init.DataSize = SPI_DATASIZE_8BIT;    //设置SPI的数据大小:SPI发送接收8位帧结构
    spiHandle.Init.CLKPolarity = SPI_POLARITY_LOW; //串行同步时钟的空闲状态为低电平 电路中下拉
    spiHandle.Init.CLKPhase = SPI_PHASE_1EDGE;      //串行同步时钟的第二个跳变沿(上升或下降)数据被采样
    spiHandle.Init.NSS = SPI_NSS_SOFT;       //NSS信号由软件管理
    spiHandle.Init.NSSPMode = SPI_NSS_PULSE_DISABLE;//NSS信号脉冲失能
    spiHandle.Init.IOSwap = SPI_IO_SWAP_DISABLE;//SPI_IO_SWAP_ENABLE;
    spiHandle.Init.NSSPolarity = SPI_NSS_POLARITY_LOW;
    spiHandle.Init.MasterInterDataIdleness = SPI_MASTER_SS_IDLENESS_02CYCLE;
    spiHandle.Init.MasterKeepIOState = SPI_MASTER_KEEP_IO_STATE_ENABLE;  //SPI主模式IO状态保持使能
    spiHandle.Init.BaudRatePrescaler = SPI_BAUDRATEPRESCALER_256;//定义波特率预分频的值:波特率预分频值为16
    spiHandle.Init.FirstBit = SPI_FIRSTBIT_MSB;     //指定数据传输从MSB位还是LSB位开始:数据传输从MSB位开始
    spiHandle.Init.TIMode = SPI_TIMODE_DISABLE;     //关闭TI模式
    spiHandle.Init.CRCCalculation = SPI_CRCCALCULATION_DISABLE;//关闭硬件CRC校验
    spiHandle.Init.CRCPolynomial = 7;               //CRC值计算的多项式
    HAL_SPI_Init(&spiHandle);
    __HAL_SPI_ENABLE(&spiHandle);
    memset(spiFlashRxBuffer, 0, SPI_FLASH_BUF_LEN);
    memset(spiFlashTxBuffer, 0, SPI_FLASH_BUF_LEN);
香水城 发表于 2019-9-9 09:42 | 显示全部楼层
你说的第一包数据具体有多少个? 发完第一包数据后应该是什么操作?
 楼主| nch1766 发表于 2019-9-9 12:30 | 显示全部楼层
第一包数据目前我试过发送一个自己,到十个字节都是有波形的;
发送/接收完成后进入DMA发送/接收中断,目前是等待5ms,在中断服务程序中并清除发送/接收完成标志位,然后拷贝数据到另外一个缓存空间,加上上面的代码就是所有的了,请问有什么建议么?
static void spiWRFlashDataDma(uint16_t len)
    spiHandle.State = HAL_SPI_STATE_READY;
    spiHandle.hdmarx->State = HAL_DMA_STATE_READY;
    spiHandle.hdmatx->State = HAL_DMA_STATE_READY;
    __HAL_UNLOCK(spiHandle.hdmarx);
    __HAL_UNLOCK(spiHandle.hdmatx);
    HAL_SPI_TransmitReceive_DMA(&spiHandle, spiFlashTxBuffer, spiFlashRxBuffer, len);
void DMA1_Stream3_IRQHandler(void)    //发送完成DMA
    uint32_t isrFlag = 0;
    asm("nop");
    isrFlag = __HAL_DMA_GET_FLAG(&dma_TxHandler, (0x3F << 24));
    if((isrFlag & DMA_FLAG_TCIF3_7) != RESET)//DMA传输完成
        //清除DMA传输完成中断标志位
        __HAL_DMA_CLEAR_FLAG(&dma_TxHandler, DMA_FLAG_TCIF3_7);
        isrFlag &= ~DMA_FLAG_TCIF3_7;
    if(isrFlag != RESET)//如果还有其他DMA传输错误
        __HAL_DMA_CLEAR_FLAG(&dma_TxHandler, isrFlag);//清除传输错误中断标志位
    CLEAR_BIT(SPI_PORT->CFG1, SPI_CFG1_TXDMAEN);
void DMA1_Stream4_IRQHandler(void)   //接收完成DMA
    asm("nop");
    isrFlag = __HAL_DMA_GET_FLAG(&dma_RxHandler, (0x3F << 0));
    if((isrFlag & DMA_FLAG_TCIF0_4) != RESET)//DMA传输完成
        __HAL_DMA_CLEAR_FLAG(&dma_RxHandler, DMA_FLAG_TCIF0_4);//清除DMA传输完成中断标志位
        isrFlag &= ~DMA_FLAG_TCIF0_4;
        __HAL_DMA_CLEAR_FLAG(&dma_RxHandler, isrFlag);//清除传输错误中断标志位
    CLEAR_BIT(SPI_PORT->CFG1, SPI_CFG1_RXDMAEN);
uint8_t spiReadFlashSR(void)
    spiFlashTxBuffer[0] = FLASH_CMD_READ_SR1;
    ETH_SPI_CS_LOW;                            //使能器件
    spiWRFlashDataDma(1);         //发送读取状态寄存器命令
    sleep(5);
    spiFlashTxBuffer[0] = 0xFF;
    spiWRFlashDataDma(1);          //读取一个字节
    sleep(5);
    ETH_SPI_CS_HIGH;
    return spiFlashRxBuffer[0];
香水城 发表于 2019-9-23 12:03 | 显示全部楼层
我这边使用相同的开发板,分别就几个SPI都做了测试,使用DMA传输,
不论是循环还是非循环模式,都可以正常运行。
buffered 发表于 2019-9-24 15:12 | 显示全部楼层
还是DMA的配置没有弄好吧应该
coshi 发表于 2019-10-12 11:57 | 显示全部楼层
换成普通模式呢
磨砂 发表于 2019-10-12 12:36 | 显示全部楼层
是不是配置的问题
aoyi 发表于 2019-10-13 08:35 | 显示全部楼层
不太用过dma
drer 发表于 2019-10-13 09:05 | 显示全部楼层
帮楼主顶一下吧
kxsi 发表于 2019-10-13 10:25 | 显示全部楼层
我一般就用普通模式就够用了
方孔恩 发表于 2020-5-6 16:30 | 显示全部楼层
不论是循环还是非循环模式,都可以正常 ...
兄台,能不能看下我的spi传输的代码,我的dma传输一直收不到数据,请看看有什么问题,谢谢了
  1. void HAL_SPI_MspInit(SPI_HandleTypeDef *hspi)
  3.           GPIO_InitTypeDef GPIO_Initure;
  4.     RCC_PeriphCLKInitTypeDef SPI2ClkInit;
  5.
  6.           __HAL_RCC_SPI2_CLK_ENABLE();                    //使能SPI2时钟
  7.                 __HAL_RCC_GPIOB_CLK_ENABLE();
  8.                 __HAL_RCC_GPIOF_CLK_ENABLE();        //使能GPIOF时钟
  9.                 SPI2ClkInit.PeriphClockSelection=RCC_PERIPHCLK_SPI2;
  10.                 SPI2ClkInit.Spi123ClockSelection=RCC_SPI123CLKSOURCE_PLL;
  11.                 HAL_RCCEx_PeriphCLKConfig(&SPI2ClkInit);
  12.                 __HAL_RCC_DMA1_CLK_ENABLE();
  13.     //PB13,15 (SCK|MISO|MOSI)
  14.     GPIO_Initure.Pin=GPIO_PIN_13|GPIO_PIN_14|GPIO_PIN_15;
  15.     GPIO_Initure.Mode=GPIO_MODE_AF_PP;              //复用推挽输出
  16.     GPIO_Initure.Pull=GPIO_PULLUP;                  //上拉
  17.     GPIO_Initure.Speed=GPIO_SPEED_FREQ_VERY_HIGH;   //快速
  18.     GPIO_Initure.Alternate=GPIO_AF5_SPI2;           //复用为SPI2
  19.     HAL_GPIO_Init(GPIOB,&GPIO_Initure);             //初始化
  20.
  21.                 //PB9(NSS引脚,用作其他)
  22.                 GPIO_Initure.Pin=GPIO_PIN_9;
  23.           GPIO_Initure.Mode=GPIO_MODE_OUTPUT_PP;  //推挽输出
  24.     GPIO_Initure.Pull=GPIO_PULLUP;          //上拉
  25.     GPIO_Initure.Speed=GPIO_SPEED_FREQ_VERY_HIGH;     //高速
  26.                 HAL_GPIO_Init(GPIOB,&GPIO_Initure);
  27.
  28.                 //W25Q256片选信号拉高,防止W25Q256干扰
  29.                 GPIO_Initure.Pin=GPIO_PIN_10;                         //PF10
  30.                 HAL_GPIO_Init(GPIOF,&GPIO_Initure);     //初始化
  31.
  32.
  33.           /*##-3- Configure the DMA ##################################################*/
  34.     /* Configure the DMA handler for Transmission process */
  35.     hdma_tx.Instance                 = SPIx_TX_DMA_STREAM;
  36.                 hdma_tx.Init.Request             = SPIx_TX_DMA_REQUEST;
  37.     hdma_tx.Init.FIFOMode            = DMA_FIFOMODE_DISABLE;
  38.     hdma_tx.Init.FIFOThreshold       = DMA_FIFO_THRESHOLD_FULL;
  39. //    hdma_tx.Init.MemBurst            = DMA_MBURST_INC4;
  40. //    hdma_tx.Init.PeriphBurst         = DMA_PBURST_INC4;
  41.     hdma_tx.Init.Direction           = DMA_MEMORY_TO_PERIPH;
  42.     hdma_tx.Init.PeriphInc           = DMA_PINC_DISABLE;
  43.     hdma_tx.Init.MemInc              = DMA_MINC_ENABLE;
  44.     hdma_tx.Init.PeriphDataAlignment = DMA_PDATAALIGN_BYTE;
  45.     hdma_tx.Init.MemDataAlignment    = DMA_MDATAALIGN_BYTE;
  46.     hdma_tx.Init.Mode                = DMA_CIRCULAR;
  47.     hdma_tx.Init.Priority            = DMA_PRIORITY_HIGH;
  48.     HAL_DMA_Init(&hdma_tx);
  49.     /* Associate the initialized DMA handle to the the SPI handle */
  50.     __HAL_LINKDMA(hspi, hdmatx, hdma_tx);
  51.     /* Configure the DMA handler for Transmission process */
  52.     hdma_rx.Instance                 = SPIx_RX_DMA_STREAM;
  53.     hdma_rx.Init.Request             = SPIx_RX_DMA_REQUEST;
  54.     hdma_rx.Init.FIFOMode            = DMA_FIFOMODE_DISABLE;
  55.     hdma_rx.Init.FIFOThreshold       = DMA_FIFO_THRESHOLD_FULL;
  56. //    hdma_rx.Init.MemBurst            = DMA_MBURST_INC4;
  57. //    hdma_rx.Init.PeriphBurst         = DMA_PBURST_INC4;
  58.     hdma_rx.Init.Direction           = DMA_PERIPH_TO_MEMORY;
  59.     hdma_rx.Init.PeriphInc           = DMA_PINC_DISABLE;
  60.     hdma_rx.Init.MemInc              = DMA_MINC_ENABLE;
  61.     hdma_rx.Init.PeriphDataAlignment = DMA_PDATAALIGN_BYTE;
  62.     hdma_rx.Init.MemDataAlignment    = DMA_MDATAALIGN_BYTE;
  63.     hdma_rx.Init.Mode                = DMA_CIRCULAR;
  64.     hdma_rx.Init.Priority            = DMA_PRIORITY_HIGH;
  65.     HAL_DMA_Init(&hdma_rx);
  66.     /* Associate the initialized DMA handle to the the SPI handle */
  67.     __HAL_LINKDMA(hspi, hdmarx, hdma_rx);
  68.
  69.     /*##-4- Configure the NVIC for DMA #########################################*/
  70.     /* NVIC configuration for DMA transfer complete interrupt (SPI1_TX) */
  71.     HAL_NVIC_SetPriority(SPIx_DMA_TX_IRQn, 1, 1);
  72.     HAL_NVIC_DisableIRQ(SPIx_DMA_TX_IRQn);
  73.
  74.     /* NVIC configuration for DMA transfer complete interrupt (SPI1_RX) */
  75.     HAL_NVIC_SetPriority(SPIx_DMA_RX_IRQn, 1, 0);
  76.     HAL_NVIC_EnableIRQ(SPIx_DMA_RX_IRQn);
  77. }
  1. void SPI2_Init(void)
  3.     SPI2_Handler.Instance=SPI2;                      //SP2
  4.     SPI2_Handler.Init.Mode=SPI_MODE_MASTER ;         //设置SPI工作模式,设置为主模式
  5.     SPI2_Handler.Init.Direction=SPI_DIRECTION_2LINES;//设置SPI单向或者双向的数据模式:SPI设置为双线模式
  6.     SPI2_Handler.Init.DataSize=SPI_DATASIZE_8BIT;    //设置SPI的数据大小:SPI发送接收8位帧结构
  7.     SPI2_Handler.Init.CLKPolarity=SPI_POLARITY_LOW; //串行同步时钟的空闲状态为低电平
  8.     SPI2_Handler.Init.CLKPhase=SPI_PHASE_1EDGE;      //串行同步时钟的第1个跳变沿(此处指上升沿)数据被采样
  9.
  10.     SPI2_Handler.Init.NSS=SPI_NSS_SOFT;              //NSS信号由硬件(NSS管脚)还是软件(使用SSI位)管理:内部NSS信号有SSI位控制,主模式SSI必须置位1
  11.     SPI2_Handler.Init.NSSPMode=SPI_NSS_PULSE_DISABLE;//NSS输出信号脉冲失能,配置成主模式才有用,目的是让ns引脚成为普通IO
  12.                 SPI2_Handler.Init.NSSPolarity=SPI_NSS_POLARITY_LOW;
  13.
  14.                 //SPI2_Handler.Init.MasterInterDataIdleness=SPI_MASTER_SS_IDLENESS_15CYCLE;
  15.                 //SPI2_Handler.Init.s = SPI_MASTER_SS_IDLENESS_04CYCLE;
  16.
  17.
  18.     SPI2_Handler.Init.MasterKeepIOState=SPI_MASTER_KEEP_IO_STATE_ENABLE;  //SPI主模式IO状态保持使能
  19.     SPI2_Handler.Init.BaudRatePrescaler=SPI_BAUDRATEPRESCALER_16;//定义波特率预分频的值:波特率预分频值为16
  20.     SPI2_Handler.Init.FirstBit=SPI_FIRSTBIT_MSB;     //指定数据传输从MSB位还是LSB位开始:数据传输从MSB位开始
  21.     SPI2_Handler.Init.TIMode=SPI_TIMODE_DISABLE;     //关闭TI模式
  22.     SPI2_Handler.Init.CRCCalculation=SPI_CRCCALCULATION_DISABLE;//关闭硬件CRC校验
  23.     SPI2_Handler.Init.CRCPolynomial=7;               //CRC值计算的多项式
  24.                 if (HAL_SPI_DeInit(&SPI2_Handler) != HAL_OK)
  25.                 {
  26.                         printf("error\t\n");
  27.                 }
  28.   if(HAL_SPI_Init(&SPI2_Handler) != HAL_OK)
  29.   {
  30.     /* Initialization Error */
  31.     printf("error\t\n");
  32.         }
  33.         __HAL_SPI_ENABLE(&SPI2_Handler);
  34.          SPI2_ReadWriteByte(0Xff);                        //启动传输
  35. }
在主程序中,
  1. if(HAL_SPI_TransmitReceive_DMA(&SPI2_Handler, (uint8_t *)SpiTxBuffer, (uint8_t *)SpiRxBuffer, BUFFERSIZE) != HAL_OK)
  2.         {
  3.                         printf("error\t\n");
  4.         }
  5.         //printf("");
  6.         while(1)
  7.         {
  8.         }
而且又设置了
  1. void HAL_SPI_TxRxCpltCallback(SPI_HandleTypeDef *hspi)
  3.         SCB_InvalidateDCache_by_Addr ((uint32_t *)SpiRxBuffer, BUFFERSIZE);
  4.
  5.         printf("Received: %s \t\n", SpiRxBuffer);
  6.
  7.         //HAL_SPI_DMAStop(&SPI2_Handler);
  8. }
但是进入中断接收时,一直为空,这是什么原因呢?
香水城 发表于 2020-5-7 15:55 | 显示全部楼层
你注意下 数据缓冲区 是否是你配置的DMA可以到达的地方。
基于STM32H7 DMA传输的SPI 应用示例
方孔恩 发表于 2020-5-9 11:17 | 显示全部楼层
多谢兄弟,这个我看了,我自己用库函数写的spi—dma的代码,主机的miso和mosi相连,是可以接收到自己发的数据的,但是正常连接之后,在从机上面就收不到主机发的东西了,一直为0,我从机的代码跟主机没有多少区别的,在之前的spi中断方式试可以实现的,但是不知道这个为啥不能
香水城 发表于 2020-7-5 22:37 | 显示全部楼层
多谢兄弟,这个我看了,我自己用库函数写的spi—dma的代码,主机的miso和mosi相连,是可以接收到自己发的 ...
方小弟,你的这个问题还没解决吗? 我看你是2019年9月发的贴了。
lemonwind 发表于 2020-9-24 06:42 | 显示全部楼层
我也碰到相同的问题了,请问楼主解决了吗?
