GD32VF103C-START开发板,编译后下载的时候报这个错误,什么原因?
3959|7
 楼主| Andy1978 发表于 2019-9-21 21:27 | 显示全部楼层 |阅读模式
Error in final launch sequence
Failed to execute MI command:
-target-select remote localhost:3333
Error message from debugger back end:
bfd requires xlen 8, but target has xlen 4
zoomdy 发表于 2019-9-25 17:27 | 显示全部楼层
set arch riscv:rv32
zoomdy 发表于 2019-9-25 17:28 | 显示全部楼层
kaiw 发表于 2020-8-12 09:06 | 显示全部楼层
(gdb) set arch riscv:rv32
warning: A handler for the OS ABI "GNU/Linux" is not built into this configuration
of GDB.  Attempting to continue with the default riscv:rv32 settings.
The target architecture is assumed to be riscv:rv32
(gdb) target remote localhost:3333
Remote debugging using localhost:3333
(gdb)
您好!gdb调试出现这样的问题怎么解决呢?
“set arch riscv:rv32”命令执行完以后,还是显示“bfd requires xlen 8, but target has xlen 4”。
谢谢老师!!!
(gdb)
谢谢老师!!!
xdqfc 发表于 2020-8-12 10:08 | 显示全部楼层
假如是编译没有问题,而仿真下载有问题,两个文件需要注意一下,一个是芯片型号选择,好像是ELF,我记不清楚了,还有就是编译后产出的仿真文件,什么结尾的的我记不得了,请看一下官方的说明书,两个文件的定位千万不要玩错了。
wdliming 发表于 2020-8-19 09:04 | 显示全部楼层
mxzwish 发表于 2021-1-8 20:40 | 显示全部楼层
warning: A handler for the OS ABI "GNU/Linux" is not built into this con ...
你这个gdb版本可能有问题没能支持riscv:rv32
你应该用芯来科技下载频道里的toolchain里面的gdb
