- import ddf.minim.*;
- import ddf.minim.analysis.*;
- import processing.serial.*;
- import cc.arduino.*;
- Arduino arduino;
- Minim minim;
- AudioPlayer song;
- FFT fft;
- int redPin1 = 0;
- int greenPin1 = 1;
- int bluePin1 = 2;
- int redPin2 = 3;
- int greenPin2 = 5;
- int bluePin2 = 6;
- int redPin3 = 9;
- int greenPin3 = 11;
- int bluePin3 = 12;
- int LED_PINS[] = {redPin1,greenPin1,bluePin1,redPin2,greenPin2,bluePin2,redPin3,greenPin3,bluePin3};
- int color_id = 0;
- int common_cathode = 0;
- void setup() {
- size(800, 600);
- arduino = new Arduino(this, "COM7", 57600);
- for (int i = 0; i <= 8; i++) arduino.pinMode(LED_PINS[i], Arduino.PWM);
- for (int i = 0; i <= 8; i++) arduino.analogWrite(LED_PINS[i],255);
- minim = new Minim(this);
- song = minim.loadFile("badapple.mp3");
- song.play();
- fft = new FFT(song.bufferSize(), song.sampleRate());
- void draw() {
- background(#151515);
- fft.forward(song.mix);
- strokeWeight(1.3);
- stroke(#FFF700);
- // frequency
- pushMatrix();
- translate(250, 0);
- for(int i = 0; i < 0+fft.specSize(); i++) {
- line(i, height*4/5, i, height*4/5 - fft.getBand(i)*4);
- if(i%100==0) text(fft.getBand(i), i, height*4/5+20);
- if(i==200) {
- if(fft.getBand(i)>2) {
- setColor1(255,255,0);
- setColor3(255,255,0);
- else if(fft.getBand(i)>1) {
- setColor1(255,0,255);
- setColor3(255,0,255);
- } else {
- setColor1(255,255,255);
- setColor3(255,255,255);
- if(i==50) {
- if(fft.getBand(i)>5) {
- color_id = (color_id+1)%4;
- } else if(fft.getBand(i)>3) {
- if(color_id==0) setColor2(0,255,0);
- else if(color_id==1) setColor2(0,255,255);
- else if(color_id==2) setColor2(0,0,255);
- else setColor2(255,0,0);
- else {
- setColor2(255,255,255);
- popMatrix();
- stroke(#FF0000);
- //waveform
- for(int i = 250; i < song.left.size() - 1; i++) {
- line(i, 50 + song.left.get(i)*50, i+1, 50 + song.left.get(i+1)*50);
- line(i, 150 + song.right.get(i)*50, i+1, 150 + song.right.get(i+1)*50);
- line(i, 250 + song.mix.get(i)*50, i+1, 250 + song.mix.get(i+1)*50);
- noStroke();
- fill(#111111);
- rect(0, 0, 250, height);
- textSize(24);
- fill(#046700);
- text("left amplitude", 10, 50);
- text("right amplitude", 10, 150);
- text("mixed amplitude", 10, 250);
- text("frequency", 10, height*4/5);
- void stop()
- for (int i = 0; i <= 13; i++) arduino.digitalWrite(i,arduino.HIGH);
- song.close();
- minim.stop();
- super.stop();
- void setColor1(int red, int green, int blue)
- if(common_cathode==1) {
- red = 255-red;
- green = 255-green;
- blue = 255-blue;
- arduino.analogWrite(redPin1, red);
- arduino.analogWrite(greenPin1, green);
- arduino.analogWrite(bluePin1, blue);
- void setColor2(int red, int green, int blue)
- red = 255-red;
- blue = 255-blue;
- arduino.analogWrite(redPin2, red);
- arduino.analogWrite(greenPin2, green);
- arduino.analogWrite(bluePin2, blue);
- void setColor3(int red, int green, int blue)
- red = 255-red;
- blue = 255-blue;
- arduino.analogWrite(redPin3, red);
- arduino.analogWrite(greenPin3, green);
- arduino.analogWrite(bluePin3, blue);
这里需要注意的是,需要在Processing程序里面更改你的板子对应COM口,和你需要播放的音乐名(和sketch同一级目录)。
完整程序如下:(请至零知官网查看同名原帖)
3、测试验证
在我们连接好零知板与LED等的连线并上传好程序后,我们再打开Processing程序并运行,就可以看到播放音乐的时候炫酷的LED灯光效果了。
查看完整效果视频: http://www.lingzhilab.com/forum.php?mod=redirect&goto=findpost&ptid=1074&pid=5052&fromuid=3010
