- * @file main.c
- * @version V1.00
- * $Revision: 3 $
- * $Date: 13/10/07 3:54p $
- * @brief Timer sample for Mini51 series MCU
- * @note
- * Copyright (C) 2013 Nuvoton Technology Corp. All rights reserved.
- #include <stdio.h>
- #include "Mini51Series.h"
- uint32_t TCAP0_old;
- void TMR0_IRQHandler(void)
- uint32_t TCAP0_tmp = TIMER0->TCAP;
- printf("%d\n\r",(12000000/(TCAP0_tmp*2))*60);
- if(TCAP0_tmp==0)
- printf("cap:0\n\r");
- if(TCAP0_old!=TCAP0_tmp)
- printf("%d\n\r",TCAP0_tmp-TCAP0_old);
- TCAP0_old=TCAP0_tmp;
- TIMER0->TEXISR = TIMER_TEXISR_TEXIF_Msk;
- void SYS_Init(void)
- /* Init System Clock */
- /* Unlock protected registers */
- while(SYS->RegLockAddr != 1) {
- SYS->RegLockAddr = 0x59;
- SYS->RegLockAddr = 0x16;
- SYS->RegLockAddr = 0x88;
- SYS->P5_MFP=0X03;
- /* Enable external 12MHz XTAL (UART), and internal 22.1184MHz */
- CLK->PWRCON = CLK_PWRCON_XTL12M | CLK_PWRCON_IRC22M_EN_Msk;
- /* Waiting for clock ready */
- while((CLK->CLKSTATUS & (CLK_CLKSTATUS_IRC22M_STB_Msk |CLK_CLKSTATUS_XTL_STB_Msk)) !=
- (CLK_CLKSTATUS_IRC22M_STB_Msk |CLK_CLKSTATUS_XTL_STB_Msk));
- /* Enable UART and Timer 0 clock */
- CLK->APBCLK = CLK_APBCLK_UART_EN_Msk | CLK_APBCLK_TMR0_EN_Msk;
- /* Select Timer 0 clock source from external crystal*/
- CLK->CLKSEL1 = (CLK->CLKSEL1 & ~CLK_CLKSEL1_TMR0_S_Msk) | CLK_CLKSEL1_TMR0_S_XTAL;
- /* Update System Core Clock */
- /* User can use SystemCoreClockUpdate() to calculate SystemCoreClock and CycylesPerUs automatically. */
- SystemCoreClockUpdate();
- /* Init I/O Multi-function */
- /* Set P1 multi-function pins for UART RXD, TXD */
- SYS->P0_MFP = SYS_MFP_P00_TXD | SYS_MFP_P01_RXD;
- /* Set P3 multi function pin for Timer 0 capture pin */
- SYS->P3_MFP = SYS_MFP_P32_T0EX;
- /* Lock protected registers */
- SYS->RegLockAddr = 0;
- void UART_Init(void)
- // Set UART to 8 bit character length, 1 stop bit, and no parity
- UART->LCR = UART_LCR_WLS_Msk;
- // 22.1184 MHz reference clock input, for 115200 bps
- // 22118400 / 115200 = 192. Using mode 2 to calculate baudrate, 192 - 2 = 190 = 0xBE
- UART->BAUD = UART_BAUD_DIV_X_EN_Msk | UART_BAUD_DIV_X_ONE_Msk | (0xBE);
- int main(void)
- int volatile i;
- /* Init System, IP clock and multi-function I/O
- In the end of SYS_Init() will issue SYS_LockReg()
- to lock protected register. If user want to write
- protected register, please issue SYS_UnlockReg()
- to unlock protected register if necessary */
- SYS_Init();
- /* Init UART to 115200-8n1 for print message */
- UART_Init();
- printf("\nThis sample code demonstrat timer trigger counting mode.\n");
- printf("Please connect input source with Timer 0 capture pin T0EX (P3.2), press any key to continue\n");
- //getchar();
- TIMER0->TCSR = TIMER_TCSR_CEN_Msk | TIMER_TCSR_TDR_EN_Msk|TIMER_CONTINUOUS_MODE | 0;
- // Set compare value as large as possible
- TIMER0->TCMPR = 0xFFFFFF;
- // Configure Timer 0 trigger counting mode, capture TDR value on falling edge, enable capture interrupt
- TIMER0->TEXCON = TIMER_TEXCON_CAP_MODE_Msk|
- TIMER_CAPTURE_TRIGGER_COUNTING_MODE |
- TIMER_CAPTURE_FALLING_EDGE |
- TIMER_TEXCON_TEXIEN_Msk |
- TIMER_TEXCON_TEXEN_Msk|
- TIMER_TEXCON_TEXDB_Msk;
- NVIC_EnableIRQ(TMR0_IRQn);
- while(1);
- /*** (C) COPYRIGHT 2013 Nuvoton Technology Corp. ***/
