[MCU] load program时出错应该怎么解决
640|17
 楼主| heweibig 发表于 2019-10-20 14:30 | 显示全部楼层 |阅读模式
显示data verification failed at address 0x3fffc0
wuhany 发表于 2019-10-20 14:34 | 显示全部楼层
什么板子啊
 楼主| heweibig 发表于 2019-10-20 14:39 | 显示全部楼层
我的是2812的板子,仿真器是XDS510PLUS
jiahy 发表于 2019-10-20 14:43 | 显示全部楼层
是不是连接有问题啊
 楼主| heweibig 发表于 2019-10-20 14:47 | 显示全部楼层
连接没问题
lizye 发表于 2019-10-20 14:50 | 显示全部楼层
你做什么东西来着呢
 楼主| heweibig 发表于 2019-10-20 14:54 | 显示全部楼层
做一个正弦波,库文件用的是rts2800_ml.lib。
shimx 发表于 2019-10-20 14:58 | 显示全部楼层
CMD文件看看
 楼主| heweibig 发表于 2019-10-20 15:01 | 显示全部楼层
下面是我的CMD文件内容:
MEMORY
   PAGE 0 : PROG(R)     : origin = 0x3E8000, length = 0x10000
   PAGE 0 : BOOT(R)     : origin = 0x3FF000, length = 0xFC0
   PAGE 0 : RESET(R)    : origin = 0x3FFFC0, length = 0x2
   PAGE 0 : VECTORS(R)  : origin = 0x3FFFC2, length = 0x3E
   PAGE 1 : M0RAM(RW)   : origin = 0x000000, length = 0x400
   PAGE 1 : M1RAM(RW)   : origin = 0x000400, length = 0x400
   PAGE 1 : L0L1RAM(RW) : origin = 0x008000, length = 0x2000
   PAGE 1 : H0RAM(RW)   : origin = 0x3F8000, length = 0x2000
SECTIONS
   /* 22-bit program sections */
   .reset   : > RESET,   PAGE = 0
    vectors : > VECTORS, PAGE = 0
   .pinit   : > PROG,    PAGE = 0
   .cinit   : > PROG,    PAGE = 0
   .text    : > PROG,    PAGE = 0
   .cio     : > PROG,    PAGE = 0
   /* 16-Bit data sections */
   .const   : > L0L1RAM, PAGE = 1
   .bss     : > L0L1RAM, PAGE = 1
   .stack   : > M1RAM, PAGE = 1
   .sysmem  : > M0RAM, PAGE = 1
   /* 32-bit data sections */
   .ebss    : > H0RAM, PAGE = 1
   .econst  : > H0RAM, PAGE = 1
   .esysmem : > H0RAM, PAGE = 1
C文件如下:
#include <stdio.h>
#include "Sine.h"
// gain control variable
int gain = INITIALGAIN;  // 5
// declare and initalize a IO buffer //声明并初始化一个IO缓冲器
BufferContents currentBuffer;
// Define some functions
static void processing(); // process the input and generate output
static void dataIO();  // dummy function to be used with ProbePoint
void main()
puts("SineWave example started.\n");
    while(TRUE) // loop forever
        dataIO();
        processing();
    int size = BUFFSIZE;
    while(size--){
        currentBuffer.output[size] = currentBuffer.input[size] * gain; // apply gain to input
    /* do data I/O */
    return;
其中头文件Sine.h如下:
#ifndef TRUE
#define TRUE 1
#endif
// buffer constants
#define BUFFSIZE 0x64
#define INITIALGAIN 5
// IO buffer structure
typedef struct IOBuffer {
int input[BUFFSIZE];
int output[BUFFSIZE];
} BufferContents;
jiaxw 发表于 2019-10-20 15:06 | 显示全部楼层
在CCS下,OUT文件加载时提示“Data verification failed...”的原因?
Link的CMD文件分配的地址同GEL或设置的有效地址空间不符。
jiaxw 发表于 2019-10-20 15:08 | 显示全部楼层
中断向量定位处或其它代码、数据段定位处,没有RAM,无法加载OUT文件。
 楼主| heweibig 发表于 2019-10-20 15:11 | 显示全部楼层
高人,求解?
jiaxw 发表于 2019-10-20 15:16 | 显示全部楼层
调整Link的CMD文件,使得定位段处有RAM。
spark周 发表于 2019-10-20 15:19 | 显示全部楼层
调整存储器设置,使得RAM区有效。
 楼主| heweibig 发表于 2019-10-20 15:22 | 显示全部楼层
哦,这么回事啊,我知道了
wuhany 发表于 2019-10-20 15:25 | 显示全部楼层
错误的地址是哪里?
spark周 发表于 2019-10-20 15:28 | 显示全部楼层
externally 发表于 2019-10-24 16:01 | 显示全部楼层
存储地址不匹配
