| 代码: #include "ac78xx_adc.h"
 #include "ac78xx_gpio.h"
 #include "ac78xx.h"
 #include "ac78xx_debugout.h"
 #include "oled.h"
 #include "bmp.h"
 #define DISABLE                         0
 #define ENABLE                          1
 #define VOLTAGE_BG                      (1.2)             ///<Bandgap Voltage
 uint32_t g_adcValue = 0;
 uint32_t g_displayValue = 0;
 float g_vdd = 0;                                          ///<Power Voltage
 #define ADC_KEY_NUM                     3                 ///<define keypad number
 static float s_ADC_DatMap[ADC_KEY_NUM] = {0.9, 0.6, 0.3}; ///<define KEY voltage
 * OSD_KEY
 * @param[in]  no
 * @return no
 * @brief  Display select KEY pad
 void OSD_KEY()
 ADC_SoftwareStartRegularConvCmd(ADC, ADC_ENABLE);
 while (!ADC_GetIntFlag(ADC, ADC_FLAG_EOC));
 udelay(1);
 g_adcValue = ADC_GetRegularConversionValue(ADC);
 if(g_adcValue < (4096 * s_ADC_DatMap[2]))             ///<select KEY pad
 OLED_ShowString(8, 4, "K5", 8);
 else if(g_adcValue < (4096 * s_ADC_DatMap[1]))
 OLED_ShowString(8, 4, "K4", 8);
 else if(g_adcValue < (4096 * s_ADC_DatMap[0]))
 OLED_ShowString(8, 4, "K3", 8);
 else
 OLED_ShowString(8, 4, "NO", 8);
 * OSD_VDD
 * @param[in]  no
 * @return no
 * @brief  Display Power Voltage
 void OSD_VDD()
 OLED_ShowString(8, 2, "VDD:", 8);
 udelay(1);
 g_adcValue = ADC_GetRegularConversionValue(ADC);       ///<Float Voltage display
 g_vdd = (VOLTAGE_BG / g_adcValue) * 4095;
 g_displayValue = (uint32_t)g_vdd;
 OLED_ShowNum(48, 2, g_displayValue, 1, 8);
 OLED_ShowString(56, 2, ".", 8);
 g_displayValue = (uint32_t)(g_vdd * 10) % 10;
 OLED_ShowNum(64, 2, g_displayValue , 1, 8);
 g_displayValue = (uint32_t)(g_vdd * 100) % 10;         ///<Float Voltage display
 OLED_ShowNum(72, 2, g_displayValue , 1, 8);
 OLED_ShowString(80, 2, "V", 8);
 * main
 * @param[in]  none
 * @return 0: success, other: error value
 * @brief  use ADC detect pressed KEYss
 int main(void)
 ADC_InitType tempAdcConfig = {0, 0, 0, 0, 0, 0, 1};
 ADC_TrigSourceType tempAdcTrigSource = {0, 0};
 ADC_InitType* adcConfig;
 ADC_TrigSourceType* adcTrigSource;
 adcConfig = &tempAdcConfig;
 adcTrigSource = &tempAdcTrigSource;
 adcConfig->scanMode = 0;///ADC mode 0
 adcConfig->continousMode = 0;
 adcConfig->disContinousModeOnRegularGroup = 0;
 adcConfig->disContinousModeOnInjectGroup = 0;
 adcConfig->injectAutoMode = 0;
 GPIO_SetFunc(8, 1); ///ADC_IN1 Analog function enable
 ADC_Init(ADC, adcConfig);  ///ADC works Mode Config
 ADC_SetClockPrescaler(ADC, 4); ///Set ADC Prescaler
 ADC_TrigSourceInit(ADC, adcTrigSource);
 ADC_SetRegularGroupLength(ADC, 1);
 ADC_SetRegularGroupSequence(ADC, 1, ADC_CHANNEL_AD16_BANDGAP); ///set ADC_CHANNEL_AD16_BANDGAP for AD Sample
 ADC_ChannelSampleTimeSel(ADC, ADC_CHANNEL_AD1, ADC_SampleTime_14Cycle);///Set ADC_CHANNEL1 Sample Cycles
 ADC_ChannelSampleTimeSel(ADC, ADC_CHANNEL_AD16_BANDGAP, ADC_SampleTime_14Cycle);///Set ADC_CHANNEL_AD16_BANDGAP Sample Cycles
 ADC_Cmd(ADC, ENABLE);
 InitDelay();
 InitDebug(); /// Initialize debug UART 1
 OLED_Init();
 OLED_Clear();
 printf("\r\nAC7811: ADC_Demo\r\n");
 OLED_ShowString(0, 0, "ADC Demo", 8);
 OLED_DrawBMP(64, 4, 128, 8, g_atc**BMP);
 OSD_VDD();
 OLED_ShowString(8, 3, "Pressed Keypad:", 8);
 OLED_ShowString(8, 4, "NO Key", 8);
 ADC_SetRegularGroupSequence(ADC, 1, ADC_CHANNEL_AD1); //set ADC_CHANNEL1 for AD Sample
 mdelay(100);
 while(1)
 OSD_KEY();
 mdelay(100);
 效果图:
