[STM32F1] 定时器时间,是怎么算出来的?
671|19
 楼主| morrisk 发表于 2019-11-21 19:48 | 显示全部楼层 |阅读模式
#include "stm8s.h"
#include <string.h>
#include <stdio.h>
void Time1(void)
TIM1_DeInit();
TIM1_TimeBaseInit(15,TIM1_COUNTERMODE_UP,1,0);//300us
TIM1_ARRPreloadConfig(ENABLE);//使能自动重装
TIM1_ITConfig(TIM1_IT_UPDATE , ENABLE);//数据更新中断
TIM1_Cmd(ENABLE);//开定时器
void main(void)
  Time1();
  GPIO_Init(GPIOA, GPIO_PIN_3, GPIO_MODE_OUT_PP_LOW_FAST);
  GPIO_Init(GPIOC, GPIO_PIN_3, GPIO_MODE_OUT_PP_LOW_FAST);
  GPIO_Init(GPIOD, GPIO_PIN_3, GPIO_MODE_OUT_PP_LOW_FAST);
  GPIO_Init(GPIOE, GPIO_PIN_3, GPIO_MODE_OUT_PP_LOW_FAST);
  GPIO_Init(GPIOD, GPIO_PIN_0, GPIO_MODE_OUT_PP_LOW_FAST);
  enableInterrupts();
  while (1)
INTERRUPT_HANDLER(TIM1_UPD_OVF_TRG_BRK_IRQHandler, 11)
        static u16 j=0;
      if(j<1)
        j++;
      else
        j=0;
        GPIO_WriteReverse(GPIOD,GPIO_PIN_0);
      TIM1_ClearITPendingBit(TIM1_IT_UPDATE);
#ifdef USE_FULL_ASSERT
void assert_failed(u8* file, u32 line)
  while (1)
#endif
yinxiangh 发表于 2019-11-21 19:53 | 显示全部楼层
没开总中断,需在while(1)前添加 :_asm("rim");//开总中断(此处为开启总中断的方法)
 楼主| morrisk 发表于 2019-11-21 19:57 | 显示全部楼层
谢谢指导,
可是我加了后,出现这样的提示,怎么办啊?
 楼主| morrisk 发表于 2019-11-21 20:02 | 显示全部楼层
#include "stm8s.h"
#include <string.h>
#include <stdio.h>
void Time1(void)
TIM1_DeInit();
TIM1_TimeBaseInit(15,TIM1_COUNTERMODE_UP,1000,0);
void main(void)
  Time1();
  GPIO_WriteHigh(GPIOA,GPIO_PIN_3);
  GPIO_WriteHigh(GPIOC,GPIO_PIN_3);
  GPIO_WriteHigh(GPIOD,GPIO_PIN_3);
  GPIO_WriteHigh(GPIOE,GPIO_PIN_3);
  GPIO_WriteHigh(GPIOD,GPIO_PIN_0);
  enableInterrupts();
  while (1)
__interrupt void TIM1_OVR_UIF(void)
      static u16 j=0; //定义变量j类型为u16,static定义了 变量j的生存周期
      if(j<60000)//判断 j当前的数值是否小于60000
        j++;//计数器 j 加1  也可以写成  j=j+1;
      else//如果大于等于100 执行下面这个分支
        j=0;//计数器 j 清零
         GPIO_WriteReverse(GPIOA,GPIO_PIN_3);
          GPIO_WriteReverse(GPIOC,GPIO_PIN_3);
           GPIO_WriteReverse(GPIOE,GPIO_PIN_3);
      TIM1_ClearITPendingBit(TIM1_IT_UPDATE);//清除更新标
  while (1)
#endif
//新改了,编译没有错误了,可是还是没有闪灯哎
为什么我在中断上面这样写:
#pragma vector=0x0d
__interrupt void TIM1_IRQHandler(void)
却编译失败呢
jiaxw 发表于 2019-11-21 20:02 | 显示全部楼层
ECanaLAMRegs.LAM11.all = 0x8C000000;      //屏蔽26 27两位
        ECanaLAMRegs.LAM12.all = 0x8C000000;      //屏蔽26 27两位
        ECanaLAMRegs.LAM13.all = 0x8C000000;              //屏蔽26 27两位
        ECanaMboxes.MBOX11.MSGID.all = 0x05680000; //  std identifier 15a ,25a
        ECanaMboxes.MBOX12.MSGID.all = 0x056C0000; //  std identifier 15b ,25b
        ECanaMboxes.MBOX13.MSGID.all = 0x05700000; //  std identifier 15c ,25c
yszong 发表于 2019-11-21 20:06 | 显示全部楼层
我的中断函数是在stm8s_it.c中直接添加的,初始化一样,也是IAR的环境。
 楼主| morrisk 发表于 2019-11-21 20:09 | 显示全部楼层
怎么添加???
supernan 发表于 2019-11-21 20:12 | 显示全部楼层
在官方库的例程中直接复制的。你也直接复制就好。
supernan 发表于 2019-11-21 20:15 | 显示全部楼层
 楼主| morrisk 发表于 2019-11-21 20:18 | 显示全部楼层
  /* In order to detect unexpected events during development,
     it is recommended to set a breakpoint on the following instruction.
  * @brief Timer1 Capture/Compare Interrupt routine.
  * @param  None
  * @retval None
INTERRUPT_HANDLER(TIM1_CAP_COM_IRQHandler, 12)
上面是stm8s_it.c文件中的,
我按上面复制,编译报错,这个报错如何处理啊?
 楼主| morrisk 发表于 2019-11-21 20:19 | 显示全部楼层
xxrs 发表于 2019-11-21 20:19 | 显示全部楼层
还有什么现象?能再详细描述下吗?
 楼主| morrisk 发表于 2019-11-21 20:22 | 显示全部楼层
#include "stm8s.h"
#include <string.h>
#include <stdio.h>
void Time1(void)
TIM1_DeInit();
void main(void)
  Time1();
  enableInterrupts();
  while (1)
      if(j<1)//判断 j当前的数值是否小于60000
        j=0;//计数器 j 清零
  while (1)
#endif
现在有闪烁了,得出来的频率是32ms ,
程序如上。
这个STM8的初值是怎么计算出来的呢?
liuzaiy 发表于 2019-11-21 20:28 | 显示全部楼层
enableInterrupts();
 楼主| morrisk 发表于 2019-11-21 20:30 | 显示全部楼层
#include "stm8s.h"
#include <string.h>
#include <stdio.h>
void Time1(void)
TIM1_DeInit();
void main(void)
  Time1();
  enableInterrupts();
  while (1)
        static u16 j=0;
      if(j<1)
        j++;
      else
        j=0;
  while (1)
#endif
//16M的晶振,为什么用示波器测量出来的时间是300US 呢?
八层楼 发表于 2019-12-10 14:47 | 显示全部楼层
我自己没有算过
晓伍 发表于 2019-12-10 14:50 | 显示全部楼层
不太清楚这个问题
磨砂 发表于 2019-12-10 14:53 | 显示全部楼层
帮楼主顶一下
