[PIC®/AVR®/dsPIC®产品] PIC18F47Q10 Curiosity Nano评估工具包【10月】+ LCD12232
1023|4
 楼主| Cjy_JDxy 发表于 2019-11-25 20:40 | 显示全部楼层 |阅读模式
今晚捣鼓了一下LCD12232。
代码如下:
* File:   main.c
* Author: Administrator
* Created on November 25, 2019, 7:48 PM
// CONFIG1L
#pragma config FEXTOSC = ECH    // External Oscillator mode Selection bits (EC (external clock) above 8 MHz; PFM set to high power)
#pragma config RSTOSC = EXTOSC  // Power-up default value for COSC bits (EXTOSC operating per FEXTOSC bits (device manufacturing default))
// CONFIG1H
#pragma config CLKOUTEN = OFF   // Clock Out Enable bit (CLKOUT function is disabled)
#pragma config CSWEN = ON       // Clock Switch Enable bit (Writing to NOSC and NDIV is allowed)
#pragma config FCMEN = ON       // Fail-Safe Clock Monitor Enable bit (Fail-Safe Clock Monitor enabled)
// CONFIG2L
#pragma config MCLRE = EXTMCLR  // Master Clear Enable bit (MCLR pin (RE3) is MCLR)
#pragma config PWRTE = OFF      // Power-up Timer Enable bit (Power up timer disabled)
#pragma config LPBOREN = OFF    // Low-power BOR enable bit (Low power BOR is disabled)
#pragma config BOREN = SBORDIS  // Brown-out Reset Enable bits (Brown-out Reset enabled , SBOREN bit is ignored)
// CONFIG2H
#pragma config BORV = VBOR_190  // Brown Out Reset Voltage selection bits (Brown-out Reset Voltage (VBOR) set to 1.90V)
#pragma config ZCD = OFF        // ZCD Disable bit (ZCD disabled. ZCD can be enabled by setting the ZCDSEN bit of ZCDCON)
#pragma config PPS1WAY = ON     // PPSLOCK bit One-Way Set Enable bit (PPSLOCK bit can be cleared and set only once; PPS registers remain locked after one clear/set cycle)
#pragma config STVREN = ON      // Stack Full/Underflow Reset Enable bit (Stack full/underflow will cause Reset)
#pragma config XINST = OFF      // Extended Instruction Set Enable bit (Extended Instruction Set and Indexed Addressing Mode disabled)
// CONFIG3L
#pragma config WDTCPS = WDTCPS_31// WDT Period Select bits (Divider ratio 1:65536; software control of WDTPS)
#pragma config WDTE = OFF       // WDT operating mode (WDT Disabled)
// CONFIG3H
#pragma config WDTCWS = WDTCWS_7// WDT Window Select bits (window always open (100%); software control; keyed access not required)
#pragma config WDTCCS = SC      // WDT input clock selector (Software Control)
// CONFIG4L
#pragma config WRT0 = OFF       // Write Protection Block 0 (Block 0 (000800-003FFFh) not write-protected)
#pragma config WRT1 = OFF       // Write Protection Block 1 (Block 1 (004000-007FFFh) not write-protected)
#pragma config WRT2 = OFF       // Write Protection Block 2 (Block 2 (008000-00BFFFh) not write-protected)
#pragma config WRT3 = OFF       // Write Protection Block 3 (Block 3 (00C000-00FFFFh) not write-protected)
#pragma config WRT4 = OFF       // Write Protection Block 4 (Block 4 (010000-013FFFh) not write-protected)
#pragma config WRT5 = OFF       // Write Protection Block 5 (Block 5 (014000-017FFFh) not write-protected)
#pragma config WRT6 = OFF       // Write Protection Block 6 (Block 6 (018000-01BFFFh) not write-protected)
#pragma config WRT7 = OFF       // Write Protection Block 7 (Block 7 (01C000-01FFFFh) not write-protected)
// CONFIG4H
#pragma config WRTC = OFF       // Configuration Register Write Protection bit (Configuration registers (300000-30000Bh) not write-protected)
#pragma config WRTB = OFF       // Boot Block Write Protection bit (Boot Block (000000-0007FFh) not write-protected)
#pragma config WRTD = OFF       // Data EEPROM Write Protection bit (Data EEPROM not write-protected)
#pragma config SCANE = ON       // Scanner Enable bit (Scanner module is available for use, SCANMD bit can control the module)
#pragma config LVP = ON         // Low Voltage Programming Enable bit (Low voltage programming enabled. MCLR/VPP pin function is MCLR. MCLRE configuration bit is ignored)
// CONFIG5L
#pragma config CP = OFF         // UserNVM Program Memory Code Protection bit (UserNVM code protection disabled)
#pragma config CPD = OFF        // DataNVM Memory Code Protection bit (DataNVM code protection disabled)
// CONFIG5H
// CONFIG6L
#pragma config EBTR0 = OFF      // Table Read Protection Block 0 (Block 0 (000800-003FFFh) not protected from table reads executed in other blocks)
#pragma config EBTR1 = OFF      // Table Read Protection Block 1 (Block 1 (004000-007FFFh) not protected from table reads executed in other blocks)
#pragma config EBTR2 = OFF      // Table Read Protection Block 2 (Block 2 (008000-00BFFFh) not protected from table reads executed in other blocks)
#pragma config EBTR3 = OFF      // Table Read Protection Block 3 (Block 3 (00C000-00FFFFh) not protected from table reads executed in other blocks)
#pragma config EBTR4 = OFF      // Table Read Protection Block 4 (Block 4 (010000-013FFFh) not protected from table reads executed in other blocks)
#pragma config EBTR5 = OFF      // Table Read Protection Block 5 (Block 5 (014000-017FFFh) not protected from table reads executed in other blocks)
#pragma config EBTR6 = OFF      // Table Read Protection Block 6 (Block 6 (018000-01BFFFh) not protected from table reads executed in other blocks)
#pragma config EBTR7 = OFF      // Table Read Protection Block 7 (Block 7 (01C000-01FFFFh) not protected from table reads executed in other blocks)
// CONFIG6H
#pragma config EBTRB = OFF      // Boot Block Table Read Protection bit (Boot Block (000000-0007FFh) not protected from table reads executed in other blocks)
// #pragma config statements should precede project file includes.
// Use project enums instead of #define for ON and OFF.
#include <xc.h>
#include <pic18f47q10.h>
#define uint     unsigned int
#define uchar    unsigned char
#define CS  RD7
#define SCK  RD5
#define SID  RD6
#define KEY  RE2
uchar i=0,j=0;
uchar yemiancount=0;
uchar const  bmp1[]=
{0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,
0x80,0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,0xFF,0xFF,0x80,0x00,0x00,0x00,0x00,0x01,
0x80,0x00,0x00,0x00,0x00,0x00,0xF8,0x20,0x82,0x0F,0x80,0x00,0x00,0x00,0x00,0x01,
0x80,0x00,0x00,0x00,0x00,0x00,0xF8,0x20,0x83,0xFF,0x80,0x00,0x00,0x00,0x00,0x01,
0x80,0x00,0x00,0x00,0x00,0x00,0xF8,0x3F,0x82,0x0F,0x80,0x00,0x00,0x00,0x00,0x01,
0x80,0x30,0x00,0x18,0x01,0x80,0x0C,0x00,0x18,0x60,0x0F,0x00,0x7F,0xC0,0x01,0x81,
0x80,0x18,0x00,0x18,0x00,0xC0,0x07,0xFC,0x7F,0xFC,0xF8,0x30,0x60,0xC0,0xFF,0xC1,
0x87,0xFF,0xC0,0x18,0x0F,0xFC,0x18,0x0C,0x3C,0x60,0x7B,0x60,0x60,0xC0,0xC1,0x81,
0x80,0x30,0x0F,0xFF,0x80,0x18,0x1B,0xEC,0x19,0xF8,0x36,0xC0,0x7F,0xC0,0xFF,0x81,
0x80,0x30,0x00,0x18,0x00,0x30,0x1B,0x6C,0x7E,0x60,0x18,0x18,0x66,0x00,0xC1,0x81,
0x80,0x3F,0x03,0x18,0x00,0x60,0x1B,0x6C,0x1B,0xFC,0xFF,0xB0,0x63,0x00,0xFF,0x81,
0x80,0x33,0x01,0x98,0x00,0xC0,0x1B,0xEC,0x3D,0x98,0x18,0x60,0x79,0x80,0x36,0x01,
0x80,0x63,0x00,0xD8,0x01,0x80,0x1B,0x6C,0x3F,0xF8,0x3D,0xD8,0x6C,0xC1,0xB6,0xC1,
0x80,0x63,0x00,0x18,0x03,0x00,0x1B,0xEC,0x79,0x98,0x7E,0x30,0xC6,0x70,0xF7,0x81,
0x80,0xC3,0x00,0x18,0x07,0x00,0x1B,0x6C,0x79,0xF8,0xDB,0x61,0xB8,0x00,0x77,0x01,
0x81,0x9E,0x00,0x18,0x1D,0xC0,0x18,0x0C,0x19,0x98,0x18,0xC0,0x0E,0x00,0x36,0xC1,
0x83,0x0C,0x00,0x38,0x00,0x7F,0x18,0x1C,0x19,0xB8,0x1B,0x80,0x03,0x03,0xFF,0xE1,
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF};
uchar const bmp2[]=
{0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x05,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x0F,0xC0,0x00,0x00,0x00,0x00,0x1C,0x00,0x07,0x80,0x00,0x00,0x00,0x00,0x00,0x00,
0x0F,0xF1,0xFF,0xFF,0xFC,0x00,0xFE,0x00,0x0D,0xE1,0xFF,0xFF,0xE0,0x00,0x00,0x00,
0x0F,0xFF,0xFF,0xFF,0xFF,0xC3,0xFF,0x00,0x0C,0x7F,0xFF,0xBF,0xFC,0x00,0x00,0x00,
0x07,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x00,0x0C,0x00,0x00,0x00,0x1F,0x80,0x00,0x00,
0x07,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x00,0x0C,0x00,0x00,0x00,0x03,0xE0,0x00,0x00,
0x07,0xFF,0xFF,0xFF,0xFF,0xFF,0xFE,0x00,0x1C,0x00,0x00,0x00,0x00,0xF8,0x00,0x00,
0x0F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFE,0x00,0x36,0x00,0x00,0x00,0x00,0x3C,0x00,0x00,
0x0F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFC,0x00,0x62,0x00,0x00,0x00,0x00,0x0E,0x00,0x00,
0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,0xF8,0x00,0xC3,0x00,0x00,0x00,0x00,0x07,0x00,0x00,
0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,0xF8,0x00,0x80,0x00,0x00,0x00,0x00,0x03,0x80,0x00,
0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFC,0x01,0x80,0x00,0x00,0x00,0x00,0x01,0x80,0x00,
0x3F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFC,0x03,0x00,0x00,0x00,0x00,0x00,0x00,0xC0,0x00,
0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFC,0x06,0x00,0x00,0x00,0x00,0x00,0x00,0x60,0x00,
0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFC,0x06,0x00,0x00,0x00,0x00,0x00,0x00,0x70,0x00,
0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFC,0x04,0x00,0x00,0x00,0x00,0x00,0x00,0x30,0x00,
0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFC,0x0C,0x00,0x00,0x00,0x00,0x00,0x00,0x30,0x00,
0x7F,0xE3,0xFF,0xFF,0xFF,0xFF,0xFE,0x0C,0x00,0x00,0x00,0x00,0x00,0x00,0x38,0x00,
0x7F,0xC1,0xFF,0xFF,0xFF,0x83,0xFE,0x0C,0x00,0x00,0x00,0x00,0x00,0x00,0x38,0x00,
0x7F,0xE1,0xF8,0x00,0x0F,0x83,0xFE,0xF8,0x00,0x00,0x00,0x00,0x00,0x00,0x18,0x00,
0x7F,0xE3,0xF0,0x00,0x03,0x87,0xFF,0x80,0x18,0x00,0x00,0x00,0x00,0x00,0x18,0x00,
0x7F,0xFF,0xE0,0x40,0x81,0xFF,0xFF,0x00,0x7C,0x00,0x00,0x00,0x00,0x00,0x18,0x00,
0x7F,0xFF,0xE0,0xE1,0xC1,0xFF,0xFF,0x00,0x3C,0x00,0x00,0x00,0x00,0x00,0x18,0x00,
0x7F,0xFF,0xE0,0xC1,0xC1,0xFF,0xFF,0x00,0x38,0x00,0x00,0x00,0x00,0x00,0x1C,0x00,
0x7F,0xFF,0xE0,0x00,0x81,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x18,0x00,
0xFF,0xFF,0xF0,0x00,0x03,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x18,0x00,
0xFF,0xFF,0xFC,0x00,0x0F,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x1C,0x00,
0xFF,0xFF,0xFF,0x81,0xFF,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x1C,0x00,
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x1E,0x00,
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x1F,0x80,
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF0,0x00,0x00,0x00,0x00,0x00,0x00,0x1D,0xFE,
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF8,0x00,0x00,0x00,0x00,0x00,0x00,0x1D,0xFE,
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFE,0x18,0x00,0x00,0x00,0x00,0x00,0x00,0x19,0x60,
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFE,0x18,0x00,0x00,0x00,0x00,0x00,0x00,0x1B,0x60,
0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFE,0x18,0x00,0x00,0x00,0x00,0x00,0x00,0x19,0xE0,
0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFE,0x18,0x00,0x00,0x00,0x00,0x00,0x00,0x18,0x80,
0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFE,0x18,0x00,0x00,0x00,0x00,0x00,0x00,0x38,0x00,
0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFE,0x0C,0x00,0x00,0x00,0x00,0x00,0x00,0x38,0x00,
0x3F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFE,0x0C,0x00,0x00,0x00,0x00,0x00,0x00,0x30,0x00,
0x3F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFE,0x06,0x00,0x00,0x00,0x00,0x00,0x00,0x70,0x00,
0x3F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFE,0x03,0x00,0x00,0x00,0x00,0x00,0x00,0x60,0x00,
0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFE,0x01,0x80,0x00,0x00,0x00,0x00,0x00,0xC0,0x00,
0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFC,0x01,0xC0,0x00,0x00,0x00,0x00,0x00,0xC0,0x00,
0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFC,0x00,0xC0,0x00,0x00,0x00,0x00,0x01,0x80,0x00,
0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFC,0x00,0x60,0x00,0x00,0x00,0x00,0x03,0x80,0x00,
0x0F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFC,0x00,0x70,0x00,0x00,0x00,0x00,0x03,0x00,0x00,
0x0F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFC,0x00,0x38,0x00,0x00,0x00,0x00,0x06,0x00,0x00,
0x07,0xFF,0xFF,0xFF,0xFF,0xFF,0xF8,0x00,0x18,0x1F,0x7F,0xFB,0xFE,0x0E,0x00,0x00,
0x07,0xFF,0xFF,0xFF,0xFF,0xE7,0xF8,0x00,0x0C,0x3F,0xFF,0xFF,0xFE,0x18,0x00,0x00,
0x07,0xF8,0x0E,0x00,0x08,0x03,0xF0,0x00,0x0C,0x60,0x00,0x00,0x06,0x30,0x00,0x00,
0x03,0xF8,0x00,0x00,0x00,0x03,0xF0,0x00,0x0E,0x60,0x00,0x00,0x03,0xF0,0x00,0x00,
0x01,0xF0,0x00,0x00,0x00,0x01,0x80,0x00,0x03,0xC0,0x00,0x00,0x01,0xC0,0x00,0x00,
0x00,0x20,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
uchar const bmp3[]=
0x00,0x7F,0x0F,0xC0,0x01,0x81,0xF0,0xF8,0x3C,0x06,0x00,0x0F,0x9E,0xF0,0x00,0x00,
0x00,0x31,0x98,0xC0,0x07,0x83,0x19,0x8C,0x6C,0x0E,0x00,0x18,0xCC,0x60,0x00,0x00,
0x00,0x36,0x18,0xC0,0x01,0x83,0x19,0x8C,0xC0,0x1E,0x00,0x18,0xCC,0x60,0x00,0x00,
0x00,0x36,0x30,0x00,0x01,0x83,0x19,0x8C,0xC0,0x36,0x00,0x18,0xCC,0x60,0x00,0x00,
0x00,0x3E,0x30,0x00,0x01,0x80,0x30,0xD8,0xF8,0x36,0x00,0x01,0x8C,0x60,0x00,0x00,
0x00,0x36,0x30,0x0F,0xF1,0x80,0x30,0x70,0xEC,0x66,0x3F,0xC1,0x8F,0xE0,0x00,0x00,
0x00,0x36,0x30,0x00,0x01,0x80,0x60,0xD8,0xC6,0x66,0x00,0x03,0x0C,0x60,0x00,0x00,
0x00,0x30,0x30,0x00,0x01,0x80,0xC1,0x8C,0xC6,0x7F,0x00,0x06,0x0C,0x60,0x00,0x00,
0x00,0x30,0x18,0xC0,0x01,0x81,0x81,0x8C,0xC6,0x06,0x00,0x0C,0x0C,0x60,0x00,0x00,
0x00,0x30,0x19,0x80,0x01,0x83,0x19,0x8C,0x6C,0x06,0x00,0x18,0xCC,0x60,0x00,0x00,
0x00,0x78,0x0F,0x00,0x07,0xE3,0xF8,0xF8,0x38,0x1F,0x00,0x1F,0xDE,0xF0,0x00,0x00,
0x00,0x00,0x03,0x66,0x00,0x60,0x00,0x18,0x03,0x06,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x03,0x66,0x00,0x30,0x00,0x0C,0x01,0x83,0x00,0x7F,0xF0,0x00,0x00,0x00,
0x00,0x00,0x1F,0xFF,0xC7,0xFF,0xC3,0xFF,0xF1,0xBF,0xF8,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x03,0x66,0x06,0x00,0xC3,0x18,0x00,0x30,0x30,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x03,0x66,0x0C,0x01,0x83,0x18,0x06,0x1F,0xE0,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x1F,0xFF,0xC3,0xFE,0x03,0xFF,0xE3,0xC3,0x01,0xFF,0xFC,0x00,0x00,0x00,
0x00,0x00,0x18,0x61,0x80,0x0C,0x03,0x36,0x00,0xDF,0xE0,0x06,0x00,0x00,0x00,0x00,
0x00,0x00,0x30,0x63,0x00,0x18,0x03,0x66,0x01,0x9B,0x60,0x06,0x00,0x00,0x00,0x00,
0x00,0x00,0x07,0xFE,0x00,0x30,0x03,0xFF,0xE1,0x9F,0xE0,0x66,0xC0,0x00,0x00,0x00,
0x00,0x00,0x06,0x66,0x0F,0xFF,0xE3,0x66,0x01,0x9B,0x60,0x66,0x60,0x00,0x00,0x00,
0x00,0x00,0x06,0x66,0x00,0x30,0x03,0x06,0x07,0x1B,0x60,0xC6,0x30,0x00,0x00,0x00,
0x00,0x00,0x06,0x66,0x00,0x30,0x03,0xFF,0xF3,0x1F,0xE1,0x86,0x38,0x00,0x00,0x00,
0x00,0x00,0x06,0x7E,0x00,0x30,0x03,0x06,0x03,0x00,0x03,0x06,0x18,0x00,0x00,0x00,
0x00,0x00,0x06,0x6C,0x00,0x30,0x06,0x06,0x03,0x0C,0xC0,0x06,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x60,0x00,0xF0,0x06,0x06,0x03,0x0C,0x60,0x1E,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x60,0x00,0x60,0x0C,0x06,0x03,0x18,0x60,0x0C,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x60,0x03,0x03,0x00,0x00,0x00,0x00,0x00,0x01,0x80,0x00,0x00,0x00,
0x00,0x00,0x00,0x60,0x01,0x83,0x80,0x00,0x03,0xFF,0xF8,0xCD,0x80,0x00,0x00,0x00,
0x00,0x00,0x07,0xFE,0x00,0xE3,0x03,0xFF,0xC0,0x00,0x60,0x6D,0x80,0x00,0x00,0x00,
0x00,0x00,0x06,0x66,0x00,0xC6,0x03,0x00,0xC0,0x00,0x60,0x6F,0xF0,0x00,0x00,0x00,
0x00,0x00,0x06,0x66,0x0F,0xFF,0xC3,0x00,0xC0,0xFE,0x60,0x19,0x80,0x00,0x00,0x00,
0x00,0x00,0x07,0xFE,0x00,0xC6,0x03,0x00,0xC0,0xC6,0x60,0x01,0x80,0x00,0x00,0x00,
0x00,0x00,0x00,0x60,0x00,0xC6,0x03,0x00,0xC0,0xC6,0x63,0xFF,0xF8,0x00,0x00,0x00,
0x00,0x00,0x0F,0xFF,0x00,0xC6,0x03,0x00,0xC0,0xC6,0x60,0x66,0xC0,0x00,0x00,0x00,
0x00,0x00,0x0C,0x63,0x0F,0xFF,0xE3,0x00,0xC0,0xC6,0x60,0x66,0xC0,0x00,0x00,0x00,
0x00,0x00,0x0C,0x63,0x00,0xC6,0x03,0x00,0xC0,0xFE,0x60,0x6C,0xD8,0x00,0x00,0x00,
0x00,0x00,0x0C,0x63,0x00,0xC6,0x03,0x00,0xC0,0xC6,0x60,0x6C,0xD8,0x00,0x00,0x00,
0x00,0x00,0x0F,0xFF,0x00,0xC6,0x03,0xFF,0xC0,0x00,0x60,0x78,0x78,0x00,0x00,0x00,
0x00,0x00,0x0C,0x63,0x01,0x86,0x03,0x00,0xC0,0x03,0x60,0x60,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x60,0x01,0x86,0x03,0x00,0xC0,0x01,0xE0,0xF0,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x60,0x03,0x06,0x00,0x00,0x00,0x00,0xC1,0x9F,0xFC,0x00,0x00,0x00,
0x00,0x00,0x00,0x60,0x06,0x06,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
uchar const bmp4[]=
0x00,0x36,0x30,0x00,0x01,0x83,0x19,0x8C,0xC0,0x36,0x00,0x01,0x8C,0x60,0x00,0x00,
0x00,0x3E,0x30,0x00,0x01,0x80,0x30,0xD8,0xF8,0x36,0x00,0x07,0x0C,0x60,0x00,0x00,
0x00,0x36,0x30,0x00,0x01,0x80,0x60,0xD8,0xC6,0x66,0x00,0x00,0xCC,0x60,0x00,0x00,
0x00,0x30,0x30,0x00,0x01,0x80,0xC1,0x8C,0xC6,0x7F,0x00,0x00,0xCC,0x60,0x00,0x00,
0x00,0x30,0x18,0xC0,0x01,0x81,0x81,0x8C,0xC6,0x06,0x00,0x18,0xCC,0x60,0x00,0x00,
0x00,0x30,0x19,0x80,0x01,0x83,0x19,0x8C,0x6C,0x06,0x00,0x19,0x8C,0x60,0x00,0x00,
0x00,0x78,0x0F,0x00,0x07,0xE3,0xF8,0xF8,0x38,0x1F,0x00,0x0F,0x1E,0xF0,0x00,0x00,
void delayus(void)
    uchar i;
    for(i=0;i<5;i++);
void SendByte(uchar Dbyte)
         uchar i;
         for(i=0;i<8;i++)
                 SCK = 0;
                 delayus();
                 if((Dbyte&0x80)==0x80)
                    SID = 1;
                 else
                    SID = 0;
                 Dbyte=Dbyte<<1;
                 delayus();
                 SCK = 1;
                 delayus();
uchar ReceiveByte()
         uchar i,temp1,temp2;
         temp1=temp2=0;
         TRISD=0X40;
         for(i=0;i<20;i++);
         for(i=0;i<8;i++)
                 temp1=temp1<<1;
                 SCK = 0;
                 delayus();
                 SCK = 1;
                 delayus();
                 if(SID==1) temp1++;
                 delayus();
         for(i=0;i<8;i++)
                 temp2=temp2<<1;
                 SCK = 0;
                 delayus();
                 SCK = 1;
                 delayus();
                 if(SID==1) temp2++;
                 delayus();
         TRISD=0;
         for(i=0;i<20;i++);
         return ((0xf0&temp1)+(0x0f&temp2));
void busy( )
         do SendByte(0xfc);     //11111,RW(1),RS(0),0
         while(0x80&ReceiveByte());
void write_cmd( uchar Cbyte )
         CS = 1;
         delayus();
         busy();
         SendByte(0xf8);          //11111,RW(0),RS(0),0
                 SendByte(0xf0&Cbyte);
         SendByte(0xf0&Cbyte<<4);
         CS = 0;
         delayus();
void write_data( uchar Dbyte )
         CS = 1;
         delayus();
         busy();
         SendByte(0xfa);          //11111,RW(0),RS(1),0
         SendByte(0xf0&Dbyte);
                 SendByte(0xf0&Dbyte<<4);
         CS = 0;
         delayus();
uchar ReadData( )
         busy();
         SendByte(0xfe);          //11111,RW(1),RS(1),0
         return ReceiveByte();
void delay(uint MS)
  uint i,j;
  for (i=0;i<MS;i++)
  for(j=0;j<10;j++);
void LcmInit( )
         write_cmd(0x30);
                 delay(100);
         write_cmd(0x03);
                 delay(100);
         write_cmd(0x0C);
                 delay(100);
         write_cmd(0x01);
                 delay(100);
         write_cmd(0x06);
                 delay(100);
void LcmClearTXT( )
         uchar i;
         write_cmd(0x30);
         write_cmd(0x80);
         for(i=0;i<64;i++)
         write_data(0x20);
void LcmClearBMP()
         uchar i,j;
         write_cmd(0x34);
         write_cmd(0x36);
         for(i=0;i<32;i++)
                 write_cmd(0x80+i);
                 write_cmd(0x80);
                 for(j=0;j<32;j++)
                 write_data(0);
void PUTstring(uchar row,uchar col,uchar *puts)
       write_cmd(0x30);
      switch(row)
        case 0: write_cmd(0x80+col);break;
        case 1: write_cmd(0x90+col);break;
        case 2: write_cmd(0x88+col);break;
        case 3: write_cmd(0x98+col);break;
         while(*puts != '\0')
            write_data(*puts);
            puts++;
void PUTZIZAO(uchar row,uchar col,uchar *puts)
            uchar i=0,j=0,k=0;
        write_cmd(0x34);
        write_cmd(0x36);
        for(i=0;i<16;i++)
            write_cmd(0x80+i+row);
            write_data(puts[2*k]);
            write_data(puts[2*k+1]);
            k++;
void PUTBMP(uchar *puts)
         uint x=0,y=0;
         uchar i,j;
         write_cmd(0x34);
         write_cmd(0x36);
         for(i=0;i<32;i++)
                 write_cmd(0x80+i);
                 write_cmd(0x80);
                 for(j=0;j<8;j++)
                     write_data(puts[2*x]);
                                         write_data(puts[2*x+1]);
                     x++;
                                 write_cmd(0x80+i);
                 write_cmd(0x88);
                 for(j=0;j<8;j++)
                     write_data(puts[2*y+512]);
                                         write_data(puts[2*y+513]);
                     y++;
void  oshuxian()
                write_cmd(0x34);
            write_cmd(0x36);
            for(i=0;i<32;i++)
         {  //write_cmd(0x36);
            write_cmd(0x80+i);
                        write_cmd(0x80);
            //write_cmd(0x30);
            for(j=0;j<32;j++)
                        write_data(0xCC);
                write_cmd(0x32);
void jishuxian()
                write_cmd(0x34);
            write_cmd(0x36);
               for(i=0;i<32;i++)
             //write_cmd(0x36);
            write_cmd(i+0x80);
                        write_cmd(0x80);
            //write_cmd(0x30);
                        for(j=0;j<32;j++)
                        write_data(0x33);
                write_cmd(0x32);
void  ohengxian()
        LcmClearTXT();
         write_cmd(0x34);
             write_cmd(0x36);
         for(i=0;i<16;i++)
                    //write_cmd(0x36);
                                         write_cmd(0x80+2*i);
                                         write_cmd(0x80);
                                         //write_cmd(0x30);
                     for(j=0;j<32;j++)write_data(0xFF);
                                         //write_cmd(0x36);
                                         write_cmd(0x80+2*i+1);
                                         write_cmd(0x80);
                                         //write_cmd(0x30);
                     for(j=0;j<32;j++)write_data(0);
                 write_cmd(0x32);
void  dianxian()
        LcmClearTXT();
             write_cmd(0x34);
             write_cmd(0x36);
             for(i=0;i<16;i++)
                                         write_cmd(0x80);
                                         //write_cmd(0x30);
                     for(j=0;j<32;j++)write_data(0XAA);
                                         //write_cmd(0x36);
                                         write_cmd(0x80);
                                         //write_cmd(0x30);
                     for(j=0;j<32;j++)write_data(0x55);
                 write_cmd(0x32);
void hanzi()
   LcmClearBMP();
   write_cmd(0x30);
   PUTstring(0,0,"深圳方寸电子有限");
   PUTstring(1,0,"公司南山区西丽南");
   PUTstring(2,0,"湾工业区10栋4 楼");
   PUTstring(3,0,"方寸之间精彩尽显");
void  jihengxian()
         write_cmd(0x34);
             write_cmd(0x36);
         for(i=0;i<16;i++)
                    //write_cmd(0x36);
                                         write_cmd(0x80);
                                         //write_cmd(0x30);
                                         //write_cmd(0x36);
                                         write_cmd(0x80);
                                         //write_cmd(0x30);
                 write_cmd(0x32);
void main(void)
    uint k;
    ANSELE=0X02;
    ANSELD=0;
    WPUE=0X04;
    TRISE=0X04;
    TRISD=0;
    LcmInit();
    LcmClearTXT();
    LcmClearBMP();
    hanzi();
    while(1)
        if(KEY==0)
            for(k=0;k<2000;k++);
            if(KEY==0)
                while(KEY==0);
                yemiancount++;
                if(yemiancount>=9)
                    yemiancount=0;
                RE0^=1;
        /*switch(yemiancount)
          case 0: PUTBMP(bmp4);break;
          case 1: PUTBMP(bmp1);break;
          case 2: hanzi();break;
          case 3: dianxian();break;
          case 4: ohengxian();break;
          case 5: jihengxian();break;
          case 6: oshuxian();break;
          case 7: jishuxian();break;
          case 8:         PUTBMP(bmp2);break;
    return;
效果图:
小明的同学 发表于 2019-12-9 23:42 | 显示全部楼层
一看楼主就是高手,上来就是字库。
小明的同学 发表于 2019-12-9 23:43 | 显示全部楼层
经常看到楼主跟各位大佬切磋,给楼主点赞。讲讲入门吧
 楼主| Cjy_JDxy 发表于 2019-12-10 08:11 | 显示全部楼层
一看楼主就是高手,上来就是字库。
不是高手
小明的同学 发表于 2019-12-10 12:06 | 显示全部楼层
你就是,哈哈。我看你经常在大佬们贴下回复自己的观点
个人签名:绿水本无忧因风皱面,青山原不老为雪白头。
553
