[活动] EFM8BB1测评——闪灯
808|0
 楼主| Cjy_JDxy 发表于 2019-11-29 20:03 | 显示全部楼层 |阅读模式
fm, TI, LED, se, ic
以前没用过silabs公司的芯片,C8051没用过,小壁虎也没用过。
今天有机会了,先搞个闪灯。开发环境simplicity studio v4
代码:
#include <SI_EFM8SB2_Register_Enums.h>                // SFR declarations
#include "InitDevice.h"
SI_SBIT(LED, SFR_P1, 4);   // LED
SI_SBIT(S1, SFR_P0, 2);                                   // BTN0
#define SYSCLK      24500000/8         // Clock speed in Hz (default)
#define SW_PRESSED           0
#define SW_NOT_PRESSED       1
#define LED_ON               0
#define LED_OFF              1
// SiLabs_Startup() Routine
// This function is called immediately after reset, before the initialization
// code is run in SILABS_STARTUP.A51 (which runs before main() ). This is a
// useful place to disable the watchdog timer, which is enable by default
// and may trigger before main() in some instances.
void SiLabs_Startup (void)
  // Disable the watchdog here
// main() Routine
// Note: the software watchdog timer is not disabled by default in this
// example, so a long-running program will reset periodically unless
// the timer is disabled or your program periodically writes to it.
// Review the "Watchdog Timer" section under the part family's datasheet
// for details. To find the datasheet, select your part in the
// Simplicity Launcher and click on "Data Sheet".
int main (void)
        unsigned int i;
        enter_DefaultMode_from_RESET();
        while (1)
                LED = LED_OFF;
                for(i=0;i<20000;i++);
                LED = LED_ON;
        }                             // Spin forever
效果图:
个人签名:绿水本无忧因风皱面,青山原不老为雪白头。
553
