最近在学习LWIP的数据包管理,分析源码的时候看到这个内存分配函数,感觉源码的p->len处理有问题,还请大佬指教。有问题部分的源码已经标红出来了。
---------------------- pbuf结构体是这样的 ---------------------------
struct pbuf {
/** next pbuf in singly linked pbuf chain */
struct pbuf *next;
/** pointer to the actual data in the buffer */
void *payload;
* total length of this buffer and all next buffers in chain
* belonging to the same packet.
* For non-queue packet chains this is the invariant:
* p->tot_len == p->len + (p->next? p->next->tot_len: 0)
u16_t tot_len;
/** length of this buffer */
u16_t len;
/** pbuf_type as u8_t instead of enum to save space */
u8_t /*pbuf_type*/ type;
/** misc flags */
u8_t flags;
* the reference count always equals the number of pointers
* that refer to this pbuf. This can be pointers from an application,
* the stack itself, or pbuf->next pointers from a chain.
u16_t ref;
----------------- pbuf的内存分配函数是这样的 ------------------
struct pbuf *
pbuf_alloc(pbuf_layer layer, u16_t length, pbuf_type type)
struct pbuf *p, *q, *r;
u16_t offset;
s32_t rem_len; /* remaining length */
LWIP_DEBUGF(PBUF_DEBUG | LWIP_DBG_TRACE | 3, ("pbuf_alloc(length=%"U16_F")\n", length));
/* determine header offset */
offset = 0;
switch (layer) {
case PBUF_TRANSPORT:
/* add room for transport (often TCP) layer header */
offset += PBUF_TRANSPORT_HLEN;
/* FALLTHROUGH */
case PBUF_IP:
/* add room for IP layer header */
offset += PBUF_IP_HLEN;
/* FALLTHROUGH */
case PBUF_LINK:
/* add room for link layer header */
offset += PBUF_LINK_HLEN;
break;
case PBUF_RAW:
break;
default:
LWIP_ASSERT("pbuf_alloc: bad pbuf layer", 0);
return NULL;
switch (type) {
case PBUF_POOL://这是用内存池策略来分配时候的情况
/* allocate head of pbuf chain into p */
ALLOC_POOL_PBUF(p);//在这里分配了一个内存池给p
LWIP_DEBUGF(PBUF_DEBUG | LWIP_DBG_TRACE | 3, ("pbuf_alloc: allocated pbuf %p\n", (void *)p));
if (p == NULL) {
return NULL;
p->type = type;
p->next = NULL;
/* make the payload pointer point 'offset' bytes into pbuf data memory */
p->payload = LWIP_MEM_ALIGN((void *)((u8_t *)p + (SIZEOF_STRUCT_PBUF + offset)));
LWIP_ASSERT("pbuf_alloc: pbuf p->payload properly aligned",
((mem_ptr_t)p->payload % MEM_ALIGNMENT) == 0);
/* the total length of the pbuf chain is the requested size */
p->tot_len = length;
/* set the length of the first pbuf in the chain */
p->len = LWIP_MIN(length, PBUF_POOL_BUFSIZE_ALIGNED - LWIP_MEM_ALIGN_SIZE(offset));/* 这里赋值给len字段的时候,为什么不把pbuf结构本身的长度去掉呢?这很奇怪。
我个人感觉正确的写法应该是:
p->len = LWIP_MIN(length, PBUF_POOL_BUFSIZE_ALIGNED - LWIP_MEM_ALIGN_SIZE(offset+PBUF_POOL_BUFSIZE_ALIGNED));
LWIP_ASSERT("check p->payload + p->len does not overflow pbuf",
((u8_t*)p->payload + p->len <=
(u8_t*)p + SIZEOF_STRUCT_PBUF + PBUF_POOL_BUFSIZE_ALIGNED));
LWIP_ASSERT("PBUF_POOL_BUFSIZE must be bigger than MEM_ALIGNMENT",
(PBUF_POOL_BUFSIZE_ALIGNED - LWIP_MEM_ALIGN_SIZE(offset)) > 0 );
/* set reference count (needed here in case we fail) */
p->ref = 1;
/* now allocate the tail of the pbuf chain */
/* remember first pbuf for linkage in next iteration */
r = p;
/* remaining length to be allocated */
rem_len = length - p->len;
/* any remaining pbufs to be allocated? */
while (rem_len > 0) {
ALLOC_POOL_PBUF(q);
if (q == NULL) {
/* free chain so far allocated */
pbuf_free(p);
/* bail out unsuccesfully */
return NULL;
q->type = type;
q->flags = 0;
q->next = NULL;
/* make previous pbuf point to this pbuf */
r->next = q;
/* set total length of this pbuf and next in chain */
LWIP_ASSERT("rem_len < max_u16_t", rem_len < 0xffff);
q->tot_len = (u16_t)rem_len;
/* this pbuf length is pool size, unless smaller sized tail */
q->len = LWIP_MIN((u16_t)rem_len, PBUF_POOL_BUFSIZE_ALIGNED);
q->payload = (void *)((u8_t *)q + SIZEOF_STRUCT_PBUF);
LWIP_ASSERT("pbuf_alloc: pbuf q->payload properly aligned",
((mem_ptr_t)q->payload % MEM_ALIGNMENT) == 0);
q->ref = 1;
/* calculate remaining length to be allocated */
rem_len -= q->len;
/* remember this pbuf for linkage in next iteration */
r = q;
/* end of chain */
/*r->next = NULL;*/
break;
case PBUF_RAM://这是用内存堆策略来分配的情况
/* If pbuf is to be allocated in RAM, allocate memory for it. */
p = (struct pbuf*)mem_malloc(LWIP_MEM_ALIGN_SIZE(SIZEOF_STRUCT_PBUF + offset) + LWIP_MEM_ALIGN_SIZE(length));//这里分配的长度,显然说明了整个pbuf的组成应该是pbuf结构体本身的长度+offset偏移+实际的数据长度
if (p == NULL) {
return NULL;
/* Set up internal structure of the pbuf. */
p->payload = LWIP_MEM_ALIGN((void *)((u8_t *)p + SIZEOF_STRUCT_PBUF + offset));
p->len = p->tot_len = length;
p->next = NULL;
p->type = type;
LWIP_ASSERT("pbuf_alloc: pbuf->payload properly aligned",
break;
/* pbuf references existing (non-volatile static constant) ROM payload? */
case PBUF_ROM:
/* pbuf references existing (externally allocated) RAM payload? */
case PBUF_REF:
/* only allocate memory for the pbuf structure */
p = memp_malloc(MEMP_PBUF);
if (p == NULL) {
LWIP_DEBUGF(PBUF_DEBUG | LWIP_DBG_TRACE | 2, ("pbuf_alloc: Could not allocate MEMP_PBUF for PBUF_%s.\n",
(type == PBUF_ROM) ? "ROM" : "REF"));
return NULL;
/* caller must set this field properly, afterwards */
p->payload = NULL;
p->next = NULL;
p->type = type;
break;
default:
LWIP_ASSERT("pbuf_alloc: erroneous type", 0);
return NULL;
/* set reference count */
p->ref = 1;
/* set flags */
p->flags = 0;
LWIP_DEBUGF(PBUF_DEBUG | LWIP_DBG_TRACE | 3, ("pbuf_alloc(length=%"U16_F") == %p\n", length, (void *)p));
return p;
