[DemoCode下载] M051使用库函数输出互补PWM信号方法
1958|4
 楼主| 734774645 发表于 2020-2-20 12:17 | 显示全部楼层 |阅读模式
  1. /**************************************************************************//**
  2. * [url=home.php?mod=space&uid=288409]@file[/url]     main.c
  3. * [url=home.php?mod=space&uid=895143]@version[/url]  V1.00
  4. * $Revision: 4 $
  5. * $Date: 15/05/22 2:05p $
  6. * [url=home.php?mod=space&uid=247401]@brief[/url]    通过P40(24)和P41(PIN36)输出两路PWM信号.
  7. *
  8. * @note
  9. * Copyright (C) 2014 Nuvoton Technology Corp. All rights reserved.
  10. *
  11. ******************************************************************************/
  12. #include <stdio.h>
  13. #include "M051Series.h"
  14. /*---------------------------------------------------------------------------------------------------------*/
  15. /* Macro, type and constant definitions        */
  16. /*---------------------------------------------------------------------------------------------------------*/
  17. #define PLLCON_SETTING      CLK_PLLCON_50MHz_HXT
  18. #define PLL_CLOCK           50000000
  19. /*---------------------------------------------------------------------------------------------------------*/
  20. /* Global variables        */
  21. /*---------------------------------------------------------------------------------------------------------*/
  22. void SYS_Init(void)
  23. {
  24.     /*---------------------------------------------------------------------------------------------------------*/
  25.     /* Init System Clock        */
  26.     /*---------------------------------------------------------------------------------------------------------*/
  27.     /* Enable Internal RC clock */
  28.     CLK_EnableXtalRC(CLK_PWRCON_OSC22M_EN_Msk);
  29.     /* Waiting for IRC22M clock ready */
  30.     CLK_WaitClockReady(CLK_CLKSTATUS_OSC22M_STB_Msk);
  31.     /* Switch HCLK clock source to Internal RC and HCLK source divide 1 */
  32.     CLK_SetHCLK(CLK_CLKSEL0_HCLK_S_HIRC, CLK_CLKDIV_HCLK(1));
  33.     /* Enable external 12MHz XTAL, internal 22.1184MHz */
  34.     CLK_EnableXtalRC(CLK_PWRCON_XTL12M_EN_Msk | CLK_PWRCON_OSC22M_EN_Msk);
  35.     /* Enable PLL and Set PLL frequency */
  36.     CLK_SetCoreClock(PLLCON_SETTING);
  37.     /* Waiting for clock ready */
  38.     CLK_WaitClockReady(CLK_CLKSTATUS_PLL_STB_Msk | CLK_CLKSTATUS_XTL12M_STB_Msk | CLK_CLKSTATUS_OSC22M_STB_Msk);
  39.     /* Switch HCLK clock source to PLL, STCLK to HCLK/2 */
  40.     CLK_SetHCLK(CLK_CLKSEL0_HCLK_S_PLL, CLK_CLKDIV_HCLK(2));
  41.     /* Enable UART module clock */
  42.     CLK_EnableModuleClock(UART0_MODULE);
  43.     /* Enable PWM module clock */
  44.     CLK_EnableModuleClock(PWM01_MODULE);
  45.     /* Select UART module clock source */
  46.     CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UART_S_HXT, CLK_CLKDIV_UART(1));
  47.     /* Select PWM module clock source */
  48.     CLK_SetModuleClock(PWM01_MODULE, CLK_CLKSEL1_PWM01_S_HXT, 0);
  49.     /* Reset PWMA channel0~channel3 */
  50.     SYS_ResetModule(PWM03_RST);
  51.     /* Update System Core Clock */
  52.     /* User can use SystemCoreClockUpdate() to calculate PllClock, SystemCoreClock and CycylesPerUs automatically. */
  53.     //SystemCoreClockUpdate();
  54.     PllClock        = PLL_CLOCK;            // PLL
  55.     SystemCoreClock = PLL_CLOCK / 1;        // HCLK
  56.     CyclesPerUs     = PLL_CLOCK / 1000000;  // For SYS_SysTickDelay()
  57.     /*---------------------------------------------------------------------------------------------------------*/
  58.     /* Init I/O Multi-function        */
  59.     /*---------------------------------------------------------------------------------------------------------*/
  60.     /* Set P3 multi-function pins for UART0 RXD and TXD  */
  61.     SYS->P3_MFP &= ~(SYS_MFP_P30_Msk | SYS_MFP_P31_Msk);
  62.     SYS->P3_MFP |= SYS_MFP_P30_RXD0 | SYS_MFP_P31_TXD0;
  63.     /* Set P4 multi-function pins for PWMA Channel 0 and 1 */
  64.     SYS->P4_MFP &= ~(SYS_MFP_P40_Msk|SYS_MFP_P41_Msk);
  65.     SYS->P4_MFP |= (SYS_MFP_P40_PWM0|SYS_MFP_P41_PWM1);
  66.
  67. }
  68. void UART0_Init(void)
  69. {
  70.     /*---------------------------------------------------------------------------------------------------------*/
  71.     /* Init UART        */
  72.     /*---------------------------------------------------------------------------------------------------------*/
  73.     /* Configure UART0 and set UART0 Baudrate */
  74.     UART_Open(UART0, 115200);
  75. }
  76. /*---------------------------------------------------------------------------------------------------------*/
  77. /*  Main Function        */
  78. /*---------------------------------------------------------------------------------------------------------*/
  79. int32_t main(void)
  80. {
  81.         uint8_t i=100;
  82.         /* Unlock protected registers */
  83.         SYS_UnlockReg();
  84.         /* Init System, IP clock and multi-function I/O */
  85.         SYS_Init();
  86.         /* Lock protected registers */
  87.         SYS_LockReg();
  88.         /* Init UART0 for printf */
  89.         UART0_Init();
  90. //使能PWM0和PWM1通道
  91.         PWM_EnableOutput(PWMA, 0x1|0x2);
  92.         //设置PWM0通道的频率与占空比配置,因为是互补输出,只需要设置PWM0的即可
  93.         PWM_ConfigOutputChannel(PWMA, PWM_CH0, 1000, i);
  94. //使能死区功能,死区设置为0,即生成完全互补信号。
  95.         PWM_EnableDeadZone(PWMA,PWM_CH0,0);
  96.         PWM_Start(PWMA, 0x1|0x2);
  97.
  98.         GPIO_SetMode(P3,BIT6,GPIO_PMD_OUTPUT);
  99.         while(1)
  100.         {
  101.                 while(i>0)
  102.                 {
  103.                         i=i-1;
  104.                         PWM_ConfigOutputChannel(PWMA, PWM_CH0, 1000, i);
  105.                         CLK_SysTickDelay(10000);
  106.                 }
  107.
  108. //驱动板载的LED红灯闪烁
  109.                 P36 ^=1;
  110.
  111.                 while(i<100)
  112.                 {
  113.                         i=i+1;
  114.                         PWM_ConfigOutputChannel(PWMA, PWM_CH0, 1000, i);
  115.                         CLK_SysTickDelay(10000);
  116.                 }
  117.
  118. //驱动板载的LED红灯闪烁
  119.                 P36 ^=1;
  120.         }
  121. }
新版的库函数在多个系列中都是通用的, 因此会了新版库函数,可以在任意一款新唐单片机中实现。移植能力超强。
zhuomuniao110 发表于 2020-2-20 12:21 | 显示全部楼层
大佬给力,精简,易懂
antusheng 发表于 2020-2-20 12:27 | 显示全部楼层
看懂了,比例程还好懂。
yiy 发表于 2020-2-20 23:25 | 显示全部楼层
学会了好容易啊。
