| 在网上查资料,有网友试验成功,自己用可以读取TypeB的读卡器不能正常读取,按照网上的资料修改询卡指令后,不能返回正常的数据。没有卡的时候打印的数据如下:58 50 00 00 1D 1D 1D 1D 1D 1D 1D 1D 1D 1D 1D 1D 1D 00 6D 03 7B       最后的03是g_test。从50到最后一个1D是RegFIFOData返回的数据。刷身份证没啥变化。询卡函数如下:
 uchar At88rf080Request(void)     //TypeBѯ¿¨
 char status = MI_OK;
 int dd;
 char m,i;
 i = 0;
 mrcreg.RegChannelRedundancy =  0x2c; //RegChannelRedundanc
 //mrcreg.RegControl = mrcreg.RegControl | 0X01 ;
 mrcreg.RegControl = mrcreg.RegControl & 0XF7 ;
 //mrcreg.RegTxControl = mrcreg.RegTxControl | 0X03 ;
 //mrcreg.RegInterruptEn = 0X7F ;
 //mrcreg.RegInterruptRq = 0x7F ; // reset interrupt requests
 mrcreg.RegCommand = 0x00 ; // terminate probably running command **0xa0;
 mrcreg.RegFIFOData = 0XA0;
 mrcreg.RegFIFOData = 0X00;
 mrcreg.RegFIFOData = 0X80;
 mrcreg.RegFIFOData = 0X13;
 mrcreg.RegFIFOData = 0X4D;
 mrcreg.RegCommand= 0X1A ;
 mrcreg.RegFIFOData = 0x50;
 mrcreg.RegFIFOData = 0x00;
 mrcreg.RegCommand  = 0X1A ;
 dd=10000;
 while ( (!(mrcreg.RegInterruptRq & 0x10)) && dd)
 dd --;
 m=( mrcreg.RegInterruptRq &0x10);
 g_test3 =  mrcreg.RegFIFOLength;
 if(m>10)
 while(m--)
 Srn[i]  =mrcreg.RegFIFOData ;
 i++;
 SendCardResult(0x58,Srn);
 if (!m)
 m = mrcreg.RegPrimaryStatus;
 return m;
 else
 return 0;
 初始化函数如下:
 uchar InitialTypeB_080(void)
 char status = MI_RESETERR;
 status = MCRReset_1();
 if (status == MI_OK)
 mrcreg.RegTxControl      =0x4B;         // (0x11) disable Force100ASk--ok  13.56MHz
 mrcreg.RegCwConductance  =0x3f ;   //     ÉèÖÃÊä³öÇý¶¯µÄµçµ¼ÏµÊý
 mrcreg.RegModConductance =0x03 ;   //0x06  ·ùÒÆ¼ü¿ØASk 12%
 mrcreg.RegCoderControl   =0x20;      //0x14  TypeB,²¨ÌØÂÊ106kbps, NRZ±àÂë ISO 14443B;NRZ acording ISO 14443B--ok
 mrcreg.RegTypeBFraming   =0x23;      //      ¶¨ÒåISO14443BÖ¡¸ñʽ
 mrcreg.RegDecoderControl =0x19;    //0x1a    ISO14443BÖ¡,BPSK±àÂë   TYPE_B ;BPSK Coding
 mrcreg.RegRxThreshold    =0xFF;       //KAI   ¿É½ÓÊÕµÄ×îСÐźÅÇ¿¶È
 mrcreg.RegBPSKDemControl =0x3e;    //0x1d    ºöÂÔEOF,´ò¿ª¸ßͨÂ˲¨ ignore EOF, on amp. detect
 mrcreg.RegClockQControl  =0x07;  //     QʱÖÓ¿ØÖÆ
 mrcreg.RegChannelRedundancy =0x20; // (0x22)RegChannelRedundancy
 mrcreg.RegRxWait         = 0x06;   //ÉèÖýÓÊÕÑÓʱ
 mrcreg.RegBitFraming    = 0x00;       // (0x0f)fangxiang
 mrcreg.RegRxControl1     =0x73;        // (0x19) 8 Pulses;GAIN 27 DB--ok
 mrcreg.RegRxControl2     =0x01;
 mrcreg.RegRxWait      =0x06;
 return(0);
 有做过的朋友,帮忙看下,是哪里设置有问题,谢啦
