- /*****************电子园PIC16F877A开发板 普通IO驱动74595实验***************
 - //PIC16F877A 实验板
 - //mcu: PIC16F877A  4MHz
 - //2010年7月10日21:52:30
 - #include <lian_pic.h>
 - __CONFIG(HS&WDTDIS&LVPDIS&PWRTEN);
 - //HS振荡,禁止看门狗,低压编程关闭,启动延时定时器
 - #define srclk RC3        //移位寄存器时钟 (74595:11脚)
 - #define rclk  RC4        //存储寄存器时钟 (74595:12脚)
 - #define ser   RC5        //串行数据口     (74595:14脚)
 -                          //oe:输出允许  L:允许输出;H:禁止输出;  (74595:13脚)
 -                          //srclr:移位寄存器清零 (L:清零) (74595:10脚)
 - const uchar smg_text[]={0xbf,0xfe,0xfb,0xef,0xdf,0x7f,0xfd,0xf7,};
 - const uchar smg[]={0x0a,0xfa,0x8c,0xa8,0x78,0x29,0x09,0xba,0x08,0x28,0x00,};
 -                   // 0     1    2    3    4    5    6    7    8    9   all
 - const uchar smg_bit[]={0x01,0x02,0x04,0x08,0x10,0x20,0x40,0x80,0xff,};
 - uchar c;
 - uchar d;
 - //********************函数定义*********************
 - void delay1ms(uint DelayTime);
 - void senddata_74595(uchar SendData);
