/*---------------------------------------------------------------------------------------------------------*/ /* */ /* Copyright(c) 2017 Nuvoton Technology Corp. All rights reserved. */ /* */ /*---------------------------------------------------------------------------------------------------------*/ //*********************************************************************************************************** // Nuvoton Technoledge Corp. // Website: http://www.nuvoton.com // E-Mail : MicroC-8bit@nuvoton.com // Date : Apr/21/2017 //*********************************************************************************************************** //*********************************************************************************************************** // File Function: N76E003 Timer2 Capture Mode demo code //*********************************************************************************************************** #include "N76E003.h" #include "Common.h" #include "Delay.h" #include "SFR_Macro.h" #include "Function_define.h" //***************** The Following is in define in Fucntion_define.h *************************** //****** Always include Function_define.h call the define you want, detail see main(void) ******* //*********************************************************************************************** #if 0 ////-------------------- Timer2 Capture define -------------------- ////--- Falling Edge ----- //#define IC0_P12_CAP0_FallingEdge_Capture CAPCON1&=0xFC;CAPCON3&=0xF0;CAPCON0|=SET_BIT4;CAPCON2|=SET_BIT4 //#define IC1_P11_CAP0_FallingEdge_Capture CAPCON1&=0xFC;CAPCON3&=0xF0;CAPCON3|=0x01;CAPCON0|=SET_BIT4;CAPCON2|=SET_BIT4 //#define IC2_P10_CAP0_FallingEdge_Capture CAPCON1&=0xFC;CAPCON3&=0xF0;CAPCON3|=0x02;CAPCON0|=SET_BIT4;CAPCON2|=SET_BIT4 //#define IC3_P00_CAP0_FallingEdge_Capture CAPCON1&=0xFC;CAPCON3&=0xF0;CAPCON3|=0x03;CAPCON0|=SET_BIT4;CAPCON2|=SET_BIT4 //#define IC3_P04_CAP0_FallingEdge_Capture CAPCON1&=0xFC;CAPCON3&=0xF0;CAPCON3|=0x04;CAPCON0|=SET_BIT4;CAPCON2|=SET_BIT4 //#define IC4_P01_CAP0_FallingEdge_Capture CAPCON1&=0xFC;CAPCON3&=0xF0;CAPCON3|=0x05;CAPCON0|=SET_BIT4;CAPCON2|=SET_BIT4 //#define IC5_P03_CAP0_FallingEdge_Capture CAPCON1&=0xFC;CAPCON3&=0xF0;CAPCON3|=0x06;CAPCON0|=SET_BIT4;CAPCON2|=SET_BIT4 //#define IC6_P05_CAP0_FallingEdge_Capture CAPCON1&=0xFC;CAPCON3&=0xF0;CAPCON3|=0x07;CAPCON0|=SET_BIT4;CAPCON2|=SET_BIT4 //#define IC7_P15_CAP0_FallingEdge_Capture CAPCON1&=0xFC;CAPCON3&=0xF0;CAPCON3|=0x08;CAPCON0|=SET_BIT4;CAPCON2|=SET_BIT4 //#define IC0_P12_CAP1_FallingEdge_Capture CAPCON1&=0xF3;CAPCON3&=0x0F;CAPCON0|=SET_BIT5;CAPCON2|=SET_BIT5 //#define IC1_P11_CAP1_FallingEdge_Capture CAPCON1&=0xF3;CAPCON3&=0x0F;CAPCON3|=0x10;CAPCON0|=SET_BIT5;CAPCON0|=SET_BIT5 //#define IC2_P10_CAP1_FallingEdge_Capture CAPCON1&=0xF3;CAPCON3&=0x0F;CAPCON3|=0x20;CAPCON0|=SET_BIT5;CAPCON2|=SET_BIT5 //#define IC3_P00_CAP1_FallingEdge_Capture CAPCON1&=0xF3;CAPCON3&=0x0F;CAPCON3|=0x30;CAPCON0|=SET_BIT5;CAPCON2|=SET_BIT5 //#define IC3_P04_CAP1_FallingEdge_Capture CAPCON1&=0xF3;CAPCON3&=0x0F;CAPCON3|=0x40;CAPCON0|=SET_BIT5;CAPCON2|=SET_BIT5 //#define IC4_P01_CAP1_FallingEdge_Capture CAPCON1&=0xF3;CAPCON3&=0x0F;CAPCON3|=0x50;CAPCON0|=SET_BIT5;CAPCON2|=SET_BIT5 //#define IC5_P03_CAP1_FallingEdge_Capture CAPCON1&=0xF3;CAPCON3&=0x0F;CAPCON3|=0x60;CAPCON0|=SET_BIT5;CAPCON2|=SET_BIT5 //#define IC6_P05_CAP1_FallingEdge_Capture CAPCON1&=0xF3;CAPCON3&=0x0F;CAPCON3|=0x70;CAPCON0|=SET_BIT5;CAPCON2|=SET_BIT5 //#define IC7_P15_CAP1_FallingEdge_Capture CAPCON1&=0xF3;CAPCON3&=0x0F;CAPCON3|=0x80;CAPCON0|=SET_BIT5;CAPCON2|=SET_BIT5 //#define IC0_P12_CAP2_FallingEdge_Capture CAPCON1&=0x0F;CAPCON4&=0xF0;CAPCON0|=SET_BIT6;CAPCON2|=SET_BIT6 //#define IC1_P11_CAP2_FallingEdge_Capture CAPCON1&=0x0F;CAPCON4&=0xF0;CAPCON4|=0x10;CAPCON0|=SET_BIT6;CAPCON2|=SET_BIT6 //#define IC2_P10_CAP2_FallingEdge_Capture CAPCON1&=0x0F;CAPCON4&=0xF0;CAPCON4|=0x20;CAPCON0|=SET_BIT6;CAPCON2|=SET_BIT6 //#define IC3_P00_CAP2_FallingEdge_Capture CAPCON1&=0x0F;CAPCON4&=0xF0;CAPCON4|=0x30;CAPCON0|=SET_BIT6;CAPCON2|=SET_BIT6 //#define IC3_P04_CAP2_FallingEdge_Capture CAPCON1&=0x0F;CAPCON4&=0xF0;CAPCON4|=0x40;CAPCON0|=SET_BIT6;CAPCON2|=SET_BIT6 //#define IC4_P01_CAP2_FallingEdge_Capture CAPCON1&=0x0F;CAPCON4&=0xF0;CAPCON4|=0x50;CAPCON0|=SET_BIT6;CAPCON2|=SET_BIT6 //#define IC5_P03_CAP2_FallingEdge_Capture CAPCON1&=0x0F;CAPCON4&=0xF0;CAPCON4|=0x60;CAPCON0|=SET_BIT6;CAPCON2|=SET_BIT6 //#define IC6_P05_CAP2_FallingEdge_Capture CAPCON1&=0x0F;CAPCON4&=0xF0;CAPCON4|=0x70;CAPCON0|=SET_BIT6;CAPCON2|=SET_BIT6 //#define IC7_P15_CAP2_FallingEdge_Capture CAPCON1&=0x0F;CAPCON4&=0xF0;CAPCON4|=0x80;CAPCON0|=SET_BIT6;CAPCON2|=SET_BIT6 ////----- Rising edge ---- //#define IC0_P12_CAP0_RisingEdge_Capture CAPCON1&=0xFC;CAPCON1|=0x01;CAPCON3&=0xF0CAPCON0|=SET_BIT4;CAPCON2|=SET_BIT4; //#define IC1_P11_CAP0_RisingEdge_Capture CAPCON1&=0xFC;CAPCON1|=0x01;CAPCON3&=0xF0;CAPCON3|=0x01;CAPCON0|=SET_BIT4;CAPCON2|=SET_BIT4; //#define IC2_P10_CAP0_RisingEdge_Capture CAPCON1&=0xFC;CAPCON1|=0x01;CAPCON3&=0xF0;CAPCON3|=0x02;CAPCON0|=SET_BIT4;CAPCON2|=SET_BIT4; //#define IC3_P00_CAP0_RisingEdge_Capture CAPCON1&=0xFC;CAPCON1|=0x01;CAPCON3&=0xF0;CAPCON3|=0x03;CAPCON0|=SET_BIT4;CAPCON2|=SET_BIT4; //#define IC3_P04_CAP0_RisingEdge_Capture CAPCON1&=0xFC;CAPCON1|=0x01;CAPCON3&=0xF0;CAPCON3|=0x04;CAPCON0|=SET_BIT4;CAPCON2|=SET_BIT4; //#define IC4_P01_CAP0_RisingEdge_Capture CAPCON1&=0xFC;CAPCON1|=0x01;CAPCON3&=0xF0;CAPCON3|=0x05;CAPCON0|=SET_BIT4;CAPCON2|=SET_BIT4; //#define IC5_P03_CAP0_RisingEdge_Capture CAPCON1&=0xFC;CAPCON1|=0x01;CAPCON3&=0xF0;CAPCON3|=0x06;CAPCON0|=SET_BIT4;CAPCON2|=SET_BIT4; //#define IC6_P05_CAP0_RisingEdge_Capture CAPCON1&=0xFC;CAPCON1|=0x01;CAPCON3&=0xF0;CAPCON3|=0x07;CAPCON0|=SET_BIT4;CAPCON2|=SET_BIT4; //#define IC7_P15_CAP0_RisingEdge_Capture CAPCON1&=0xFC;CAPCON1|=0x01;CAPCON3&=0xF0;CAPCON3|=0x08;CAPCON0|=SET_BIT4;CAPCON2|=SET_BIT4; //#define IC0_P12_CAP1_RisingEdge_Capture CAPCON1&=0xF3;CAPCON1|=0x04;CAPCON3&=0x0FCAPCON0|=SET_BIT5;CAPCON2|=SET_BIT5; //#define IC1_P11_CAP1_RisingEdge_Capture CAPCON1&=0xF3;CAPCON1|=0x04;CAPCON3&=0x0F;CAPCON3|=0x10;CAPCON0|=SET_BIT5;CAPCON2|=SET_BIT5; //#define IC2_P10_CAP1_RisingEdge_Capture CAPCON1&=0xF3;CAPCON1|=0x04;CAPCON3&=0x0F;CAPCON3|=0x20;CAPCON0|=SET_BIT5;CAPCON2|=SET_BIT5; //#define IC3_P00_CAP1_RisingEdge_Capture CAPCON1&=0xF3;CAPCON1|=0x04;CAPCON3&=0x0F;CAPCON3|=0x30;CAPCON0|=SET_BIT5;CAPCON2|=SET_BIT5; //#define IC3_P04_CAP1_RisingEdge_Capture CAPCON1&=0xF3;CAPCON1|=0x04;CAPCON3&=0x0F;CAPCON3|=0x40;CAPCON0|=SET_BIT5;CAPCON2|=SET_BIT5; //#define IC4_P01_CAP1_RisingEdge_Capture CAPCON1&=0xF3;CAPCON1|=0x04;CAPCON3&=0x0F;CAPCON3|=0x50;CAPCON0|=SET_BIT5;CAPCON2|=SET_BIT5; //#define IC5_P03_CAP1_RisingEdge_Capture CAPCON1&=0xF3;CAPCON1|=0x04;CAPCON3&=0x0F;CAPCON3|=0x60;CAPCON0|=SET_BIT5;CAPCON2|=SET_BIT5; //#define IC6_P05_CAP1_RisingEdge_Capture CAPCON1&=0xF3;CAPCON1|=0x04;CAPCON3&=0x0F;CAPCON3|=0x70;CAPCON0|=SET_BIT5;CAPCON2|=SET_BIT5; //#define IC7_P15_CAP1_RisingEdge_Capture CAPCON1&=0xF3;CAPCON1|=0x04;CAPCON3&=0x0F;CAPCON3|=0x80;CAPCON0|=SET_BIT5;CAPCON2|=SET_BIT5; //#define IC0_P12_CAP3_RisingEdge_Capture CAPCON1&=0x0F;CAPCON1|=0x10;CAPCON4&=0xF0;CAPCON0|=SET_BIT6;CAPCON2|=SET_BIT6; //#define IC1_P11_CAP3_RisingEdge_Capture CAPCON1&=0x0F;CAPCON1|=0x10;CAPCON4&=0xF0;CAPCON4|=0x01;CAPCON0|=SET_BIT6;CAPCON2|=SET_BIT6; //#define IC2_P10_CAP3_RisingEdge_Capture CAPCON1&=0x0F;CAPCON1|=0x10;CAPCON4&=0xF0;CAPCON4|=0x02;CAPCON0|=SET_BIT6;CAPCON2|=SET_BIT6; //#define IC3_P00_CAP3_RisingEdge_Capture CAPCON1&=0x0F;CAPCON1|=0x10;CAPCON4&=0xF0;CAPCON4|=0x03;CAPCON0|=SET_BIT6;CAPCON2|=SET_BIT6; //#define IC3_P04_CAP3_RisingEdge_Capture CAPCON1&=0x0F;CAPCON1|=0x10;CAPCON4&=0xF0;CAPCON4|=0x04;CAPCON0|=SET_BIT6;CAPCON2|=SET_BIT6; //#define IC4_P01_CAP3_RisingEdge_Capture CAPCON1&=0x0F;CAPCON1|=0x10;CAPCON4&=0xF0;CAPCON4|=0x05;CAPCON0|=SET_BIT6;CAPCON2|=SET_BIT6; //#define IC5_P03_CAP3_RisingEdge_Capture CAPCON1&=0x0F;CAPCON1|=0x10;CAPCON4&=0xF0;CAPCON4|=0x06;CAPCON0|=SET_BIT6;CAPCON2|=SET_BIT6; //#define IC6_P05_CAP3_RisingEdge_Capture CAPCON1&=0x0F;CAPCON1|=0x10;CAPCON4&=0xF0;CAPCON4|=0x07;CAPCON0|=SET_BIT6;CAPCON2|=SET_BIT6; //#define IC7_P15_CAP3_RisingEdge_Capture CAPCON1&=0x0F;CAPCON1|=0x10;CAPCON4&=0xF0;CAPCON4|=0x08;CAPCON0|=SET_BIT6;CAPCON2|=SET_BIT6; ////-----BOTH edge ---- //#define IC0_P12_CAP0_BothEdge_Capture CAPCON1&=0xFC;CAPCON1|=0x02;CAPCON3&=0xF0;CAPCON0|=SET_BIT4;CAPCON2|=SET_BIT4 //#define IC1_P11_CAP0_BothEdge_Capture CAPCON1&=0xFC;CAPCON1|=0x02;CAPCON3&=0xF0;CAPCON3|=0x01;CAPCON0|=SET_BIT4;CAPCON2|=SET_BIT4 //#define IC2_P10_CAP0_BothEdge_Capture CAPCON1&=0xFC;CAPCON1|=0x02;CAPCON3&=0xF0;CAPCON3|=0x02;CAPCON0|=SET_BIT4;CAPCON2|=SET_BIT4 //#define IC3_P00_CAP0_BothEdge_Capture CAPCON1&=0xFC;CAPCON1|=0x02;CAPCON3&=0xF0;CAPCON3|=0x03;CAPCON0|=SET_BIT4;CAPCON2|=SET_BIT4 //#define IC3_P04_CAP0_BothEdge_Capture CAPCON1&=0xFC;CAPCON1|=0x02;CAPCON3&=0xF0;CAPCON3|=0x04;CAPCON0|=SET_BIT4;CAPCON2|=SET_BIT4 //#define IC4_P01_CAP0_BothEdge_Capture CAPCON1&=0xFC;CAPCON1|=0x02;CAPCON3&=0xF0;CAPCON3|=0x05;CAPCON0|=SET_BIT4;CAPCON2|=SET_BIT4 //#define IC5_P03_CAP0_BothEdge_Capture CAPCON1&=0xFC;CAPCON1|=0x02;CAPCON3&=0xF0;CAPCON3|=0x06;CAPCON0|=SET_BIT4;CAPCON2|=SET_BIT4 //#define IC6_P05_CAP0_BothEdge_Capture CAPCON1&=0xFC;CAPCON1|=0x02;CAPCON3&=0xF0;CAPCON3|=0x07;CAPCON0|=SET_BIT4;CAPCON2|=SET_BIT4 //#define IC7_P15_CAP0_BothEdge_Capture CAPCON1&=0xFC;CAPCON1|=0x02;CAPCON3&=0xF0;CAPCON3|=0x08;CAPCON0|=SET_BIT4;CAPCON2|=SET_BIT4 //#define IC0_P12_CAP1_BothEdge_Capture CAPCON1&=0xF3;CAPCON1|=0x08;CAPCON3&=0x0F;CAPCON0|=SET_BIT5;CAPCON2|=SET_BIT5 //#define IC1_P11_CAP1_BothEdge_Capture CAPCON1&=0xF3;CAPCON1|=0x08;CAPCON3&=0x0F;CAPCON3|=0x10;CAPCON0|=SET_BIT5;CAPCON2|=SET_BIT5; //#define IC2_P10_CAP1_BothEdge_Capture CAPCON1&=0xF3;CAPCON1|=0x08;CAPCON3&=0x0F;CAPCON3|=0x20;CAPCON0|=SET_BIT5;CAPCON2|=SET_BIT5; //#define IC3_P00_CAP1_BothEdge_Capture CAPCON1&=0xF3;CAPCON1|=0x08;CAPCON3&=0x0F;CAPCON3|=0x30;CAPCON0|=SET_BIT5;CAPCON2|=SET_BIT5; //#define IC3_P04_CAP1_BothEdge_Capture CAPCON1&=0xF3;CAPCON1|=0x08;CAPCON3&=0x0F;CAPCON3|=0x40;CAPCON0|=SET_BIT5;CAPCON2|=SET_BIT5; //#define IC4_P01_CAP1_BothEdge_Capture CAPCON1&=0xF3;CAPCON1|=0x08;CAPCON3&=0x0F;CAPCON3|=0x50;CAPCON0|=SET_BIT5;CAPCON2|=SET_BIT5; //#define IC5_P03_CAP1_BothEdge_Capture CAPCON1&=0xF3;CAPCON1|=0x08;CAPCON3&=0x0F;CAPCON3|=0x60;CAPCON0|=SET_BIT5;CAPCON2|=SET_BIT5; //#define IC6_P05_CAP1_BothEdge_Capture CAPCON1&=0xF3;CAPCON1|=0x08;CAPCON3&=0x0F;CAPCON3|=0x70;CAPCON0|=SET_BIT5;CAPCON2|=SET_BIT5; //#define IC7_P15_CAP1_BothEdge_Capture CAPCON1&=0xF3;CAPCON1|=0x08;CAPCON3&=0x0F;CAPCON3|=0x80;CAPCON0|=SET_BIT5;CAPCON2|=SET_BIT5; //#define IC0_P12_CAP3_BothEdge_Capture CAPCON1&=0x0F;CAPCON1|=0x20;CAPCON4&=0xF0;CAPCON0|=SET_BIT6;CAPCON2|=SET_BIT6; //#define IC1_P11_CAP3_BothEdge_Capture CAPCON1&=0x0F;CAPCON1|=0x20;CAPCON4&=0xF0;CAPCON4|=0x01;CAPCON0|=SET_BIT6;CAPCON2|=SET_BIT6; //#define IC2_P10_CAP3_BothEdge_Capture CAPCON1&=0x0F;CAPCON1|=0x20;CAPCON4&=0xF0;CAPCON4|=0x02;CAPCON0|=SET_BIT6;CAPCON2|=SET_BIT6; //#define IC3_P00_CAP3_BothEdge_Capture CAPCON1&=0x0F;CAPCON1|=0x20;CAPCON4&=0xF0;CAPCON4|=0x03;CAPCON0|=SET_BIT6;CAPCON2|=SET_BIT6; //#define IC3_P04_CAP3_BothEdge_Capture CAPCON1&=0x0F;CAPCON1|=0x20;CAPCON4&=0xF0;CAPCON4|=0x04;CAPCON0|=SET_BIT6;CAPCON2|=SET_BIT6; //#define IC4_P01_CAP3_BothEdge_Capture CAPCON1&=0x0F;CAPCON1|=0x20;CAPCON4&=0xF0;CAPCON4|=0x05;CAPCON0|=SET_BIT6;CAPCON2|=SET_BIT6; //#define IC5_P03_CAP3_BothEdge_Capture CAPCON1&=0x0F;CAPCON1|=0x20;CAPCON4&=0xF0;CAPCON4|=0x06;CAPCON0|=SET_BIT6;CAPCON2|=SET_BIT6; //#define IC6_P05_CAP3_BothEdge_Capture CAPCON1&=0x0F;CAPCON1|=0x20;CAPCON4&=0xF0;CAPCON4|=0x07;CAPCON0|=SET_BIT6;CAPCON2|=SET_BIT6; //#define IC7_P15_CAP3_BothEdge_Capture CAPCON1&=0x0F;CAPCON1|=0x20;CAPCON4&=0xF0;CAPCON4|=0x08;CAPCON0|=SET_BIT6;CAPCON2|=SET_BIT6; //#define TIMER2_IC2_DISABLE CAPCON0&=~SET_BIT6 //#define TIMER2_IC1_DISABLE CAPCON0&=~SET_BIT5 //#define TIMER2_IC0_DISABLE CAPCON0&=~SET_BIT4 ///*---------------------------------------------------------------------------------------------------------- //* Timer2 mode define //------------------------------------------------------------------------------------------------------------*/ //#define TIMER2_CAP0_Capture_Mode T2CON&=~SET_BIT0;T2MOD=0x89 //#define TIMER2_CAP1_Capture_Mode T2CON&=~SET_BIT0;T2MOD=0x8A //#define TIMER2_CAP2_Capture_Mode T2CON&=~SET_BIT0;T2MOD=0x8B ///*---------------------------------------------------------------------------------------------------------- //* Timer devider define //----------------------------------------------------------------------------------------------------------*/ //#define TIMER2_DIV_4 T2MOD|=0x10;T2MOD&=0x9F //#define TIMER2_DIV_16 T2MOD|=0x20;T2MOD&=0xAF //#define TIMER2_DIV_32 T2MOD|=0x30;T2MOD&=0xBF //#define TIMER2_DIV_64 T2MOD|=0x40;T2MOD&=0xCF //#define TIMER2_DIV_128 T2MOD|=0x50;T2MOD&=0xDF //#define TIMER2_DIV_256 T2MOD|=0x60;T2MOD&=0xEF //#define TIMER2_DIV_512 T2MOD|=0x70 #endif /************************************************************************************************************ * Timer2 Capture interrupt subroutine ************************************************************************************************************/ void Capture_ISR (void) interrupt 12 { clr_CAPF0; // clear capture0 interrupt flag P1 = C0L; // For capture mode CxL/CxH with data capture from I/O pin P2 = C0H; P12 = ~P12; //toggle GPIO1 to show int printf("\n TM2 CAP 0x%bX",C0H); clr_TF2; } /************************************************************************************************************ * Main function ************************************************************************************************************/ void main (void) { Set_All_GPIO_Quasi_Mode; InitialUART0_Timer3(115200); P00_Input_Mode; P00 = 1; TIMER2_CAP0_Capture_Mode; IC3_P00_CAP0_BothEdge_Capture; set_ECAP; //Enable Capture interrupt set_TR2; //Triger Timer2 set_EA; while(1); }
收藏0 举报
本版积分规则 发表回复 回帖并转播 回帖后跳转到最后一页
等级类勋章
发帖类勋章
时间类勋章
人才类勋章
21
132
扫码关注 21ic 官方微信
扫码关注嵌入式微处理器
扫码关注电源系统设计
扫码关注21ic项目外包
扫码浏览21ic手机版
本站介绍 | 申请友情链接 | 欢迎投稿 | 隐私声明 | 广告业务 | 网站地图 | 联系我们 | 诚聘英才
京公网安备 11010802024343号
