EXTI中断KEY1正常,KEY2不正常,请帮忙看一下是程序哪里有问题?
598|2
 楼主| 菊江先生 发表于 2020-4-2 11:48 | 显示全部楼层 |阅读模式
TI, pi, IO, GPIO, gp
/*bsp_exti.c文件*/
#include "bsp_exti.h"
static void EXIT_NVIC_Config(void)
  NVIC_InitTypeDef NVIC_InitStruct;
   NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1);
   NVIC_InitStruct.NVIC_IRQChannel=EXTI0_IRQn;
   NVIC_InitStruct.NVIC_IRQChannelPreemptionPriority=1;
   NVIC_InitStruct.NVIC_IRQChannelSubPriority=1;
   NVIC_InitStruct.NVIC_IRQChannelCmd=ENABLE;
   NVIC_Init(&NVIC_InitStruct);
   NVIC_InitStruct.NVIC_IRQChannel=EXTI15_10_IRQn;
void EXIT_Key_Config(void)
  EXTI_InitTypeDef EXTI_InitStructure;
   /*配置中断优先级*/
   EXIT_NVIC_Config();
   /*初始化KEY1要连接到EXTI的GPIO*/
   RCC_APB2PeriphClockCmd(KEY1_INT_GPIO_CLK,ENABLE);
   GPIO_InitStructure.GPIO_Pin = KEY1_INT_GPIO_PIN;
   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
   GPIO_Init(KEY1_INT_GPIO_PORT, &GPIO_InitStructure);
    /*初始化KEY2要连接到EXTI的GPIO*/
   RCC_APB2PeriphClockCmd(KEY2_INT_GPIO_CLK,ENABLE);
   GPIO_InitStructure.GPIO_Pin = KEY2_INT_GPIO_PIN;
  GPIO_Init(KEY2_INT_GPIO_PORT, &GPIO_InitStructure);
   GPIO_EXTILineConfig(GPIO_PortSourceGPIOA, GPIO_PinSource0);
  EXTI_InitStructure.EXTI_Line=EXTI_Line0;
   EXTI_InitStructure.EXTI_LineCmd=ENABLE;
   EXTI_InitStructure.EXTI_Mode=EXTI_Mode_Interrupt;
   EXTI_InitStructure.EXTI_Trigger=EXTI_Trigger_Rising;
  EXTI_Init(&EXTI_InitStructure);
  GPIO_EXTILineConfig(GPIO_PortSourceGPIOC, GPIO_PinSource13);
   EXTI_InitStructure.EXTI_Line = EXTI_Line13;
    EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt;
    EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Rising;
    EXTI_InitStructure.EXTI_LineCmd = ENABLE;
/*bsp_exti.h文件*/
#ifndef _BSP_EXTI_H
#define _BSP_EXTI_H
#include "stm32f10x.h"
/*KEY1有关的接口宏定义*/
#define KEY1_INT_GPIO_PORT     GPIOA
#define KEY1_INT_GPIO_CLK      RCC_APB2Periph_GPIOA
#define KEY1_INT_GPIO_PIN      GPIO_Pin_0
#define KEY2_INT_GPIO_PORT     GPIOC
#define KEY2_INT_GPIO_CLK      RCC_APB2Periph_GPIOC
#define KEY2_INT_GPIO_PIN      GPIO_Pin_13
void EXIT_Key_Config(void);
#endif /* _BSP_EXTI_H*/
/*stm32F10x_it.c文件*/
void SysTick_Handler(void)
void EXTI0_IRQHandler(void)
  if(EXTI_GetITStatus(EXTI_Line0)!=RESET)
         LED1_TOGGLE;
  EXTI_ClearITPendingBit(EXTI_Line0);
void EXTI15_10_IRQHandler(void)
  if(EXTI_GetITStatus(EXTI_Line13)!=RESET)
        LED2_TOGGLE;
  EXTI_ClearITPendingBit(EXTI_Line13);
程序运行KEY1正常,KEY2无响应,请问是为什么?
dirtwillfly 发表于 2020-4-2 20:21 | 显示全部楼层
这是stm32吗?具体什么型号?是不是EXTI15_10_IRQn错了?
光轮TreeOS 发表于 2020-4-3 09:53 | 显示全部楼层
  EXTI15_10_IRQn的 NVIC_InitStruct.NVIC_IRQChannelCmd=ENABLE;没使能吧。
看看是不是这问题。
