| MEMORY {
 VECTORS:
 o = 0x00800000  l = 0x00000400
 /*vectors*/
 L2RAM:      o = 0x00800400  l = 0x001FFC00  /* 2MB L2 Internal SRAM */
 L1PRAM:     o = 0x00E00000  l = 0x00008000  /* 32kB L1 Program SRAM/CACHE */
 L1DRAM:     o = 0x00F00000  l = 0x00008000  /* 32kB L1 Data SRAM/CACHE */
 EMIFA_CE2:  o = 0xA0000000  l = 0x00800000  /* 8MB EMIFA CE2 */
 EMIFA_CE3:  o = 0xB0000000  l = 0x00800000  /* 8MB EMIFA CE2 */
 EMIFA_CE4:  o = 0xC0000000  l = 0x00800000  /* 8MB EMIFA CE2 */
 EMIFA_CE5:  o = 0xD0000000  l = 0x00800000  /* 8MB EMIFA CE2 */
 DDR2_CE0:   o = 0xE0000000  l = 0x20000000  /* 512MB EMIFB CE0 */
 中断向量表:
 .sect".vecs"
 .ref _c_int00
 .ref _c_int04                ;ref the function defined in C file
 .align 1024
 _vectors:
 _vector0:       VEC_ENTRY _c_int00   ;RESET中断
 _vector1:       VEC_ENTRY _vec_dummy ;NMI不可屏蔽中断
 _vector2:       VEC_ENTRY _vec_dummy ;保留中断1
 _vector3:       VEC_ENTRY _vec_dummy ;保留中断2
 _vector4:       VEC_ENTRY _c_int04   ;对应于c_int04 ISR
 _vector5:       VEC_ENTRY _vec_dummy ;外部中断INT5
 _vector6:       VEC_ENTRY _vec_dummy ;外部中断INT6
 _vector7:       VEC_ENTRY _vec_dummy ;外部中断INT7
 _vector8:       VEC_ENTRY _vec_dummy ;外部中断INT8
 _vector9:       VEC_ENTRY _vec_dummy ;JTAGRTDX中断
 _vector10:      VEC_ENTRY _vec_dummy ;EMIF_SDRAM_Timer中断
 _vector11:      VEC_ENTRY _vec_dummy ;McBSP_0_Receive中断
 _vector12:      VEC_ENTRY _vec_dummy ;McBSP_1_Transmit中断
 _vector13:      VEC_ENTRY _vec_dummy ;Host_Port_Host_to_DSP中断
 _vector14:      VEC_ENTRY _vec_dummy ;Timer0中断
 _vector15:      VEC_ENTRY _vec_dummy ;Timer1中断
 中断初始化:
 void InitInterrupt(void)
 unsigned int temp;
 *IECRH = 0xFFFFFFFF;  // IECRH (disable high interrupts enable)
 *EECRH = 0xFFFFFFFF; // EECRH (disable high events enable)
 *ICRH  = 0xFFFFFFFF;  // ICRH  (clear high interrupts pending)
 *ECRH  = 0xFFFFFFFF;  // ECRH  (clear high events pending)
 *IECR  = 0xFFFFFFFF;  // IECR  (disable low interrupts enable)
 *EECR  = 0xFFFFFFFF;  // EECR  (disable low events enable)
 *EICR  = 0xFFFFFFFF;  // ICR   (clear low interrupts pending)
 *ECR   = 0xFFFFFFFF;  // ECR   (clear low events pending)
 *EVTMASK0 = 0xffffffff;//disable combine
 *EVTMASK1 = 0xffffffff;
 *EVTMASK2 = 0xffffffff;
 *EVTMASK3 = 0xffffffff;
 *EVTCLR0 |= 0xfffffff;
 *EVTCLR1 |= 0xfffffff;
 *EVTCLR2 |= 0xfffffff;//clear all event(including 66) flag before the new interrupt come
 *EVTCLR3 |= 0xfffffff;
 temp = *EVTFLAG2;
 ICR = 0xfffffffe;
 //clear IFR
 asm( " NOP");
 asm( " NOP");
 *INTMUX1 |= 0x00000037;//55对应到INT04
 *INTMUX1 &= 0xffff0037;
 *INTMUX1 |= 0x00000042;//INT04 responding to event 66,GPIO 15
 *INTMUX1 &= 0xffff0042;
 IER |= 0x00000012;   // IE4=1,NMIE=1
 ISTP = 0x00800080;
 *EVTSET1 |= 0x00800000;//55
 *EVTSET2 |= 0x00000004;//set interrupt 66,only for test,zdx
 CSR |= 0x00000001;
 // enable GIE
 //*EVTSET2=0x0000;
