uint8_t I2C_ByteWrite(uint8_t WriteDatas,uint8_t WriteAddr){
I2C_GenerateSTART(EEPROM_I2Cx, ENABLE);
I2CTimeout = I2CT_FLAG_TIMEOUT;
/* Test on EV5 and clear it */
while(!I2C_CheckEvent(EEPROM_I2Cx, I2C_EVENT_MASTER_MODE_SELECT))
if((I2CTimeout--) == 0) return I2C_TIMEOUT_UserCallback(0);
/* Send EEPROM address for write */
I2C_Send7bitAddress(EEPROM_I2Cx, EEPROM_ADDRESS, I2C_Direction_Transmitter);
/* Test on EV6 and clear it */
while(!I2C_CheckEvent(EEPROM_I2Cx, I2C_EVENT_MASTER_TRANSMITTER_MODE_SELECTED))
if((I2CTimeout--) == 0) return I2C_TIMEOUT_UserCallback(1);
/* Send the EEPROM's internal address to write to */
I2C_SendData(EEPROM_I2Cx, WriteAddr);
/* Test on EV8 and clear it */
while(!I2C_CheckEvent(EEPROM_I2Cx, I2C_EVENT_MASTER_BYTE_TRANSMITTED))
if((I2CTimeout--) == 0) return I2C_TIMEOUT_UserCallback(2);
/* Send the byte to be written */
I2C_SendData(EEPROM_I2Cx,WriteAddr);
if((I2CTimeout--) == 0) return I2C_TIMEOUT_UserCallback(3);
/* Send STOP condition */
I2C_GenerateSTOP(EEPROM_I2Cx, ENABLE);
return 1;
uint8_t Current_Address_Read(uint8_t ReadDatas,uint8_t ReadAddr)
if((I2CTimeout--) == 0) return I2C_TIMEOUT_UserCallback(4);
I2C_Send7bitAddress(EEPROM_I2Cx, EEPROM_ADDRESS, I2C_Direction_Receiver);
while(!I2C_CheckEvent(EEPROM_I2Cx, I2C_EVENT_MASTER_RECEIVER_MODE_SELECTED)) ||程序停在这里
if((I2CTimeout--) == 0) return I2C_TIMEOUT_UserCallback(5);
while(I2C_CheckEvent(EEPROM_I2Cx, I2C_EVENT_MASTER_BYTE_RECEIVED)==0)
if((I2CTimeout--) == 0) return I2C_TIMEOUT_UserCallback(6);
ReadDatas=I2C_ReceiveData(EEPROM_I2Cx);
/* Disable Acknowledgement */
I2C_AcknowledgeConfig(EEPROM_I2Cx, DISABLE);
/* Send STOP Condition */
return 1;
int main(void)
uint8_t read;
USART_Config();
LED_GPIO_Config();
I2C_EE_Init();
I2C_ByteWrite(10,EEP_Firstpage);
Current_Address_Read(read,EEP_Firstpage);
if(read==10)
LED_G(on);
}else
LED_R(on);
while (1)
程序总是停在读EEPROM的过程传递I2C设备地址,不能继续往下执行,求解,把例程也看几遍,也想不出问题在哪。 |
