STM32L152 USB问题
686|0
 楼主| 你画我瞎 发表于 2020-4-26 14:22 | 显示全部楼层 |阅读模式
while(1)
          if(index == 0)
                        printf("temp=%0.3f\r\n",g_temperature);
                        Delay_ms(500);
                        sendData.head = 0x54;
                        sendData.cmd = 0x58;
                        sendData.data_len = sizeof(UsbSendData);
                        sendData.temperature = g_temperature;
                        sendData.** = g_fTemp;
                        sendData.exp_freq = g_para_cfg.current_freq;
                        sendData.exp_time = g_para_cfg.current_pulse;
                        sendData.current_pulse = g_para_cfg.mh7139_current_value;
                        sendData.vol_pulse = 0;
                        sendData.vcsel_state = g_para_cfg.enable;
                        memcpy(Temp_Buffer, &sendData, sizeof(sendData));
                if (PrevXferComplete)
                        if(index < sizeof(UsbSendData))
                                Send_Buffer[0] = 0x05;
                                Send_Buffer[1] = Temp_Buffer[index];
                                UserToPMABufferCopy(Send_Buffer, ENDP1_TXADDR, 2);
                                SetEPTxCount(ENDP1, 2);
                                SetEPTxValid(ENDP1);
                                index++;
                                if(index == sizeof(UsbSendData))
                                        index = 0;
                                printf("index = %d\n",index);
                                PrevXferComplete = 0;
}请问下为什么在INDEX==0这里我把延迟加到Delay_ms(500);USB传输就正常,如果更改为Delay_ms(50);或者在        if(index == sizeof(UsbSendData))
                                        index = 0;
                                printf("index = %d\n",index);增加打印语句USB传输就不正常。 还有HID USB方式是不是不支持应答方式传输数据?
void EP1_IN_Callback(void)
        PrevXferComplete = 1;}  EP1_IN_Callback 什么时候才会被调用?
