【GD32评测】一、外部中断
1267|1
 楼主| Cjy_JDxy 发表于 2020-4-26 18:50 | 显示全部楼层 |阅读模式
板子到了,感觉很不错。一个精致的白盒子,还有一根线,板子也白白的,像个
穿白衣服的少女,我喜欢。
装了KEIL支持包
打开外部中断工程,设置如下
原理图:
代码:
#include "gd32e23x.h"
#include "gd32e231c_start.h"
#include "systick.h"
void led_config(void);
void led_flash(int times);
void exti_config(void);
void gpio_config(void);
void timer_config(void);
    \brief      main function
    \param[in]  none
    \param[out] none
    \retval     none
int main(void)
    /* initialize KEY and LED, configure SysTick */
    gd_eval_key_init(KEY_WAKEUP, KEY_MODE_EXTI);
    led_config();
    systick_config();
    /* flash the LED for test */
    led_flash(1);
    /* configure EXTI, TIMER */
    exti_config();
    gpio_config();
    timer_config();
    while(1){
    \brief      configure the LEDs
    \param[in]  none
    \param[out] none
    \retval     none
    gd_eval_led_init(LED1);
    \brief      configure the EXTI(PA5)
    \param[in]  none
    \param[out] none
    \retval     none
    /* enable the clock */
    rcu_periph_clock_enable(RCU_GPIOA);
    rcu_periph_clock_enable(RCU_CFGCMP);
    /* configure GPIO as input */
    gpio_mode_set(GPIOA, GPIO_MODE_INPUT, GPIO_PUPD_PULLUP, GPIO_PIN_5);
    /* enable and set EXTI interrupt */
    nvic_irq_enable(EXTI4_15_IRQn, 1U);
    /* connect EXTI line to GPIO pin */
    syscfg_exti_line_config(EXTI_SOURCE_GPIOA, EXTI_SOURCE_PIN5);
    /* configure EXTI line */
    exti_init(EXTI_5, EXTI_INTERRUPT, EXTI_TRIG_FALLING);
    exti_interrupt_flag_clear(EXTI_5);
    \brief      configure the GPIO ports
    \param[in]  none
    \param[out] none
    \retval     none
    /* configure PA6(TIMER2 CH0) as alternate function */
    gpio_mode_set(GPIOA, GPIO_MODE_AF, GPIO_PUPD_NONE, GPIO_PIN_6);
    gpio_output_options_set(GPIOA, GPIO_OTYPE_PP, GPIO_OSPEED_50MHZ,GPIO_PIN_6);
    gpio_af_set(GPIOA, GPIO_AF_1, GPIO_PIN_6);
    \brief      configure the TIMER peripheral
    \param[in]  none
    \param[out] none
    \retval     none
    TIMER2CLK is 100KHz
    TIMER2 channel0 duty cycle = (25000/ 50000)* 100  = 50%
    timer_oc_parameter_struct timer_ocintpara;
    timer_parameter_struct timer_initpara;
    rcu_periph_clock_enable(RCU_TIMER2);
    timer_deinit(TIMER2);
    /* TIMER configuration */
    timer_initpara.prescaler         = 719;
    timer_initpara.alignedmode       = TIMER_COUNTER_EDGE;
    timer_initpara.counterdirection  = TIMER_COUNTER_UP;
    timer_initpara.period            = 49999;
    timer_initpara.clockdivision     = TIMER_CKDIV_DIV1;
    timer_initpara.repetitioncounter = 0;
    timer_init(TIMER2,&timer_initpara);
    /* configurate CH0 in PWM mode0 */
    timer_ocintpara.ocpolarity  = TIMER_OC_POLARITY_HIGH;
    timer_ocintpara.outputstate = TIMER_CCX_ENABLE;
    timer_channel_output_config(TIMER2,TIMER_CH_0,&timer_ocintpara);
    timer_channel_output_pulse_value_config(TIMER2,TIMER_CH_0,24999);
    timer_channel_output_mode_config(TIMER2,TIMER_CH_0,TIMER_OC_MODE_PWM0);
    timer_channel_output_shadow_config(TIMER2,TIMER_CH_0,TIMER_OC_SHADOW_DISABLE);
    /* auto-reload preload enable */
    timer_auto_reload_shadow_enable(TIMER2);
    timer_enable(TIMER2);
    \brief      flash the LED for test
    \param[in]  times: times to flash the LED
    \param[out] none
    \retval     none
    int i;
    for (i = 0;i < times;i++){
        /* delay 500 ms */
        delay_1ms(500);
        /* toggle the LED */
        gd_eval_led_toggle(LED1);
        /* delay 500 ms */
        delay_1ms(500);
效果图:
工程
EXIT.rar (610.04 KB, 下载次数: 3)
21ic小喇叭 发表于 2020-4-27 09:54 | 显示全部楼层
感谢分享,送您1000家园币,可以兑换礼品或抽奖~
个人签名:绿水本无忧因风皱面,青山原不老为雪白头。
553
