 代码这里#include "DSP2833x_Device.h"     // DSP2833x Headerfile Include File
 #include "DSP2833x_Examples.h"   // DSP2833x Examples Include File
 #define BUF_SIZE   128  // Sample buffer size
 #pragma DATA_SECTION(DMABuf1,"DMARAML4");
 #pragma DATA_SECTION(DMABuf2,"ZONE7DATA");
 volatile Uint16 DMABuf1[BUF_SIZE];
 volatile Uint16 DMABuf2[BUF_SIZE];
 Uint16   i;
 volatile Uint16 *DMADest;
 volatile Uint16 *DMASource;
 interrupt void xint1_isr(void);
 interrupt void xint2_isr(void);
 void init_zone7(void);
 main(void)
 // Step 1. Initialize System Control:
 // PLL, WatchDog, enable Peripheral Clocks
 // This example function is found in the DSP2833x_SysCtrl.c file.
 InitSysCtrl();
 // Step 2. Initialize GPIO:
 // This example function is found in the DSP2833x_Gpio.c file and
 // illustrates how to set the GPIO to it's default state.
 // InitGpio();  // Skipped for this example
 // Step 3. Clear all interrupts and initialize PIE vector table:
 // Disable CPU interrupts
 DINT;
 // Initialize the PIE control registers to their default state.
 // The default state is all PIE interrupts disabled and flags
 // are cleared.
 // This function is found in the DSP2833x_PieCtrl.c file.
 InitPieCtrl();
 // Disable CPU interrupts and clear all CPU interrupt flags:
 IER = 0x0000;
 IFR = 0x0000;
 // Initialize the PIE vector table with pointers to the shell Interrupt
 // Service Routines (ISR).
 // This will populate the entire table, even if the interrupt
 // is not used in this example.  This is useful for debug purposes.
 // The shell ISR routines are found in DSP2833x_DefaultIsr.c.
 // This function is found in DSP2833x_PieVect.c.
 InitPieVectTable();
 // Interrupts that are used in this example are re-mapped to
 // ISR functions found within this file.
 EALLOW;        // Allow access to EALLOW protected registers
 PieVectTable.XINT1= &xint1_isr;
 PieVectTable.XINT2= &xint2_isr;
 EDIS;   // Disable access to EALLOW protected registers
 IER |= M_INT1;                                     //Enable INT1 (1.4 DMA Ch1)
 EnableInterrupts();
 PieCtrlRegs.PIEIER1.bit.INTx4 = 1;            // 使能PIE组1的INT4
 PieCtrlRegs.PIEIER1.bit.INTx5 = 1;            // 使能PIE组1的INT5
 //Step 5. User specific code, enable interrupts:
 // Initialize DMA
 DMAInitialize();
 init_zone7();
 // Initialize Tables
 for (i=0; i<BUF_SIZE; i++)
 DMABuf1 = 0;
 DMABuf2 = 0;
 // Configure DMA Channel
 DMADest   = &DMABuf1[0];
 DMASource = &DMABuf2[0];
 DMACH1AddrConfig(DMADest,DMASource);
 DMACH1BurstConfig(15,1,1);         //Will set up to use 16-bit datasize, pointers are based on 16-bit words
 DMACH1TransferConfig(15,1,1);      //so need to increment by 1 to grab the correct location
 DMACH1WrapConfig(0xFFFF,0,0xFFFF,0);
 //Use timer0 to start the x-fer.
 //Since this is a static copy use one shot mode, so only one trigger is needed
 //Also using 16-bit mode to decrease x-fer time
 DMACH1ModeConfig(DMA_XINT1,PERINT_ENABLE,ONESHOT_ENABLE,CONT_ENABLE,SYNC_DISABLE,SYNC_SRC,OVRFLOW_DISABLE,SIXTEEN_BIT,CHINT_END,CHINT_ENABLE);
 //rdreq输出给FIFO
 EALLOW;
 GpioCtrlRegs.GPBMUX1.bit.GPIO37 = 3;        // 选择为片选信号
 GpioCtrlRegs.GPBDIR.bit.GPIO37 = 1;         // 方向定义为输出
 EDIS;
 //wrfull输入给DSP
 EALLOW;
 GpioCtrlRegs.GPAMUX2.bit.GPIO30 = 0;         // 选择为通用I/O口
 GpioCtrlRegs.GPADIR.bit.GPIO30 = 0;          // 方向定义为输入
 GpioCtrlRegs.GPAQSEL2.bit.GPIO30 = 0;        // 外部中断1(XINT1)与系统时钟SYSCLKOUT同步
 EDIS;
 //rdempty输入给DSP
 EALLOW;
 GpioCtrlRegs.GPAMUX2.bit.GPIO29 = 0;         // 选择为通用I/O口
 GpioCtrlRegs.GPADIR.bit.GPIO29 = 0;          // 方向定义为输入
 GpioCtrlRegs.GPAQSEL2.bit.GPIO29 = 0;        // 外部中断2(XINT1)与系统时钟SYSCLKOUT同步
 EDIS;
 // 通过GPIO外部中断选择寄存器,选择GPIO30为外部中断1
 EALLOW;
 GpioIntRegs.GPIOXINT1SEL.bit.GPIOSEL = 0x1e;   // XINT1是GPIO30
 GpioIntRegs.GPIOXINT2SEL.bit.GPIOSEL = 0x1d;   // XINT2是GPIO29
 EDIS;
 // 配置外部中断1的中断控制寄存器
 XIntruptRegs.XINT1CR.bit.POLARITY = 1;      // 上升沿触发中断
 XIntruptRegs.XINT2CR.bit.POLARITY = 1;      // 上升沿触发中断
 // 使能外部中断1
 XIntruptRegs.XINT1CR.bit.ENABLE = 1;        // 使能XINT1
 XIntruptRegs.XINT2CR.bit.ENABLE = 1;        // 使能XINT2
 //步骤6:无限循环
 for(;;);
 //步骤7.在这里插入中断服务子程序,如果需要使用中断服务子程序,必须在步骤5中重新定义中断
 //向量表中对应地地址
 StartDMACH1();
 GpioDataRegs.GPBSET.bit.GPIO37 = 1;         // 输出高电平,向FIFO发出读信号
 // 应答寄存器的位1清0,以响应同组内其他中断;
 PieCtrlRegs.PIEACK.all = PIEACK_GROUP1;
 GpioDataRegs.GPBCLEAR.bit.GPIO37 = 1;      // 引脚清0
 EALLOW;
 // Make sure the XINTF clock is enabled
 SysCtrlRegs.PCLKCR3.bit.XINTFENCLK = 1;
 EDIS;
 // Configure the GPIO for XINTF with a 16-bit data bus
 // This function is in DSP2833x_Xintf.c
 InitXintf16Gpio();
 EALLOW;
 GpioDataRegs.GPCSET.bit.GPIO72 = 1;
 EDIS;      ********/
 // All Zones---------------------------------
 // Timing for all zones based on XTIMCLK = SYSCLKOUT/2
 EALLOW;
 XintfRegs.XINTCNF2.bit.XTIMCLK = 1;
 // Buffer up to 3 writes
 XintfRegs.XINTCNF2.bit.WRBUFF = 3;
 // XCLKOUT is enabled
 XintfRegs.XINTCNF2.bit.CLKOFF = 0;
 // XCLKOUT = XTIMCLK/2
 XintfRegs.XINTCNF2.bit.CLKMODE = 1;
 // Zone 7------------------------------------
 // When using ready, ACTIVE must be 1 or greater
 // Lead must always be 1 or greater
 // Zone write timing
 XintfRegs.XTIMING7.bit.XWRLEAD = 1;
 XintfRegs.XTIMING7.bit.XWRACTIVE = 2;
 XintfRegs.XTIMING7.bit.XWRTRAIL = 1;
 // Zone read timing
 XintfRegs.XTIMING7.bit.XRDLEAD = 1;
 XintfRegs.XTIMING7.bit.XRDACTIVE = 3;
 XintfRegs.XTIMING7.bit.XRDTRAIL = 0;
 // don't double all Zone read/write lead/active/trail timing
 XintfRegs.XTIMING7.bit.X2TIMING = 0;
 // Zone will not sample XREADY signal
 XintfRegs.XTIMING7.bit.USEREADY = 0;
 XintfRegs.XTIMING7.bit.READYMODE = 0;
 // 1,1 = x16 data bus
 // 0,1 = x32 data bus
 // other values are reserved
 XintfRegs.XTIMING7.bit.XSIZE = 3;
 EDIS;
 //Force a pipeline flush to ensure that the write to
 //the last register configured occurs before returning.
 asm(" RPT #7 || NOP");
