| 鼓捣了一晚上搞出一个基于原子哥LCD库V3.0的画坐标系图象的几个函数。 使用方法如下:
 - void LCD_Plot_Init(u16 width, u16 height, u16 xUnit, u16 yUnit, u16 xOrigin, u16 yOrigin, u8 GridSwitch); //最后一个参数GridSwitch用来设置是否画栅格
 - void RefreshPlot(u16 NewValue);  //直接输入一个数就可以画图了
 支持函数有
 - typedef struct tagPlot_Init
 u16 xOrigin;
 u16 yOrigin;
 u16 xUnit;
 u16 yUnit;
 u16 height;
 u16 width;
 u8 GridSwitch;
 } Plot_Init;
 void DrawFrame(Plot_Init PLOT_INIT);        //用来绘制坐标系的外框
 void DP(u16 x,u16 y,u16 color);        //快速画点 其实就是给LCD_Fast_DrawPoint()套了个壳
 以上部分定义在lcd.h中 在lcd.c中定义了两个全局变量,数组PLOT_NUM[]用来存放显示数据和坐标系参数结构体PLOT_INIT
 具体实现代码如下
 LCD_Fast_DrawPoint(x,y,color);
 void LCD_Plot_Init(u16 width, u16 height, u16 xUnit, u16 yUnit, u16 xOrigin, u16 yOrigin, u8 GridSwitch){//×ø±êϵ³õʼ»¯
 u16 i;
 PLOT_INIT.GridSwitch=GridSwitch;
 PLOT_INIT.height=height;
 PLOT_INIT.width=width;
 PLOT_INIT.xOrigin=xOrigin;
 PLOT_INIT.yOrigin=yOrigin;
 PLOT_INIT.xUnit=xUnit;
 PLOT_INIT.yUnit=yUnit;
 return;
 void DrawFrame(Plot_Init PLOT_INIT){
 u16 i;
 //PLOT_INIT.width=width;
 if(PLOT_INIT.GridSwitch){
 for(i=PLOT_INIT.width/PLOT_INIT.xUnit;i>0;i--){
 POINT_COLOR=LIGHTBLUE;
 LCD_DrawLine(PLOT_INIT.xOrigin+i*PLOT_INIT.xUnit,PLOT_INIT.yOrigin,PLOT_INIT.xOrigin+i*PLOT_INIT.xUnit,PLOT_INIT.yOrigin-PLOT_INIT.height);
 POINT_COLOR=WHITE;
 LCD_Draw_Circle(PLOT_INIT.xOrigin+i*PLOT_INIT.xUnit,PLOT_INIT.yOrigin,2);
 for(i=PLOT_INIT.height/PLOT_INIT.yUnit;i>0;i--){
 LCD_DrawLine(PLOT_INIT.xOrigin,PLOT_INIT.yOrigin-i*PLOT_INIT.yUnit,PLOT_INIT.xOrigin+PLOT_INIT.width,PLOT_INIT.yOrigin-i*PLOT_INIT.yUnit);
 POINT_COLOR=WHITE;
 LCD_Draw_Circle(PLOT_INIT.xOrigin,PLOT_INIT.yOrigin-i*PLOT_INIT.yUnit,2);
 //Draw Frame Ready
 LCD_DrawLine(PLOT_INIT.xOrigin,PLOT_INIT.yOrigin,PLOT_INIT.xOrigin,PLOT_INIT.yOrigin-PLOT_INIT.height);
 LCD_DrawLine(PLOT_INIT.xOrigin,PLOT_INIT.yOrigin,PLOT_INIT.xOrigin+PLOT_INIT.width,PLOT_INIT.yOrigin);
 LCD_DrawLine(PLOT_INIT.xOrigin+PLOT_INIT.width,PLOT_INIT.yOrigin,PLOT_INIT.xOrigin+PLOT_INIT.width,PLOT_INIT.yOrigin-PLOT_INIT.height);
 LCD_DrawLine(PLOT_INIT.xOrigin,PLOT_INIT.yOrigin-PLOT_INIT.height,PLOT_INIT.xOrigin+PLOT_INIT.width,PLOT_INIT.yOrigin-PLOT_INIT.height);
 //Draw frame ready
 POINT_COLOR=RED;
 LCD_Draw_Circle(PLOT_INIT.xOrigin,PLOT_INIT.yOrigin,4);
 POINT_COLOR=WHITE;
 return;
 void RefreshPlot(u16 NewValue){
 u16 width=PLOT_INIT.width;
 u16 height=PLOT_INIT.height;
 u16 xOrigin=PLOT_INIT.xOrigin;
 u16 yOrigin=PLOT_INIT.yOrigin;
 u8 NewValueString[10];
 u8 LastValueString[10];
 u16 LastValue=*(PLOT_NUM+*PLOT_NUM);
 u16 i;
 sprintf((char*)NewValueString,"%d",NewValue);
 sprintf((char*)LastValueString,"%d",*(PLOT_NUM+*PLOT_NUM));
 DrawFrame(PLOT_INIT);
 //ͼÏó²»ÂúÒ»ÆÁĻʱ
 if(*PLOT_NUM!=width){
 POINT_COLOR=BLACK;//¿ªÊ¼²Á³ý
 for(i=*PLOT_NUM;i>0;i--)DP(xOrigin+i,yOrigin-*(PLOT_NUM+i),BLACK);//²Á³ýÇúÏß
 LCD_ShowString(xOrigin+*PLOT_NUM+1,yOrigin-LastValue-16,120,12,12,LastValueString);//²Á³ýÊýÖµ
 LCD_Draw_Circle(xOrigin+*PLOT_NUM+1,yOrigin-LastValue,1);//²Á³ý¹â±ê
 LCD_Draw_Circle(xOrigin+*PLOT_NUM+1,yOrigin-LastValue,2);//²Á³ý¹â±ê
 *(PLOT_NUM+*PLOT_NUM+1)=NewValue;//¸üдýÏÔʾµÄÊý¾Ý
 (*PLOT_NUM)++;//¸üÐÂÊý¾ÝÊýÄ¿
 POINT_COLOR=WHITE;//¿ªÊ¼»æÖÆ
 for(i=*PLOT_NUM;i>0;i--){DP(xOrigin+i,yOrigin-*(PLOT_NUM+i),WHITE);}//»æÖÆÇúÏß
 LCD_ShowString(xOrigin+*PLOT_NUM+1,yOrigin-NewValue-16,120,12,12,NewValueString);//»æÖÆÊýÖµ
 POINT_COLOR=RED;LCD_Draw_Circle(xOrigin+*PLOT_NUM+1,yOrigin-NewValue,1);//»æÖƹâ±ê
 POINT_COLOR=RED;LCD_Draw_Circle(xOrigin+*PLOT_NUM+1,yOrigin-NewValue,2);//»æÖƹâ±ê
 }else{
 //ͼÏóÒÑÂúÒ»ÆÁĻʱ£¬¿ªÊ¼Õû¶ÎÒÆ¶¯ÇúÏß
 for(i=width;i>0;i--)DP(xOrigin+i,yOrigin-*(PLOT_NUM+i),BLACK);//²Á³ýͼÏóµã
 LCD_ShowString(xOrigin+width,yOrigin-LastValue-16,120,12,12,LastValueString);//»æÖÆÊýÖµ
 LCD_Draw_Circle(xOrigin+width,yOrigin-LastValue,1);//²Á³ý¹â±ê
 LCD_Draw_Circle(xOrigin+width,yOrigin-LastValue,2);//²Á³ý¹â±ê
 for(i=0;i<width;i++)*(PLOT_NUM+i+1)=*(PLOT_NUM+i+2);*(PLOT_NUM+width)=NewValue; //&cedil;ü&ETH;&Acirc;&acute;&yacute;&Iuml;&Ocirc;&Ecirc;&frac34;&micro;&Auml;&Ecirc;&yacute;&frac34;&Yacute;
 POINT_COLOR=WHITE;//&iquest;&ordf;&Ecirc;&frac14;&raquo;&aelig;&Ouml;&AElig;
 for(i=width;i>0;i--)DP(xOrigin+i,yOrigin-*(PLOT_NUM+i),WHITE);//&raquo;&aelig;&Ouml;&AElig;&Iacute;&frac14;&Iuml;ó&micro;&atilde;
 LCD_ShowString(xOrigin+width,yOrigin-NewValue-16,120,12,12,NewValueString);//&raquo;&aelig;&Ouml;&AElig;&Ecirc;&yacute;&Ouml;&micro;
 POINT_COLOR=RED;LCD_Draw_Circle(xOrigin+width,yOrigin-NewValue,1);//&raquo;&aelig;&Ouml;&AElig;&sup1;&acirc;±ê
 POINT_COLOR=RED;LCD_Draw_Circle(xOrigin+width,yOrigin-NewValue,2);//&raquo;&aelig;&Ouml;&AElig;&sup1;&acirc;±ê
 }//&cedil;ü&ETH;&Acirc;&Euml;ù&Iuml;&Ocirc;&Ecirc;&frac34;&micro;&Auml;&Ecirc;&yacute;&frac34;&Yacute;&sup2;&cent;&raquo;&shy;&ETH;&Acirc;&micro;&Auml;&Ecirc;&yacute;&frac34;&Yacute;&micro;&atilde;
 return;
