[DemoCode下载] M451点灯
696|7
 楼主| 幸福小强 发表于 2020-6-30 21:12 | 显示全部楼层 |阅读模式
ck, TE, se, rc
  1. /**************************************************************************//**
  2. * [url=home.php?mod=space&uid=288409]@file[/url]     main.c
  3. * [url=home.php?mod=space&uid=895143]@version[/url]  V1.00
  4. * $Date: 15/09/02 10:03a $
  5. * [url=home.php?mod=space&uid=247401]@brief[/url]    Toggle PC.9 to turn on / off the board LED
  6. *
  7. * @note
  8. * Copyright (C) 2013~2015 Nuvoton Technology Corp. All rights reserved.
  9. *
  10. ******************************************************************************/
  11. #include <stdio.h>
  12. #include "M451Series.h"
  13. #define HCLK_CLOCK       72000000
  14. void SYS_Init(void)
  15. {
  16.     /*---------------------------------------------------------------------------------------------------------*/
  17.     /* Init System Clock        */
  18.     /*---------------------------------------------------------------------------------------------------------*/
  19.     /* Unlock protected registers */
  20.     SYS_UnlockReg();
  21.     /* Enable HIRC clock (Internal RC 22.1184MHz) */
  22.     CLK_EnableXtalRC(CLK_PWRCTL_HIRCEN_Msk);
  23.     /* Wait for HIRC clock ready */
  24.     CLK_WaitClockReady(CLK_STATUS_HIRCSTB_Msk);
  25.     /* Select HCLK clock source as HIRC and and HCLK clock divider as 1 */
  26.     CLK_SetHCLK(CLK_CLKSEL0_HCLKSEL_HIRC, CLK_CLKDIV0_HCLK(1));
  27.     /* Enable HXT clock (external XTAL 12MHz) */
  28.     CLK_EnableXtalRC(CLK_PWRCTL_HXTEN_Msk);
  29.     /* Wait for HXT clock ready */
  30.     CLK_WaitClockReady(CLK_STATUS_HXTSTB_Msk);
  31.     /* Set core clock as HCLK_CLOCK */
  32.     CLK_SetCoreClock(HCLK_CLOCK);
  33.     /* Update System Core Clock */
  34.     /* User can use SystemCoreClockUpdate() to calculate SystemCoreClock. */
  35.     SystemCoreClockUpdate();
  36.     /*---------------------------------------------------------------------------------------------------------*/
  37.     /* Init I/O Multi-function        */
  38.     /*---------------------------------------------------------------------------------------------------------*/
  39.     /* Set GPD multi-function pins for UART0 RXD and TXD */
  40.     SYS->GPD_MFPL &= ~(SYS_GPD_MFPL_PD6MFP_Msk | SYS_GPD_MFPL_PD1MFP_Msk);
  41.     SYS->GPD_MFPL |= (SYS_GPD_MFPL_PD6MFP_UART0_RXD | SYS_GPD_MFPL_PD1MFP_UART0_TXD);
  42.     /* Lock protected registers */
  43.     SYS_LockReg();
  44. }
  45. /*---------------------------------------------------------------------------------------------------------*/
  46. /* MAIN function        */
  47. /*---------------------------------------------------------------------------------------------------------*/
  48. int main(void)
  49. {
  50.     /* Init System, IP clock and multi-function I/O
  51.        In the end of SYS_Init() will issue SYS_LockReg()
  52.        to lock protected register. If user want to write
  53.        protected register, please issue SYS_UnlockReg()
  54.        to unlock protected register if necessary */
  55.     SYS_Init();
  56.     /* Select SysTick clock source as HXT */
  57.     CLK_SetSysTickClockSrc(CLK_CLKSEL0_STCLKSEL_HXT);
  58.     /* Configure PC.9 as Output mode */
  59.     GPIO_SetMode(PC, BIT9, GPIO_MODE_OUTPUT);
  60.     while(1)
  61.     {
  62.         /* Configure PC.9 to low */
  63.         PC9 = 0;
  64.         /* Delay 200 ms */
  65.         CLK_SysTickDelay(200000);
  66.         /* Configure PC.9 to high */
  67.         PC9 = 1;
  68.         /* Delay 200 ms */
  69.         CLK_SysTickDelay(200000);
  70.     }
  71. }
 楼主| 幸福小强 发表于 2020-6-30 21:13 | 显示全部楼层
M451可以直接对某个PIN操作,非常方便。像51单片机一样。
xinxianshi 发表于 2020-6-30 21:27 | 显示全部楼层
确实不错,BSP还提供了延时函数。
用tick延时非常明智。
wanduzi 发表于 2020-7-21 21:42 | 显示全部楼层
这种的延时比ML51的好用多了。
玛尼玛尼哄 发表于 2020-7-23 22:04 | 显示全部楼层
可以可以。
小灵通2018 发表于 2020-7-25 11:51 | 显示全部楼层
点灯走起。
wanduzi 发表于 2020-7-25 13:21 | 显示全部楼层
太赞了,
