- #include <stdio.h>
- #include <gtk/gtk.h>
- void gtest(int a)
- printf("===:%d\n",a);
- static void
- draw_round_rectangle (cairo_t * cr,
- double x, double y,
- double width, double height, double r)
- cairo_move_to (cr, x + r, y);
- cairo_line_to (cr, x + width - r, y);
- cairo_move_to (cr, x + width, y + r);
- cairo_line_to (cr, x + width, y + height - r);
- cairo_move_to (cr, x + width - r, y + height);
- cairo_line_to (cr, x + r, y + height);
- cairo_move_to (cr, x, y + height - r);
- cairo_line_to (cr, x, y + r);
- cairo_arc (cr, x + r, y + r, r, 3.14, 3 * 3.14 / 2.0);
- cairo_arc (cr, x + width - r, y + r, r, 3 * 3.14 / 2, 2 * 3.14);
- cairo_arc (cr, x + width - r, y + height - r, r, 0, 3.14 / 2);
- cairo_arc (cr, x + r, y + height - r, r, 3.14 / 2, 3.14);
- static gboolean
- draw (GtkWidget *widget, cairo_t *cr, gpointer user_data)
- cr = gdk_cairo_create (gtk_widget_get_window (widget));
- cairo_set_source_rgb (cr, 0, 0, 0);
- cairo_set_line_width (cr, 1);
- cairo_rectangle (cr, 20, 20, 120, 80);
- cairo_rectangle (cr, 180, 20, 80, 80);
- cairo_stroke_preserve (cr);
- cairo_set_source_rgb (cr, 1, 1, 1);
- cairo_fill (cr);
- cairo_arc (cr, 330, 60, 40, 0, 2 * 3.14);
- cairo_fill (cr);
- cairo_arc (cr, 90, 160, 40, 3.14 / 4, 3.14);
- cairo_close_path (cr);
- cairo_stroke_preserve(cr);
- cairo_fill (cr);
- cairo_translate (cr, 220, 180);
- cairo_scale (cr, 1, 0.7);
- cairo_arc (cr, 0, 0, 50, 0, 2 * 3.14);
- cairo_fill (cr);
- cairo_set_source_rgb (cr, 0.8, 0.4, 0);
- cairo_translate (cr, 80, -30);
- cairo_set_line_width (cr, 6);
- draw_round_rectangle (cr, 5, 5, 60, 60, 8);
- cairo_set_source_rgb (cr, 0.8, 0.8, 0.2);
- cairo_fill (cr);
- cairo_destroy (cr);
- return FALSE;
- int gt( int argc, char **argv)
- GtkWidget *window;
- GtkWidget *darea;
- gtk_init (&argc, &argv);
- window = gtk_window_new (GTK_WINDOW_TOPLEVEL);
- darea = gtk_drawing_area_new ();
- gtk_container_add (GTK_CONTAINER (window), darea);
- g_signal_connect (darea, "draw",
- G_CALLBACK (draw), NULL);
- g_signal_connect (window, "destroy",
- G_CALLBACK (gtk_main_quit), NULL);
- gtk_window_set_position (GTK_WINDOW (window),
- GTK_WIN_POS_CENTER);
- gtk_window_set_default_size (GTK_WINDOW (window), 500, 400);
- gtk_widget_show_all (window);
- gtk_main ();
- return 0;
@gaoyang9992006
