- #include "gd32f10x.h"
- #include "systick.h"
- #include <stdio.h>
- #include "gd32f10x_eval.h"
- //#define BOARD_ADC_CHANNEL ADC_CHANNEL_13
- //#define ADC_GPIO_PORT GPIOC
- //#define ADC_GPIO_PIN GPIO_PIN_3
- uint16_t adc_value[8];
- void rcu_config(void);
- void gpio_config(void);
- void dma_config(void);
- void adc_config(void);
- \brief main function
- \param[in] none
- \param[out] none
- \retval none
- int main(void)
- /* system clocks configuration */
- rcu_config();
- /* systick configuration */
- systick_config();
- /* GPIO configuration */
- gpio_config();
- /* DMA configuration */
- dma_config();
- /* configure COM port */
- gd_eval_com_init(EVAL_COM0);
- /* ADC configuration */
- adc_config();
- while(1){
- delay_1ms(1000);
- printf("\r\n //*******************************//");
- printf("\r\n PA2 regular channel data = %04d", adc_value[0]);
- printf("\r\n PC5 regular channel data = %04d", adc_value[1]);
- printf("\r\n PC4 regular channel data = %04d", adc_value[2]);
- printf("\r\n PA3 regular channel data = %04d\r\n", adc_value[3]);
- printf("\r\n PC0 regular channel data = %04d", adc_value[4]);
- printf("\r\n PA1 regular channel data = %04d", adc_value[5]);
- printf("\r\n PA0 regular channel data = %04d", adc_value[6]);
- printf("\r\n PC1 regular channel data = %04d\r\n", adc_value[7]);
- \brief configure the different system clocks
- \param[in] none
- \param[out] none
- \retval none
- /* enable GPIOA clock */
- rcu_periph_clock_enable(RCU_GPIOA);
- rcu_periph_clock_enable(RCU_GPIOC);
- /* enable ADC clock */
- rcu_periph_clock_enable(RCU_ADC0);
- /* enable DMA0 clock */
- rcu_periph_clock_enable(RCU_DMA0);
- /* config ADC clock */
- rcu_adc_clock_config(RCU_CKADC_CKAPB2_DIV8);
- \brief configure the GPIO peripheral
- \param[in] none
- \param[out] none
- \retval none
- /* config the GPIO as analog mode */
- gpio_init(GPIOA, GPIO_MODE_AIN, GPIO_OSPEED_50MHZ, GPIO_PIN_2);
- gpio_init(GPIOC, GPIO_MODE_AIN, GPIO_OSPEED_50MHZ, GPIO_PIN_5);
- gpio_init(GPIOC, GPIO_MODE_AIN, GPIO_OSPEED_50MHZ, GPIO_PIN_4);
- gpio_init(GPIOA, GPIO_MODE_AIN, GPIO_OSPEED_50MHZ, GPIO_PIN_3);
- gpio_init(GPIOC, GPIO_MODE_AIN, GPIO_OSPEED_50MHZ, GPIO_PIN_0);
- gpio_init(GPIOA, GPIO_MODE_AIN, GPIO_OSPEED_50MHZ, GPIO_PIN_1);
- gpio_init(GPIOA, GPIO_MODE_AIN, GPIO_OSPEED_50MHZ, GPIO_PIN_0);
- gpio_init(GPIOC, GPIO_MODE_AIN, GPIO_OSPEED_50MHZ, GPIO_PIN_1);
- \brief configure the DMA peripheral
- \param[in] none
- \param[out] none
- \retval none
- /* ADC_DMA_channel configuration */
- dma_parameter_struct dma_data_parameter;
- /* ADC DMA_channel configuration */
- dma_deinit(DMA0, DMA_CH0);
- /* initialize DMA single data mode */
- dma_data_parameter.periph_addr = (uint32_t)(&ADC_RDATA(ADC0));
- dma_data_parameter.periph_inc = DMA_PERIPH_INCREASE_DISABLE;
- dma_data_parameter.memory_addr = (uint32_t)(&adc_value);
- dma_data_parameter.memory_inc = DMA_MEMORY_INCREASE_ENABLE;
- dma_data_parameter.periph_width = DMA_PERIPHERAL_WIDTH_16BIT;
- dma_data_parameter.memory_width = DMA_MEMORY_WIDTH_16BIT;
- dma_data_parameter.direction = DMA_PERIPHERAL_TO_MEMORY;
- dma_data_parameter.number = 8;
- dma_data_parameter.priority = DMA_PRIORITY_HIGH;
- dma_init(DMA0, DMA_CH0, &dma_data_parameter);
- dma_circulation_enable(DMA0, DMA_CH0);
- /* enable DMA channel */
- dma_channel_enable(DMA0, DMA_CH0);
- \brief configure the ADC peripheral
- \param[in] none
- \param[out] none
- \retval none
- /* reset ADC */
- adc_deinit(ADC0);
- /* ADC mode config */
- adc_mode_config(ADC_MODE_FREE);
- /* ADC contineous function enable */
- adc_special_function_config(ADC0, ADC_CONTINUOUS_MODE,ENABLE );
- /* ADC scan mode disable */
- adc_special_function_config(ADC0, ADC_SCAN_MODE, DISABLE);
- /* ADC data alignment config */
- adc_data_alignment_config(ADC0, ADC_DATAALIGN_RIGHT);
- /* ADC channel length config */
- adc_channel_length_config(ADC0, ADC_REGULAR_CHANNEL, 8);
- /* ADC regular channel config */
- adc_regular_channel_config(ADC0, 0, ADC_CHANNEL_2, ADC_SAMPLETIME_239POINT5);
- adc_regular_channel_config(ADC0, 1, ADC_CHANNEL_15, ADC_SAMPLETIME_239POINT5);
- adc_regular_channel_config(ADC0, 2, ADC_CHANNEL_14, ADC_SAMPLETIME_239POINT5);
- adc_regular_channel_config(ADC0, 3, ADC_CHANNEL_3, ADC_SAMPLETIME_239POINT5);
- adc_regular_channel_config(ADC0, 4, ADC_CHANNEL_10, ADC_SAMPLETIME_239POINT5);
- adc_regular_channel_config(ADC0, 5, ADC_CHANNEL_1, ADC_SAMPLETIME_239POINT5);
- adc_regular_channel_config(ADC0, 6, ADC_CHANNEL_0, ADC_SAMPLETIME_239POINT5);
- adc_regular_channel_config(ADC0, 7, ADC_CHANNEL_11, ADC_SAMPLETIME_239POINT5);
- /* ADC trigger config */
- adc_external_trigger_source_config(ADC0, ADC_REGULAR_CHANNEL, ADC0_1_2_EXTTRIG_REGULAR_NONE);
- adc_external_trigger_config(ADC0, ADC_REGULAR_CHANNEL, ENABLE);
- /* enable ADC interface */
- adc_enable(ADC0);
- delay_1ms(1);
- /* ADC calibration and reset calibration */
- adc_calibration_enable(ADC0);
- /* ADC DMA function enable */
- adc_dma_mode_enable(ADC0);
- /* ADC software trigger enable */
- adc_software_trigger_enable(ADC0, ADC_REGULAR_CHANNEL);
- /* retarget the C library printf function to the USART */
- int fputc(int ch, FILE *f)
- usart_data_transmit(EVAL_COM0, (uint8_t)ch);
- while(RESET == usart_flag_get(EVAL_COM0, USART_FLAG_TBE));
- return ch;
