理解STM32H7的MDMA的循环列表模式
356|0
 楼主| 张さん 发表于 2018-8-5 08:00 | 显示全部楼层 |阅读模式
关于这个循环里面模式,要特别注意一点
他不是从节点0开始循环的,是从节点1开始循环的,如节点1,节点2,节点3组成一个循环
而节点0是初始配置,在用户调用了HAL_MDMA_Start_IT后仅执行一次。
  * @brief  Connect a node to the linked list.
  * @param  hmdma    : Pointer to a MDMA_HandleTypeDef structure that contains
  *                    the configuration information for the specified MDMA Channel.
  * @param  pNewNode : Pointer to a MDMA_LinkNodeTypeDef structure that contains Linked list node
  *                    to be add to the list.
  * @param pPrevNode : Pointer to the new node position in the linked list or zero to insert the new node
  *                    at the end of the list
  * @retval HAL status
HAL_StatusTypeDef HAL_MDMA_LinkedList_AddNode(MDMA_HandleTypeDef *hmdma, MDMA_LinkNodeTypeDef *pNewNode, MDMA_LinkNodeTypeDef *pPrevNode)
  MDMA_LinkNodeTypeDef *pNode = 0;
  uint32_t counter = 0, nodeInserted = 0;
  HAL_StatusTypeDef hal_status = HAL_OK;
  /* Check the MDMA peripheral handle */
  if((hmdma == NULL) || (pNewNode == NULL))
    return HAL_ERROR;
  /* Process locked */
  __HAL_LOCK(hmdma);
  if(HAL_MDMA_STATE_READY == hmdma->State)
    /* Change MDMA peripheral state */
    hmdma->State = HAL_MDMA_STATE_BUSY;
    /* Check if this is the first node (after the Inititlization node) */
    if((uint32_t)hmdma->FirstLinkedListNodeAddress == 0)
      if(pPrevNode == NULL)
        /* if this is the first node after the initialization
        connect this node to the node 0 by updating
        the MDMA channel CLAR register to this node address */
        hmdma->Instance->CLAR = (uint32_t)pNewNode;
        /* Set the MDMA handle First linked List node*/
        hmdma->FirstLinkedListNodeAddress = pNewNode;
        /*reset New node link */
        pNewNode->CLAR = 0;
        /* Update the Handle last node address */
        hmdma->LastLinkedListNodeAddress = pNewNode;
        hmdma->LinkedListNodeCounter = 1;
      else
        hal_status = HAL_ERROR;
    else if(hmdma->FirstLinkedListNodeAddress != pNewNode)
      /* Check if the node to insert already exists*/
      pNode = hmdma->FirstLinkedListNodeAddress;
      while((counter < hmdma->LinkedListNodeCounter) && (hal_status == HAL_OK))
        if(pNode->CLAR == (uint32_t)pNewNode)
          hal_status = HAL_ERROR; /* error this node already exist in the linked list and it is not first node */
        pNode = (MDMA_LinkNodeTypeDef *)pNode->CLAR;
        counter++;
      if(hal_status == HAL_OK)
        /* Check if the previous node is the last one in the current list or zero */
        if((pPrevNode == hmdma->LastLinkedListNodeAddress) || (pPrevNode == 0))
          /* insert the new node at the end of the list. */
          pNewNode->CLAR = hmdma->LastLinkedListNodeAddress->CLAR;
          hmdma->LastLinkedListNodeAddress->CLAR = (uint32_t)pNewNode;
          /* Increment the linked list node counter */
          hmdma->LinkedListNodeCounter++;
        else
          /*insert the new node after the pPreviousNode node */
          counter = 0;
          while((counter < hmdma->LinkedListNodeCounter) && (nodeInserted == 0))
            counter++;
            if(pNode == pPrevNode)
              /*Insert the new node after the previous one */
              pNewNode->CLAR = pNode->CLAR;
              pNode->CLAR = (uint32_t)pNewNode;
              nodeInserted = 1;
            else
          if(nodeInserted == 0)
    else
    /* Process unlocked */
    __HAL_UNLOCK(hmdma);
    hmdma->State = HAL_MDMA_STATE_READY;
    return hal_status;
  else
    /* Return error status */
    return HAL_BUSY;
复制代码
  * @brief  Make the linked list circular by connecting the last node to the first.
HAL_StatusTypeDef HAL_MDMA_LinkedList_EnableCircularMode(MDMA_HandleTypeDef *hmdma)
  if(hmdma == NULL)
    return HAL_ERROR;
  __HAL_LOCK(hmdma);
    /* If first and last node are null (no nodes in the list) : return error*/
    if(((uint32_t)hmdma->FirstLinkedListNodeAddress == 0) || ((uint32_t)hmdma->LastLinkedListNodeAddress == 0) || (hmdma->LinkedListNodeCounter == 0))
    else
      /* to enable circular mode Last Node should be connected to first node */
      hmdma->LastLinkedListNodeAddress->CLAR = (uint32_t)hmdma->FirstLinkedListNodeAddress;
  return hal_status;
}复制代码
