| While reading the documentation on the MOV instruction (section A6.7.40) on the ARMv6-M architecture, I stumbled upon the following in the \"Encoding T1\" description: \"ARMv6-M, ARMv7-M, if and both from R0-R7. Otherwise all versions of the Thumb instruction set.\". I have trouble interpreting this. My first thought was that the T1 encoding can only be used on ARMv6-M, ARMv7-M if the Rd and Rm registers are both from R0-R7, but this doesn\'t hold as it is perfectly possible to assemble a MOV instruction for (at least) the ARMv6-M architecture using the T1 encoding with Rm and Rd being greater than R7.
 I have tried contacting the ARM support, but it wasn\'t very helpful at all.
