| #include <math.h>
 int n=2048,n1=2048,n2=2048;
 uint8_t Count=0;
 uint8_t f=0;
 int val=0;
 void ADC_DATA_CALLBACK(uint32_t u32UserData)
 n=n1;
 n1=n2;
 n2=DrvADC_GetConversionData(1);
 if(n2-n>650)
 DrvGPIO_ClrBit(E_PORT2, E_PIN7);
 if(n-n2>650)
 DrvGPIO_SetBit(E_PORT2, E_PIN7);
 /* val=abs(n2-n);
 if((val>650)&&(Count==0))
 Count=1;
 else
 Count=0;
 if(Count==1)
 if(f)
 f=0;
 else
 f=1;
 DrvADC_StartConvert();
 void time1_callback(uint32_t da)//定时器1专门作为闪烁使用
 DrvSYS_UnlockProtectedReg();
 DrvWDT_Ioctl(E_WDT_IOC_RESET_TIMER,0);  //喂狗
 DrvSYS_LockProtectedReg();
 void time0_callback(uint32_t da)//定时器0专门做采样工作和刷新屏幕显示
 void initsys()
 while(DrvSYS_SetOscCtrl(E_SYS_XTL12M, 1)!=FALSE);//使能外部12MHZ晶振
 DrvSYS_SelectPLLSource(E_SYS_EXTERNAL_12M);
 DrvSYS_SetPLLMode(0);//pll正常
 DrvSYS_UnlockProtectedReg();//关闭寄存器保护
 DrvSYS_Open(50000000);//sys=12MHZ
 DrvSYS_SelectHCLKSource(2);//pll
 //while( DrvSYS_SelectHCLKSource(0) !=FALSE);//HCLK=12MHZ
 DrvSYS_SetClockDivider(E_SYS_HCLK_DIV , 0);//HCLK1分频
 while(DrvSYS_SelectSysTickSource(0)!=FALSE);//选择系统嘀嗒时钟源为外部12MHZ晶振
 void initTMR0()
 DrvSYS_SetIPClock(E_SYS_TMR0_CLK,1); //使能始终
 DrvSYS_SelectIPClockSource(E_SYS_TMR0_CLKSRC,2 );//这个TIM0是接到APB总线,不可以用外部晶振,手册的是错误的,应该看下面的APBPCLK的时钟
 DrvTIMER_Init();
 DrvTIMER_Open(E_TMR0,1,E_PERIODIC_MODE); //100MS
 DrvTIMER_EnableInt(E_TMR0);
 DrvTIMER_SetTimerEvent(E_TMR0, 2, time0_callback, 1);//1s
 DrvTIMER_Start(E_TMR0);
 DrvSYS_SetIPClock(E_SYS_TMR1_CLK,1); //使能始终
 DrvSYS_SelectIPClockSource(E_SYS_TMR1_CLKSRC,2 );//这个TIM0是接到APB总线,不可以用外部晶振,手册的是错误的,应该看下面的APBPCLK的时钟
 DrvTIMER_Open(E_TMR1,10,E_PERIODIC_MODE); //100MS
 DrvTIMER_EnableInt(E_TMR1);
 DrvTIMER_SetTimerEvent(E_TMR1, 2, time1_callback, 1);//0.5s
 DrvTIMER_Start(E_TMR1);
 void init_ADC()
 /*Initialize ADC*/
 DrvGPIO_InitFunction(E_FUNC_ADC1 );
 DrvADC_Open(ADC_SINGLE_END, ADC_CONTINUOUS_OP, 0x02, EXTERNAL_12MHZ, 59);
 DrvADC_EnableADCInt(ADC_DATA_CALLBACK,0);
 #include <stdio.h>
 #include <string.h>
 #include &quot;SqQueue.h&quot;
 status InitQueue(SqQueue *Q,QElemType *Q_BUF)
 Q->base=Q_BUF;
 Q->front=0;
 Q->rear=0;
 return OK;
 int QueueLength(SqQueue *Q)
 return ((Q->rear-Q->front+MAXQSIZE) % MAXQSIZE);
 status EnQueue(SqQueue *Q,QElemType *e)
 if(((Q->rear+1) % MAXQSIZE) == Q->front) return ERROR;
 Q->base[Q->rear] = *e;
 Q->rear = (Q->rear+1) % MAXQSIZE;
 return OK;
 status DeQueue(SqQueue *Q,QElemType *e)
 if(Q->front == Q->rear) return ERROR;
 *e = Q->base[Q->front] ;
 Q->front = (Q->front+1) % MAXQSIZE;
 return OK;
 #define MAXQSIZE 100
 #define ERROR       0
 #define OK        1
 #define  status unsigned char
 #define  QElemType unsigned char
 typedef struct{
 QElemType *base;
 unsigned char front;
 unsigned char rear;
 }SqQueue;
 status InitQueue(SqQueue *Q,QElemType *Q_BUF);
 int QueueLength(SqQueue *Q);
 status EnQueue(SqQueue *Q,QElemType *e);
 status DeQueue(SqQueue *Q,QElemType *e) ;复制代码
