[MCU] F2812烧写中遇到的问题
699|0
 楼主| elephant00 发表于 2020-11-11 11:10 | 显示全部楼层 |阅读模式
我想把ucos移植去2812,但是在烧写中遇到了一些问题,这个问题我在论坛见过,不过不清楚具体是怎样解决的~
下面是遇到的状况:
使用ti的烧写插件烧写FLASH时出现以下提示:
Code Composer could not locate:
FlashAPIInterface.c
Would you like to browse for it?
  Do not ask me again.
program的时候出现
no section were found that map to flash
然后
Warning:  ...... if your Flash program requires initialized
data in RAM,you will need to write Flash code to initialize RAM.
还有在烧写完成后会出现下面的警告:
Warning: This program contains initialized RAM data.
It may run successfully under Code Composer Studio
but not as a standalone system because of this. If
your Flash program requires initialized data in RAM,
you will need to write Flash code to initialize RAM memory.
但是显示成功。
另外在烧写完成退出ccs时出现红色错误对话框:
Can\'t Remove Breakpoint:
Error 0x0000 0008/-2044
Error during : Break Point,
No breakpoint at 0x0000 906C
是什么原因,应该怎么解决呢?
盼各位前辈指教~
