The TCS1416 monitors the Type-C Configuration Channel (CC) lines to determine when an USB device is attached. If a sink device is attached, the TCS1416 applies power to VBUS though the P-MOSFET. When the sink device is removed, the switch will be turned off and discharge the VBUS to safe voltage.
Due to integrated auto-detect and auto-switch circuitry, the TCS1416 can apply correct electrical signatures automatically on the USB data lines to charge compliant devices among Apple, Samsung and BC1.2 DCP modes.
The TCS1416 can switch off P-MOSFET in order to protect the equipment when the supply power increased to 6.5V or the temperature of type-C connector is up to limit setting by NTC resistor.
TCS1416 MSOP8 Type-C接口芯片
TCS1416广泛应用于wall USB墙适配器、USB车载充电器、移动电源及USB外围设备更多TCS1416 MSOP8 Type-C接口芯片手册,原理图,电源输入输出规格,BOM 表和变压器参数以及安规和 EMI 测试数据等资料,可向骊微电子申请。 |
