[STM32F1] emWin:键盘EDIT自动获取点击EDIT框里的值并修改
1458|7
 楼主| xfcjava2 发表于 2021-1-6 18:15 | 显示全部楼层 |阅读模式
emWin: 键盘EDIT自动获取点击EDIT框里的值并修改
1、数字软键盘修改数据,先上照片:
2、实现如下:
  typedef struct tag_mdfKey
        u8    flag_ent; //确认标志
        u32   id_press;  //修改控件:ID
        char  mdf_buff[30];        //修改数据缓冲区
  }KPad_MDF;
static WM_MESSAGE kp_Msg;
KPad_MDF  kpad_mdf;  //数字键盘修改结构体变量
//数字小键盘:回调函数:
*       _cbDialogNumPad
static void _cbDialogNumPad(WM_MESSAGE * pMsg) {
  GUI_RECT r;
  int i, NCode, Id, Pressed = 0;
  WM_HWIN hDlg, hItem;
  hDlg = pMsg->hWin;
  switch (pMsg->MsgId) {
   case KEYPAD_UPDATE_MSG: //数字小键盘: 更新数据消息
     if(kpad_mdf.id_press>0){
            hItem = WM_GetDialogItem(hDlg, GUI_ID_EDIT1);
            EDIT_SetText(hItem,kpad_mdf.mdf_buff);
     }else{
           EDIT_SetText(hItem,"");
    WM_SetFocus(hItem);        //聚焦于小键盘上的EDIT编辑框
    break;
  case WM_PAINT:
    WM_GetClientRect(&r);
    GUI_SetColor(0x000000);
    GUI_DrawRect(r.x0, r.y0, r.x1, r.y1);          /* Draw rectangle around it */
    /* Draw the bright sides */
    GUI_SetColor(0xffffff);
    GUI_DrawHLine(r.y0 + 1, r.x0 + 1, r.x1 - 2);   /* Draw top line */
    GUI_DrawVLine(r.x0 + 1, r.y0 + 1, r.y1 - 2);
    /* Draw the dark sides */
    GUI_SetColor(0x555555);
    GUI_DrawHLine(r.y1-1, r.x0 + 1, r.x1 - 1);
    GUI_DrawVLine(r.x1-1, r.y0 + 1, r.y1 - 2);
    break;
  case WM_INIT_DIALOG:
    for (i = 0; i < GUI_COUNTOF(_aDialogNumPad) - 1; i++) {
      hItem = WM_GetDialogItem(hDlg, GUI_ID_USER + i);
      BUTTON_SetFont(hItem, &GUI_FontHZ_Saf_16);
      BUTTON_SetFocussable(hItem, 0);                       /* Set all buttons non focussable */
      switch (i) {
      case 18:
        BUTTON_SetBitmapEx(hItem, 0, &_bmArrowLeft, 10, 12);  /* Set bitmap for arrow left button (unpressed) */
        BUTTON_SetBitmapEx(hItem, 1, &_bmArrowLeft, 10, 12);  /* Set bitmap for arrow left button (pressed) */
        break;
      case 19:
        BUTTON_SetBitmapEx(hItem, 0, &_bmArrowRight, 10, 12); /* Set bitmap for arrow right button (unpressed) */
        BUTTON_SetBitmapEx(hItem, 1, &_bmArrowRight, 10, 12); /* Set bitmap for arrow right button (pressed) */
        break;
   hItem = WM_GetDialogItem(hDlg, GUI_ID_EDIT1);  //数字小键盘上的:EDIT控件
   EDIT_SetMaxLen(hItem,30);
   EDIT_SetBkColor(hItem,0,GUI_BLACK);
   EDIT_SetFont(hItem,&GUI_Font24B_1);
   EDIT_SetTextAlign(hItem,GUI_TA_VCENTER|GUI_TA_LEFT);
   EDIT_SetTextColor(hItem,0,GUI_RED);
    break;
  case WM_NOTIFY_PARENT:
    Id    = WM_GetId(pMsg->hWinSrc);      /* Id of widget */
    NCode = pMsg->Data.v;                 /* Notification code */
          switch (NCode) {
                        case WM_NOTIFICATION_CLICKED:
                                if(Id ==(GUI_ID_USER + 17)){ //"ENT"按键----按下
                                    hItem =WM_GetDialogItem(hDlg, GUI_ID_USER + 17);
                                    BUTTON_SetBkColor(hItem,BUTTON_CI_PRESSED,GUI_GREEN); //按下时--绿色背景
                                Pressed = 1;
                                break;
                        case WM_NOTIFICATION_RELEASED:
                                if ((Id >= GUI_ID_USER) && (Id <= (GUI_ID_USER + GUI_COUNTOF(_aDialogNumPad) - 1))) {
                                        int Key;
                                        if (Id < GUI_ID_USER + 14) {
                                                char acBuffer[10];
                                                BUTTON_GetText(pMsg->hWinSrc, acBuffer, sizeof(acBuffer)); /* Get the text of the button */
                                                Key = acBuffer[0];
                                        } else {
                                                Key = _aKey[Id - GUI_ID_USER - 13];                        /* Get the text from the array */
                                                if(Id ==(GUI_ID_USER + 17)){ //"ENT"按键---抬起
                                                        BUTTON_SetBkColor(hItem,BUTTON_CI_UNPRESSED,0xAAAAAA);
                                                        EDIT_GetText(hItem,kpad_mdf.mdf_buff,30);  //获取编辑后的内容
                                                        kpad_mdf.flag_ent=1;//set
                                        Pressed = 1;
                                        GUI_SendKeyMsg(Key, Pressed);     /* Send a key message to the focussed window */
                                break;
    default:
      WM_DefaultProc(pMsg);
//主窗体下的控件处理:
* 功    能: 数字小键盘---更新数据处理函数
* 入口参数: hDlg------窗口句柄
*            Id--------控件ID
* 出口参数: nil
void KeyPad_Update_Process(WM_HWIN hDlg,int Id)
    WM_HWIN hItem;
    memset(kpad_mdf.mdf_buff,0,30);//clear
    kpad_mdf.flag_ent=0; //clear
    kpad_mdf.id_press=Id;
    hItem = WM_GetDialogItem(hDlg, Id);
    EDIT_GetText(hItem,kpad_mdf.mdf_buff,30); //获取点击的EDIT编辑框的内容
    kp_Msg.MsgId = KEYPAD_UPDATE_MSG;
    WM_SendMessage(WM_GetClientWindow(hNumPad), &kp_Msg);          //给小键盘发送消息
* 功    能: 数字小键盘---更新完成函数
*                  Id--------控件ID
* 出口参数: nil
void KeyPad_Update_Finish(WM_HWIN hDlg)
        u8 i;
        WM_HWIN hItem;
        #if OS_CRITICAL_METHOD == 3
          OS_CPU_SR  cpu_sr = 0;
        #endif
        if(kpad_mdf.flag_ent==1){ //数字小键盘:确认修改
                if((kpad_mdf.id_press== GUI_ID_EDIT0)||
                   (kpad_mdf.id_press== GUI_ID_EDIT1)||
                   (kpad_mdf.id_press== GUI_ID_EDIT2)){
                                hItem = WM_GetDialogItem(hDlg, kpad_mdf.id_press);  //要点击修改的EDIT编辑框
                                EDIT_SetText(hItem,kpad_mdf.mdf_buff); //更新为:小键盘EDIT的内容
                                i=kpad_mdf.id_press-GUI_ID_EDIT0;
                                //添加自己的代码, 存储数据
                                Buzzer_out();        //蜂鸣器鸣响--->提示
                memset(&kpad_mdf,0,sizeof(KPad_MDF));  //clear
                WM_HideWindow(hwin_keypad);   //
                WM_HideWindow(hNumPad);      //隐藏虚拟小键盘
//主窗体: 回调函数
static void _cbCallback(WM_MESSAGE * pMsg)
    WM_HWIN hItem;
    WM_HWIN hDlg = pMsg->hWin;
      case WM_TOUCH:
                 break;
        case WM_PID_STATE_CHANGED: //the pressed state has been changed.
                 break;
        case UPDATE_MSG_TEXT:
                 KeyPad_Update_Finish(hDlg); //主窗体---更新小键盘的数据
                 break;
           switch(NCode)
                     case WM_NOTIFICATION_CLICKED:   //编辑框内点击------数字小键盘显示
                       switch(Id)
                              if((Id == GUI_ID_EDIT0)||
                                (Id == GUI_ID_EDIT1)||
                                (Id == GUI_ID_EDIT2))
                                        int x_pos,y_pos;
                                        hItem = WM_GetDialogItem(hDlg, GUI_ID_EDIT2);
                                        x_pos=WM_GetWindowOrgX(hItem);
                                        y_pos=WM_GetWindowOrgY(hItem);
                                        KeyPad_Update_Process(hDlg,Id); //数字小键盘更新数据处理
                                        WM_MoveTo(hwin_keypad,x_pos-15,y_pos-20);        //移动窗口
                                        WM_ShowWindow(hwin_keypad);   //
                                        WM_ShowWindow(hNumPad); //显示虚拟键盘
                       break;
3、最后的总结如下:
 楼主| xfcjava2 发表于 2021-1-8 13:49 | 显示全部楼层
数字小键盘编辑修改功能,更新后的消息处理:
#define KEYPAD_UPDATE_MSG     WM_USER + 90
#define KEYPAD_UPDATE_END     WM_USER + 100
//__packed:注意字节对齐的问题!!!
         __packed  u16   flag_ent;      //确认标志
         __packed  s16   wm_src;         //源窗口句柄
                        char  mdf_buff[32];        //修改数据缓冲区
}KPad_MDF;
* 功    能: 数字小键盘更新数据处理函数
*                  Id--------控件ID
* 出口参数: nil
        WM_HWIN hItem;
        WM_MESSAGE kp_Msg;
        memset(kpad_mdf.mdf_buff,0,,sizeof(kpad_mdf.mdf_buff));//clear
        kpad_mdf.flag_ent=0;//clear
        kpad_mdf.wm_src=hDlg; //源窗口句柄
        kpad_mdf.id_press=Id; //控件id
        EDIT_GetText(hItem,kpad_mdf.mdf_buff,sizeof(kpad_mdf.mdf_buff));
*       _cbDialogNumPad
  GUI_RECT r;
  WM_MESSAGE end_Msg;
  hDlg = pMsg->hWin;
          switch (NCode) {                case WM_NOTIFICATION_RELEASED:
                          end_Msg.MsgId = KEYPAD_UPDATE_END;        //向源窗体--->发送确认修改消息
                          WM_SendMessage(WM_GetClientWindow(kpad_mdf.wm_src), &end_Msg);
                    break;
//源窗体处理:
  case KEYPAD_UPDATE_END: //数字小键盘--->修改完毕消息
           KeyPad_Update_Finished(hDlg);
           break;
//消息传递、处理示意图:
磨砂 发表于 2021-2-3 09:03 | 显示全部楼层
图片是用什么做的啊
晓伍 发表于 2021-2-3 09:13 | 显示全部楼层
这个函数体需要自己写吗
八层楼 发表于 2021-2-3 09:21 | 显示全部楼层
代码基本上非常易读
观海 发表于 2021-2-3 09:23 | 显示全部楼层
这样在界面上修改起来非常方便
guanjiaer 发表于 2021-2-3 09:27 | 显示全部楼层
注释很多 非常易读
 楼主| xfcjava2 发表于 2021-2-3 10:44 | 显示全部楼层
图片是用什么做的啊
消息传递、处理示意图,用的软件是:Microsoft Office Visio
