[技术问答] MINI51 DE 的寄存器手册里面有错误
384|0
 楼主| elephant00 发表于 2021-1-7 09:46 | 显示全部楼层 |阅读模式
TRM_Mini51DE_Series_EN_Rev1.03   ,
在PHCHG 的寄存器说明中, 如下关于10 和11的说明是错误的,明显就没有P3.3这个引脚。
CMP1SEL
Select the positive input source of ACMP1.
00 = Select P3.1 as the input of ACMP1.
01 = Select P3.2 as the input of ACMP1.
10 = Select P3.3 as the input of ACMP1.
11 = Select P3.4 as the input of ACMP1.
