[技术问答] Eclipse编译 N9H工程 可应用整合到Visual Studio (Code)下编译
849|7
 楼主| twjiang 发表于 2021-4-1 14:50 | 显示全部楼层 |阅读模式
根据以下编译信息,请自行整合到 Visual Studio (Code) 开发环境!
14:44:31 **** Build of configuration Release for project 2D ****
make all
Building file: D:/Projects/N9H30_emWin_NonOS/SampleCode/2D/main.c
Invoking: GNU ARM Cross C Compiler
arm-none-eabi-gcc -mcpu=arm926ej-s -marm -mlittle-endian -mfloat-abi=soft -O0 -fmessage-length=0 -fsigned-char -ffunction-sections -fdata-sections  -g3 -ggdb -I"D:/Projects/N9H30_emWin_NonOS/SampleCode/2D/GCC/../../../Driver/Include" -std=gnu11 -MMD -MP -MF"Src/main.d" -MT"Src/main.o" -c -o "Src/main.o" "D:/Projects/N9H30_emWin_NonOS/SampleCode/2D/main.c"
Finished building: D:/Projects/N9H30_emWin_NonOS/SampleCode/2D/main.c
Building file: D:/Projects/N9H30_emWin_NonOS/Driver/Source/2d.c
arm-none-eabi-gcc -mcpu=arm926ej-s -marm -mlittle-endian -mfloat-abi=soft -O0 -fmessage-length=0 -fsigned-char -ffunction-sections -fdata-sections  -g3 -ggdb -I"D:/Projects/N9H30_emWin_NonOS/SampleCode/2D/GCC/../../../Driver/Include" -std=gnu11 -MMD -MP -MF"Driver/Driver/2d.d" -MT"Driver/Driver/2d.o" -c -o "Driver/Driver/2d.o" "D:/Projects/N9H30_emWin_NonOS/Driver/Source/2d.c"
Finished building: D:/Projects/N9H30_emWin_NonOS/Driver/Source/2d.c
Building file: D:/Projects/N9H30_emWin_NonOS/Driver/Source/Startup_GCC.S
Invoking: GNU ARM Cross Assembler
arm-none-eabi-gcc -mcpu=arm926ej-s -marm -mlittle-endian -mfloat-abi=soft -O0 -fmessage-length=0 -fsigned-char -ffunction-sections -fdata-sections  -g3 -ggdb -x assembler-with-cpp -I"D:/Projects/N9H30_emWin_NonOS/SampleCode/2D/GCC/../../../Driver/Include" -MMD -MP -MF"Driver/Driver/Startup_GCC.d" -MT"Driver/Driver/Startup_GCC.o" -c -o "Driver/Driver/Startup_GCC.o" "D:/Projects/N9H30_emWin_NonOS/Driver/Source/Startup_GCC.S"
Finished building: D:/Projects/N9H30_emWin_NonOS/Driver/Source/Startup_GCC.S
Building file: D:/Projects/N9H30_emWin_NonOS/Driver/Source/lcd.c
arm-none-eabi-gcc -mcpu=arm926ej-s -marm -mlittle-endian -mfloat-abi=soft -O0 -fmessage-length=0 -fsigned-char -ffunction-sections -fdata-sections  -g3 -ggdb -I"D:/Projects/N9H30_emWin_NonOS/SampleCode/2D/GCC/../../../Driver/Include" -std=gnu11 -MMD -MP -MF"Driver/Driver/lcd.d" -MT"Driver/Driver/lcd.o" -c -o "Driver/Driver/lcd.o" "D:/Projects/N9H30_emWin_NonOS/Driver/Source/lcd.c"
Finished building: D:/Projects/N9H30_emWin_NonOS/Driver/Source/lcd.c
Building file: D:/Projects/N9H30_emWin_NonOS/Driver/Source/sys.c
arm-none-eabi-gcc -mcpu=arm926ej-s -marm -mlittle-endian -mfloat-abi=soft -O0 -fmessage-length=0 -fsigned-char -ffunction-sections -fdata-sections  -g3 -ggdb -I"D:/Projects/N9H30_emWin_NonOS/SampleCode/2D/GCC/../../../Driver/Include" -std=gnu11 -MMD -MP -MF"Driver/Driver/sys.d" -MT"Driver/Driver/sys.o" -c -o "Driver/Driver/sys.o" "D:/Projects/N9H30_emWin_NonOS/Driver/Source/sys.c"
Finished building: D:/Projects/N9H30_emWin_NonOS/Driver/Source/sys.c
Building file: D:/Projects/N9H30_emWin_NonOS/Driver/Source/sys_uart.c
arm-none-eabi-gcc -mcpu=arm926ej-s -marm -mlittle-endian -mfloat-abi=soft -O0 -fmessage-length=0 -fsigned-char -ffunction-sections -fdata-sections  -g3 -ggdb -I"D:/Projects/N9H30_emWin_NonOS/SampleCode/2D/GCC/../../../Driver/Include" -std=gnu11 -MMD -MP -MF"Driver/Driver/sys_uart.d" -MT"Driver/Driver/sys_uart.o" -c -o "Driver/Driver/sys_uart.o" "D:/Projects/N9H30_emWin_NonOS/Driver/Source/sys_uart.c"
Finished building: D:/Projects/N9H30_emWin_NonOS/Driver/Source/sys_uart.c
Building file: D:/Projects/N9H30_emWin_NonOS/Driver/Source/system_N9H30.c
arm-none-eabi-gcc -mcpu=arm926ej-s -marm -mlittle-endian -mfloat-abi=soft -O0 -fmessage-length=0 -fsigned-char -ffunction-sections -fdata-sections  -g3 -ggdb -I"D:/Projects/N9H30_emWin_NonOS/SampleCode/2D/GCC/../../../Driver/Include" -std=gnu11 -MMD -MP -MF"Driver/Driver/system_N9H30.d" -MT"Driver/Driver/system_N9H30.o" -c -o "Driver/Driver/system_N9H30.o" "D:/Projects/N9H30_emWin_NonOS/Driver/Source/system_N9H30.c"
Finished building: D:/Projects/N9H30_emWin_NonOS/Driver/Source/system_N9H30.c
Building target: 2D.elf
Invoking: GNU ARM Cross C Linker
arm-none-eabi-gcc -mcpu=arm926ej-s -marm -mlittle-endian -mfloat-abi=soft -O0 -fmessage-length=0 -fsigned-char -ffunction-sections -fdata-sections  -g3 -ggdb -T "D:\Projects\N9H30_emWin_NonOS\Driver\Source\GCC.ld" -Xlinker --gc-sections -Wl,-Map,"2D.map" --specs=rdimon.specs -Wl,--start-group -lgcc -lc -lc -lm -lrdimon -Wl,--end-group -o "2D.elf"  ./Src/main.o  ./Driver/Driver/2d.o ./Driver/Driver/Startup_GCC.o ./Driver/Driver/lcd.o ./Driver/Driver/sys.o ./Driver/Driver/sys_uart.o ./Driver/Driver/system_N9H30.o
Finished building target: 2D.elf
Invoking: GNU ARM Cross Create Flash Image
arm-none-eabi-objcopy -O binary "2D.elf"  "2D.bin"
Finished building: 2D.bin
Invoking: GNU ARM Cross Print Size
arm-none-eabi-size --format=berkeley "2D.elf"
   text           data            bss            dec            hex        filename
  30720         111144         294920         436784          6aa30        2D.elf
Finished building: 2D.siz
14:44:34 Build Finished (took 2s.315ms)
 楼主| twjiang 发表于 2021-4-1 14:52 | 显示全部楼层
不使用  Keil 编译器,不怕用盗版被人家天天发律师函了!再搞个 OpenOCD就OK了
 楼主| twjiang 发表于 2021-4-1 17:56 | 显示全部楼层
请参考:
https://bbs.21ic.com/icview-3115052-1-1.html
https://bbs.21ic.com/icview-3122154-1-1.html
勇敢的大白菜 发表于 2021-4-1 17:59 | 显示全部楼层
感谢楼主的分享,看不大明白。
正圆椭圆 发表于 2021-4-1 23:38 | 显示全部楼层
太好了 所有都能用vscode是最好的
BettyBerry 发表于 2021-4-1 23:47 | 显示全部楼层
码一个 虽然没有习惯用vscode不过多一个选择总是好的
氧化二氢 发表于 2021-4-3 23:52 | 显示全部楼层
具体要怎么操作啊 不是很会弄
尼罗河L 发表于 2021-4-3 23:53 | 显示全部楼层
不错 先马一个 暂时没有用这个的想法 不过多一个选择总是好的
