 收到板子快半个月了,之前没接触过AVR单片机,趁着节假日学习下AVR,开始点灯
 ①下载安装MPLAB X IDE开发环境,安装XC8编译工具,安装MPLAB代码配置器MCC
 打开MPLAB
 ②新建工程File—>New Project...
 ③选择Microchip Embedded—>Standalone Projects—>Next
 ④Device选择AVR128DB48、Tool选择AVR128DB48 Curiosity Nano
 ⑤编译工具选择XC8
 ⑥设置工程名,存储路径,Encoding设置GB18030(中文注释就不会显示为乱码)
 ⑦Tools—>Embedded—>MCC,打开代码配置器
 ⑧配置System Module,Oscillator Frequency Options设置16MHz system clock
 ⑨配置Pin Module,右击Pin Manager: Package View中芯片引脚PB3,设置为GPIO output
 ⑩添加TCA0定时器外设,使能定时器TCA0,Clock Selection设置System Clock/16,使能溢出中断
 ⑪配置Interrupt Manager,使能全局中断
 ⑫配置完成后,点击Generate生成main.c,在main.c中增加LED代码,定时器设置为10us中断一次,呼吸频率200Hz,5ms(500*10us)
 #include "mcc_generated_files/mcc.h"
uint16_t PWMCount = 0;
uint16_t BreathingCount = 0;
uint16_t PWMDutyCount = 1;
uint8_t Direction = 0;
    Main application
void Breathing_cb(void)
    TCA0_ClearOverflowInterruptFlag();
    TCA0_WriteTimer(0);
    PWMCount++;
    BreathingCount++;
    if(PWMCount == PWMDutyCount)
        LED_SetHigh();
    if(PWMCount >= 350)
        LED_SetLow();
        PWMCount = 0;
    if(BreathingCount >= 500 && Direction == 0)
        BreathingCount = 0;
        PWMDutyCount++;
        if(PWMDutyCount >= 349)
            Direction = 1;
    if(BreathingCount >= 500 && Direction == 1)
        BreathingCount = 0;
        PWMDutyCount--;
        if(PWMDutyCount == 1)
            Direction = 0;
int main(void)
    /* Initializes MCU, drivers and middleware */
    SYSTEM_Initialize();
    LED_SetDigitalOutput();
    LED_SetHigh(); //LED熄灭
    TCA0.SINGLE.PER = 10; //10us定时中断一次
    TCA0_WriteTimer(0);
    TCA0.SINGLE.INTCTRL = 1 << TCA_SINGLE_OVF_bp;
    TCA0_SetOVFIsrCallback(Breathing_cb);
    while (1){
⑬效果如下:
 测试源码:
