[技术讨论] 那位大佬有做过GD32F103RBT6 DMA+PWM?
669|1
 楼主| xta 发表于 2021-4-18 14:07 | 显示全部楼层 |阅读模式
void pwm_gpio_config(void)
  rcu_periph_clock_enable(RCU_GPIOC);
        gpio_init(GPIOC,GPIO_MODE_AF_PP,GPIO_OSPEED_50MHZ,GPIO_PIN_6);
我们现在的项目用到DMA(从内存到外设)+PWM(调占空比),用的芯片是GD32F103RBT6。
我们现在DMA1+PWM(TIMER7)的配置上,是否能提供例程
我们自己配置以下:帮忙确认一下是否有错
void timer_config(void)
    /* TIMER0 configuration: generate PWM signals with different duty cycles:
       TIMER0CLK = SystemCoreClock / 108 = 1MHz */
    timer_oc_parameter_struct timer_ocintpara;
    timer_parameter_struct timer_initpara;
    rcu_periph_clock_enable(RCU_TIMER7);
    timer_deinit(TIMER7);
    /* TIMER0 configuration */
    timer_initpara.prescaler         = 107;
    timer_initpara.alignedmode       = TIMER_COUNTER_EDGE;
    timer_initpara.counterdirection  = TIMER_COUNTER_UP;
    timer_initpara.period            = 500;
    timer_initpara.clockdivision     = TIMER_CKDIV_DIV1;
    timer_initpara.repetitioncounter = 0;
    timer_init(TIMER7,&timer_initpara);
     /* CH0 configuration in PWM mode */
    timer_ocintpara.outputstate  = TIMER_CCX_ENABLE;
    timer_ocintpara.outputnstate = TIMER_CCXN_DISABLE;
    timer_ocintpara.ocpolarity   = TIMER_OC_POLARITY_HIGH;
    timer_ocintpara.ocnpolarity  = TIMER_OCN_POLARITY_HIGH;
    timer_ocintpara.ocidlestate  = TIMER_OC_IDLE_STATE_LOW;
    timer_ocintpara.ocnidlestate = TIMER_OCN_IDLE_STATE_LOW;
    timer_channel_output_config(TIMER7,TIMER_CH_0,&timer_ocintpara);
    timer_channel_output_pulse_value_config(TIMER7,TIMER_CH_0,250);
    timer_channel_output_mode_config(TIMER7,TIMER_CH_0,TIMER_OC_MODE_PWM0);
    timer_channel_output_shadow_config(TIMER7,TIMER_CH_0,TIMER_OC_SHADOW_DISABLE);
    timer_primary_output_config(TIMER7,ENABLE);
    /* auto-reload preload enable */
    timer_auto_reload_shadow_enable(TIMER7);
    timer_enable(TIMER7);
    \brief      configure PWM DMA
    \param[in]  none
    \param[out] none
    \retval     none
void pwm_dma_config(void)
    dma_parameter_struct dma_init_struct;
    /* enable DMA1 */
    rcu_periph_clock_enable(RCU_DMA1);
    /* deinitialize DMA channel2(TIMER7 TIMER_CH_0) */
    dma_deinit(DMA1, DMA_CH2);
    dma_init_struct.direction = DMA_MEMORY_TO_PERIPHERAL;//从内存到外设
    dma_init_struct.memory_addr = (uint32_t)MY_WS2812_GRB_BUF;//DMA数组
    dma_init_struct.memory_inc = DMA_MEMORY_INCREASE_ENABLE;
    dma_init_struct.memory_width = DMA_MEMORY_WIDTH_16BIT;//数组是U16的,是否这样设置
    dma_init_struct.number = ARRAYNUM(MY_WS2812_GRB_BUF);//DMA数组的大小
    dma_init_struct.periph_addr = PWM_TIMER7_DATA_ADDRESS;//((uint32_t)0x40013400) TIMER7是否是这个地址
    dma_init_struct.periph_inc = DMA_PERIPH_INCREASE_DISABLE;
    dma_init_struct.periph_width = DMA_PERIPHERAL_WIDTH_16BIT;//数组是U16的,是否这样设置
    dma_init_struct.priority = DMA_PRIORITY_ULTRA_HIGH;
    dma_init(DMA1, DMA_CH2, &dma_init_struct);
    /* configure DMA mode */
    dma_circulation_disable(DMA1, DMA_CH2);
    dma_memory_to_memory_disable(DMA1, DMA_CH2);
我们对DMA配置不太了解
这样就配置好了吗?
数组通过DMA输出到PWM调整占空比,还需要用到那些库函数
还有外设的地址是否有错
谢谢
 楼主| xta 发表于 2021-4-18 14:15 | 显示全部楼层
本来要发贴到GD版块的,结果发到这里来了
xta
