//此代码是我本人原创 xa87@live.cn复制 for(int i=0;i<0x012345;i++){ __nop(); //延时约0.2秒 等待电源稳定 } RCC->CR|=BIT(16); //1: HSE oscillator ON while((RCC->CR&BIT(17))==0); //0: HSE oscillator not ready //N=50-432 //M=2-63 //vco=in*(n/m) vco=100-432M //out=vco/p P=2/4/6/8 //(8M*(200/8))/2=100M //PLL时钟源来自外部HSE /N=6 /M=8 RCC->PLLCFGR=BIT(22)|(200<<6) |(8<<0); //P=0=*2 RCC->CR|=BIT(24); //1: PLL ON while((RCC->CR&BIT(25))==0); //Bit 25 PLLRDY: Main PLL (PLL) clock ready flag //切换前FLASH时钟等待加长 FLASH->ACR=6; //100M时等待6个周期 6 WS (7 CPU cycles) //APB1最大50M 100/2 RCC->CFGR|=4<<10; //APB1 100: AHB clock divided by 2 //主时钟切换至PLL RCC->CFGR|=2; //Bits 1:0 SW: System clock switch / 10: PLL selected as system clock while((RCC->CFGR&8)!=8); //等待时钟切换完成 p108 //系统定时器,相关时钟开启 SystemCoreClockUpdate(); SysTick_Config(SystemCoreClock/1000); //1ms时基 RCC->AHB1ENR|=BIT(0)|BIT(1)|BIT(2)|BIT(3)|BIT(4); //GPIO时钟开启 //IO配置 {//2初始化输出点 //out-en pc15 GPIOC->ODR|=BIT(15); GPIOC->MODER|=1<<(15*2); //01: General purpose output mode uint16_t PinBit; //pa输出点 位全置0,输出关闭 参见BSP.H GPIOA->ODR=0; GPIOA->MODER|= (1<<(0*2))| //pinF1 (1<<(1*2))| //pinF2 (1<<(4*2)); //pinCS1 //pb输出点 GPIOB->ODR=0; GPIOB->MODER|= (1<<(0*2)) | (1<<(1*2)) | (1<<(8*2)) | (1<<(9*2)) | (1<<(10*2)) | (1<<(11*2)) | (1<<(12*2)) | (1<<(13*2)) | (1<<(14*2)) | (1<<(15*2)); //pe 输出点 GPIOE->ODR=0; GPIOE->MODER|= (1<<(0*2)) | (1<<(1*2)) | (1<<(2*2)) | (1<<(3*2)) | (1<<(4*2)) | (1<<(5*2)) | (1<<(6*2)) | (1<<(7*2)) | (1<<(8*2)) | (1<<(9*2)) | (1<<(10*2)) | (1<<(11*2)) | (1<<(12*2)) | (1<<(13*2)) | (1<<(14*2)) | (1<<(15*2)); }//pc输出 //pd输出 GPIOC->ODR&=~BIT(15); //out-en pc15 {//3.初始化输入点 //下拉输出模式 2MHz; //pa输入点 //pb输入点 //pe 输入点 //PC输入(默认就是输入,忽略 ) //PD输入(默认就是输入,忽略 ) }//Pe输入 //4读取配置 {//5热电偶初始化 SPI1 RCC->APB2ENR|=BIT(12); //GPIO初始化 //pa5,pa6复用 SCK MISO GPIOA->AFR[0]|=(5<<5*4)|(5<<6*4); //af5,af5 GPIOA->MODER|=(2<<(5*2)) | (2<<(6*2)); //10: Alternate function mode GPIOA->OSPEEDR|=(2<<(5*2)) | (2<<(6*2)); //2=GPIO_SPEED_FAST //max6675 MAX=4.3 MHz SPI1->CR1|=BIT(11); //Bit 11 1: 16-bit data frame format SPI1->CR1|=BIT(9); //Bit 9 1: Software slave management enabled SPI1->CR1|=4<<3; //5=101: fPCLK/64 Baud rate control 100/64=1.56M 100/32=3.12M //4=clk/32 SPI1->CR1|=BIT(2); //1: Master configuration SPI1->CR2|=BIT(2); //SSOE //a4=cs1,pe13,14,15=cs2,3,4 GPIOA->ODR|=BIT(4); GPIOE->ODR|=BIT(13); GPIOE->ODR|=BIT(14); GPIOE->ODR|=BIT(15); SPI1->CR1|=BIT(6); //Bit 6 SPI enable } //配置定时器 控制最终目标温度 if(ReadCBit(20,9)){ //位9机头电机运动功能 //200 180/c //todo:位9机头电机运动功能 换F4后删除 } //6配置RS485串口 modbus //modbus 实现 位写入,位读取 位映射 //rs485与屏通信 //pa9 tx af7 //pa10 rx af7 GPIOA->MODER|=(2<<(9*2))|(2<<(10*2)); //10: Alternate function mode GPIOA->AFR[1]|=(7<<(4*2))| (7<<(4*1)); //af7 RCC->APB2ENR|=BIT(4); //100-000-000/16/115200=54.25347222222222 //M=54 F=.25347222222222*16=4 USART1->BRR=(54<<4)|4; USART1->CR1|=BIT(3); //Bit 3 TE: Transmitter enable USART1->CR1|=BIT(2); //Bit 2 RE: Receiver enable USART1->CR1|=BIT(5); //接收中断开启 ORE=1 or RXNE=1 USART1->CR1|=BIT(13); //Bit 13 UE: USART enable // __NVIC_EnableIRQ(USART1_IRQn); // // NVIC->ISER[(((uint32_t)USART1_IRQn) >> 5UL)] = (uint32_t)(1UL << (((uint32_t)USART1_IRQn) & 0x1FUL)); NVIC_EnableIRQ(USART1_IRQn); //x9接的是PD14,用于履带机的电机脉冲触发信号,约1-30秒触发一次 EXTI->IMR|=EXTI_IMR_MR14; EXTI->FTSR|=EXTI_FTSR_TR14; //1: Falling trigger enabled RCC->APB2ENR|=RCC_APB2ENR_SYSCFGEN; SYSCFG->EXTICR[3]|= 3<<8; //0011: PD[x] pin NVIC_EnableIRQ(EXTI15_10_IRQn); //看门狗 RCC->CSR|=RCC_CSR_LSION; //时钟开启 while((RCC->CSR & RCC_CSR_LSIRDY)==0); //1: LSI RC oscillator ready IWDG->KR=0x5555; //启用寄存器可写 IWDG->PR=2; //0=32k/4*4096=0.5秒 1=/8=1秒 2=/16=2秒 while((IWDG->SR&IWDG_SR_PVU)==0); //更新成功 IWDG->KR=0xCCCC; //启动 DOG(); //end 所有寄存器配置都是参照手册,一点点测试。 这样出现问题时比较好查找问题。 也能学习更多知识。
收藏0 举报
本版积分规则 发表回复 回帖并转播 回帖后跳转到最后一页
人才类勋章
扫码关注 21ic 官方微信
扫码关注嵌入式微处理器
扫码关注电源系统设计
扫码关注21ic项目外包
扫码浏览21ic手机版
本站介绍 | 申请友情链接 | 欢迎投稿 | 隐私声明 | 广告业务 | 网站地图 | 联系我们 | 诚聘英才
京公网安备 11010802024343号
