[技术讨论] Thu May 06, 2021 15:52:54: The stack pointer for stack 'CSTACK' (currently 0x...
1217|1
 楼主| 天命风流 发表于 2021-5-6 16:03 | 显示全部楼层 |阅读模式
Thu May 06, 2021 15:52:54: The stack pointer for stack 'CSTACK' (currently 0x04000000) is outside the stack range (0x20003078 to 0x20004278)
我用IAR软件仿真,可以正常仿真,但却时不时停止仿真,同时跳出上面的报警,有哪位大神可以解答,感激不尽!!!
天意无罪 发表于 2021-5-6 17:41 | 显示全部楼层
指针越界了,应该是你的程序里面有些变量超出了设置的堆栈大小了。
