| #define uint  unsigned int #define uchar unsigned char
 uchar key , disp_buf , temp;
 //unsigned char l_tmpdate[8]={15,11,10,0,0,14,2,12};
 unsigned char l_tmpdate[8]={7,6,5,4,2,3,1,0};
 unsigned long freq = 10000;
 uchar count_i = 0;
 sbit LS138A = P2^2;          //定义138译码器的输入A脚由P2.2控制
 sbit LS138B = P2^3;            //定义138译码器的输入脚B由P2.3控制
 sbit LS138C = P2^4;         //定义138译码器的输入脚C由P2.4控制
 void delay(uchar x);
 int keyscan(void);
 void display(unsigned char *lp,unsigned char lc);
 void diszf();
 //code unsigned char  LED7Code[] = {~0x3F,~0x06,~0x5B,~0x4F,~0x66,~0x6D,~0x7D,~0x07,~0x7F,~0x6F,~0x77,~0x7C};  //共阳极
 code unsigned char  LED7Code[] = {0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,0x7F,0x6F,0x77,0x7C};                 //共阴极
 //code unsigned char key_table[13]={0xed,0x7e,0x7d,0x7b,
 //        0xbe,0xbd,0xbb,0xde,
 //        0xdd,0xdb,0x77,0xb7,
 //        0Xff};
 //        0                1                        2                3                4                        5                        6                7                        8                9                        a                b
 code unsigned char key_table[]={0x7b,0xed,0xdd,0xbd,0xeb,0xdb,0xbb,0xe7,0xd7,0xb7,0x7d,0x77};
 //        1        2        3        up                                            0x01 0x02 0x03 0x0a
 //        4        5        6 dn 对应16进制码 0x04 0x05 0x06 0x0b
 //        7        8        9        M1                                            0x07 0x08 0x09 0x0d
 //        *c 0 #ok        M1                                         0x0c 0x00 0x0e 0x0f
 void  delay(uchar x)
 { uchar j;
 while((x--)!=0)  //CPU执行x*125次
 { for(j=0;j<125;j++)
 int keyscan(void)                            //执行一下会得到一个对应的键值
 uchar i,scancode;
 P0 = 0xf0;        // 发全0行扫描码
 if ((P0&0xf0)!=0xf0)                                        // 若有键按下
 delay(1);                                                        // 延时去抖动
 scancode = 0xfd;
 //                key = 0xff;
 for(i=0;1<3;++i)
 P0 = scancode;
 if ((P0&0xf0)!=0xf0)                                // 延时后再判断一次,去除抖动影响
 key = P0;
 break;
 scancode = _crol_(scancode,1);
 return(0);        // 无键按下,返回值为0
 int main()
 int i , num ;
 num = 0xff;
 P0 = 0x00;                //键盘置位
 //        P1 = 0xff;                //数码管置位
 delay(10);
 while(1)
 keyscan();
 for(i=0;i<13;i++)
 {                        //查表获得相应的16进制值存放l_key变量中
 if (key==key_table[i])
 num=i;
 break;
 //                  P1 = LED7Code[num];
 display(l_tmpdate,8);                        //输出获取的键值码
 if(num==0x01){                        //1按键判断
 num=0xff;
 if(count_i && count_i<9){
 switch(count_i){
 case 1: freq=1;break;
 case 2: freq=freq*10+1;break;
 case 3: freq=freq*10+1;break;
 case 4: freq=freq*10+1;break;
 case 5: freq=freq*10+1;break;
 case 6: freq=freq*10+1;break;
 case 7: freq=freq*10+1;break;
 case 8: freq=freq*10+1;break;
 count_i++;
 diszf();
 if(num==0x02){                        //2按键判断
 num=0xff;
 switch(count_i){
 case 1: freq=2;break;
 case 2: freq=freq*10+2;break;
 case 3: freq=freq*10+2;break;
 case 4: freq=freq*10+2;break;
 case 5: freq=freq*10+2;break;
 case 6: freq=freq*10+2;break;
 case 7: freq=freq*10+2;break;
 case 8: freq=freq*10+2;break;
 count_i++;
 diszf();
 if(num==0x03){                        //3按键判断
 num=0xff;
 switch(count_i){
 case 1: freq=3;break;
 case 2: freq=freq*10+3;break;
 case 3: freq=freq*10+3;break;
 case 4: freq=freq*10+3;break;
 case 5: freq=freq*10+3;break;
 case 6: freq=freq*10+3;break;
 case 7: freq=freq*10+3;break;
 case 8: freq=freq*10+3;break;
 count_i++;
 diszf();
 if(num==0x04){                        //4按键判断
 num=0xff;
 switch(count_i){
 case 1: freq=4;break;
 case 2: freq=freq*10+4;break;
 case 3: freq=freq*10+4;break;
 case 4: freq=freq*10+4;break;
 case 5: freq=freq*10+4;break;
 case 6: freq=freq*10+4;break;
 case 7: freq=freq*10+4;break;
 case 8: freq=freq*10+4;break;
 count_i++;
 diszf();
 if(num==0x05){                        //5按键判断
 num=0xff;
 switch(count_i){
 case 1: freq=5;break;
 case 2: freq=freq*10+5;break;
 case 3: freq=freq*10+5;break;
 case 4: freq=freq*10+5;break;
 case 5: freq=freq*10+5;break;
 case 6: freq=freq*10+5;break;
 case 7: freq=freq*10+5;break;
 case 8: freq=freq*10+5;break;
 count_i++;
 diszf();
 if(num==0x06){                        //6按键判断
 num=0xff;
 switch(count_i){
 case 1: freq=6;break;
 case 2: freq=freq*10+6;break;
 case 3: freq=freq*10+6;break;
 case 4: freq=freq*10+6;break;
 case 5: freq=freq*10+6;break;
 case 6: freq=freq*10+6;break;
 case 7: freq=freq*10+6;break;
 case 8: freq=freq*10+6;break;
 count_i++;
 diszf();
 if(num==0x07){                        //7按键判断
 num=0xff;
 switch(count_i){
 case 1: freq=7;break;
 case 2: freq=freq*10+7;break;
 case 3: freq=freq*10+7;break;
 case 4: freq=freq*10+7;break;
 case 5: freq=freq*10+7;break;
 case 6: freq=freq*10+7;break;
 case 7: freq=freq*10+7;break;
 case 8: freq=freq*10+7;break;
 count_i++;
 diszf();
 if(num==0x08){                        //8按键判断
 num=0xff;
 switch(count_i){
 case 1: freq=8;break;
 case 2: freq=freq*10+8;break;
 case 3: freq=freq*10+8;break;
 case 4: freq=freq*10+8;break;
 case 5: freq=freq*10+8;break;
 case 6: freq=freq*10+8;break;
 case 7: freq=freq*10+8;break;
 case 8: freq=freq*10+8;break;
 count_i++;
 diszf();
 if(num==0x09){                        //9按键判断
 num=0xff;
 switch(count_i){
 case 1: freq=9;break;
 case 2: freq=freq*10+9;break;
 case 3: freq=freq*10+9;break;
 case 4: freq=freq*10+9;break;
 case 5: freq=freq*10+9;break;
 case 6: freq=freq*10+9;break;
 case 7: freq=freq*10+9;break;
 case 8: freq=freq*10+9;break;
 count_i++;
 diszf();
 if(num==0x00){                        //0按键判断
 num=0xff;
 switch(count_i){
 case 1: freq=0;break;
 case 2: freq=freq*10;break;
 case 3: freq=freq*10;break;
 case 4: freq=freq*10;break;
 case 5: freq=freq*10;break;
 case 6: freq=freq*10;break;
 case 7: freq=freq*10;break;
 case 8: freq=freq*10;break;
 count_i++;
 diszf();
 if(num==0x0a){                        //步进按键
 num=0xff;
 freq+=100;
 diszf();
 ad9850_reset();
 ad9850_wr(0x00,freq);//串行写freqHz频率程序
 if(num==0x0b){                        //步退按键
 num=0xff;
 freq-=100;
 diszf();
 ad9850_reset();
 if(num==0x0a){                        //更改按键
 num=0xff;
 count_i=1;
 freq=0;
 //           ad9850_reset();
 diszf();
 if(num==0x0b){                        //确认输出按键
 num=0xff;
 count_i=0;
 diszf();
 //          ad9850_reset();
 //         ad9850_wr(0x00,freq);//串行写freqHz频率程序
 /*if(num==0x0d){                        //**1按键
 num=0xff;
 count_i=0;
 freq=38000000;
 diszf();
 ad9850_reset();
 if(num==0x0f){                        //**2按键,弄个蛙鸣的频率试试
 num=0xff;
 count_i=0;
 freq=7023000;
 diszf();
 ad9850_reset();
 void display(unsigned char *lp,unsigned char lc)//显示
 unsigned char i;                //定义变量
 //   P1=0;                                        //端口2为输出
 //    P1=P1&0xF8;                                //将P1口的前3位输出0,对应138译门输入脚,全0为第一位数码管
 for(i=0;i<lc;i++)
 {                //循环显示
 //  P1=LED7Code[lp[i]];        //查表法得到要显示数字的数码段
 //   delay(1);                                //延时5个空指令
 switch(i)          //使用switch 语句控制位选  也可以是用查表的方式 学员可以试着自己修改
 case 0S138A=0; LS138B=0; LS138C=0; P1=LED7Code[lp[i]]; break;
 case 1S138A=1; LS138B=0; LS138C=0; P1=LED7Code[lp[i]]; break;
 case 2S138A=0; LS138B=1; LS138C=0; P1=LED7Code[lp[i]]; break;
 case 3S138A=1; LS138B=1; LS138C=0; P1=LED7Code[lp[i]]; break;
 case 4S138A=0; LS138B=0; LS138C=1; P1=LED7Code[lp[i]]; break;
 case 5S138A=1; LS138B=0; LS138C=1; P1=LED7Code[lp[i]]; break;
 case 6S138A=0; LS138B=1; LS138C=1; P1=LED7Code[lp[i]]; break;
 case 7S138A=1; LS138B=1; LS138C=1; P1=LED7Code[lp[i]]; break;
 delay(1000);
 //        if(i==7)                                //检测显示完8位否,完成直接退出,不让P1口再加1,否则进位影响到第四位数据
 //        break;
 P1=0;                                        //清0端口,准备显示下位
 //    a++;                                        //下一位数码管
 void diszf()//处理转换给数码管显示字符
 bit nums=1;
 unsigned long tmp;
 l_tmpdate[0]=freq/10000000;
 tmp=freq/10000000;
 if(tmp==0 && nums)
 l_tmpdate[0]=0;
 else
 nums=0;
 tmp=freq%10000000;
 l_tmpdate[1]=tmp/1000000;
 if(l_tmpdate[1]==0 && nums)
 l_tmpdate[1]=0;
 else
 nums=0;
 tmp=tmp%1000000;
 l_tmpdate[2]=tmp/100000;
 if(l_tmpdate[2]==0 && nums)
 l_tmpdate[2]=0;
 else {
 nums=0; }
 tmp=tmp%100000;
 l_tmpdate[3]=tmp/10000;
 if(l_tmpdate[3]==0 && nums)
 l_tmpdate[3]=0;
 else {
 nums=0; }
 tmp=tmp%10000;
 l_tmpdate[4]=tmp/1000;
 if(l_tmpdate[4]==0 && nums)
 l_tmpdate[4]=0;
 else {
 nums=0; }
 tmp=tmp%1000;
 l_tmpdate[5]=tmp/100;
 if(l_tmpdate[5]==0 && nums)
 l_tmpdate[5]=0;
 else {
 nums=0; }
 tmp=tmp%100;
 l_tmpdate[6]=tmp/10;
 if(l_tmpdate[6]==0 && nums)l_tmpdate[6]=0;
 else {
 nums=0; }
 tmp=tmp%10;
 l_tmpdate[7]=tmp%10;
