| Features
 3.0V to 60V Wide Input Voltage
 Integrated 250mΩ 60V Power MOSFET
 Up to 95% Step-up conversion efficiency
 Low than 0.1mA static current
 1.2MHz Fixed Switching Frequency
 1mA Light load model efficiency up to 80%
 Low than 10uA Shutdown current
 Built-in Cycle-by-cycle current limiting
 Built-in thermal shutdown protection
 Built-in under-voltage protection
 Built-in loop compensatio
 Built-in soft start circuit
 Simple external circuit
 Available in a 6-pin SOT-23 package
 General Description
 The is a constant frequency,
 mode step-up converter intended
 for small, low power applications. The
 switches at 1.2MHz and allows
 the use of tiny, low cost capacitors and
 inductors 5mm or less in height. Internal
 soft-start results in small inrush current
 and extends battery life.
 The includes under-voltage
 lockout, current limiting, and thermal
 overload protection to prevent damage in
 the event of an output overload. The
 is available in a small 6-pin
 SOT-23 package.
  ZCC6303恒流驱动_datasheet_V1.0.pdf
(829.79 KB, 下载次数: 1)
