- void rt_schedule(void)
- rt_base_t level;
- struct rt_thread *to_thread;
- struct rt_thread *from_thread;
- /* disable interrupt */
- level = rt_hw_interrupt_disable();
- /* check the scheduler is enabled or not */
- if (rt_scheduler_lock_nest == 0)
- rt_ubase_t highest_ready_priority;
- if (rt_thread_ready_priority_group != 0)
- /* need_insert_from_thread: need to insert from_thread to ready queue */
- int need_insert_from_thread = 0;
- to_thread = _get_highest_priority_thread(&highest_ready_priority);
- if ((rt_current_thread->stat & RT_THREAD_STAT_MASK) == RT_THREAD_RUNNING)
- if (rt_current_thread->current_priority < highest_ready_priority)
- to_thread = rt_current_thread;
- else if (rt_current_thread->current_priority == highest_ready_priority && (rt_current_thread->stat & RT_THREAD_STAT_YIELD_MASK) == 0)
- else
- need_insert_from_thread = 1;
- rt_current_thread->stat &= ~RT_THREAD_STAT_YIELD_MASK;
- if (to_thread != rt_current_thread)
- /* if the destination thread is not the same as current thread */
- rt_current_priority = (rt_uint8_t)highest_ready_priority;
- from_thread = rt_current_thread;
- rt_current_thread = to_thread;
- RT_OBJECT_HOOK_CALL(rt_scheduler_hook, (from_thread, to_thread));
- if (need_insert_from_thread)
- rt_schedule_insert_thread(from_thread);
- rt_schedule_remove_thread(to_thread);
- to_thread->stat = RT_THREAD_RUNNING | (to_thread->stat & ~RT_THREAD_STAT_MASK);
- /* switch to new thread */
- RT_DEBUG_LOG(RT_DEBUG_SCHEDULER,
- ("[%d]switch to priority#%d "
- "thread:%.*s(sp:0x%08x), "
- "from thread:%.*s(sp: 0x%08x)\n",
- rt_interrupt_nest, highest_ready_priority,
- RT_NAME_MAX, to_thread->name, to_thread->sp,
- RT_NAME_MAX, from_thread->name, from_thread->sp));
- #ifdef RT_USING_OVERFLOW_CHECK
- _rt_scheduler_stack_check(to_thread);
- #endif
- if (rt_interrupt_nest == 0)
- extern void rt_thread_handle_sig(rt_bool_t clean_state);
- rt_hw_context_switch((rt_ubase_t)&from_thread->sp,
- (rt_ubase_t)&to_thread->sp);
- /* enable interrupt */
- rt_hw_interrupt_enable(level);
- #ifdef RT_USING_SIGNALS
- /* check stat of thread for signal */
- if (rt_current_thread->stat & RT_THREAD_STAT_SIGNAL_PENDING)
- rt_current_thread->stat &= ~RT_THREAD_STAT_SIGNAL_PENDING;
- /* check signal status */
- rt_thread_handle_sig(RT_TRUE);
- else
- #endif
- goto __exit;
- else
- RT_DEBUG_LOG(RT_DEBUG_SCHEDULER, ("switch in interrupt\n"));
- rt_hw_context_switch_interrupt((rt_ubase_t)&from_thread->sp,
- else
- rt_schedule_remove_thread(rt_current_thread);
- rt_current_thread->stat = RT_THREAD_RUNNING | (rt_current_thread->stat & ~RT_THREAD_STAT_MASK);
- __exit:
- return;
