刚使用PIC单片机不久,有大神帮忙看一下是什么问题吗?非常感谢!
我在MPLAB IPE中使用ICD4烧录程序不成功。
MPLAB IPE中使用ICD4连接目标板,能够正常连接,如下图
但是点击“Program”时 烧录失败,提示如下
Erasing...
The following memory area(s) will be programmed:
program memory: start address = 0x0, end address = 0x1fff
configuration memory
EEData memory
Verify failed. [ Pgm ] at 0x11, expected 0x000000fb, got 0x000000ff
You have set the program speed to Normal. The circuit on your board may require you to slow the speed down. Please change the setting in the tool properties to low and try the operation again.
Programming did not complete.
2018-12-10 19:19:56 +0800 - Programming failed
Pass Count: 27
